Hello
I make this topic only to reduce lenght of mine signature - links to mine productions, I'll be updating this post everytime I make sth new :
(on down part of this post You have the freshest units)
Single-stages , cascades, chillers :
Rotary + R507 @ -88.1 *C
Revage's phase
Titan 507- cased, daily chiller
Phase9 - strongest SS in the world, 3 heads
Jack's silent SLI/CF single-stage cooler (2* NL11F@R507, red LEDs)
Tuko's SS - rotary + black metal case + R507
3/4 HP single-stage and -93.1*C done
Team Poland's tiny cascade
Dalky's chiller
Rotary dual-evap : 2*GPU or CPU+GPU
Rotary 2 stager with metal case and some extras
Kumkum's 1.5 HP Single-stage
1.5 HP single-stage = -62*C @ 225W
Cosmo chiller
David's cascade
t800's silver minicascade
Pudi's chiller
Magoa's rotary cascade
chiller Minsk XTReme mkII (-13*C @ 605W)
Cascade to Belgium
Naked 2x 1HP cascade
Danfoss SC18CL cascade (ethylene, single evap)
Danfoss SC18CL GPU SLI/CF cascade (R23, two evaps)
Silver NL11F SS
Black and naked... 2x 1HP cascade
Blue and naked... 2x 1HP cascade
Chief(tec) NL11F SS (all in big tower)
Silver Cascade (2 x 1 HP) with bypass valve
Antec Twelve Hundred with surprise inside (worklog)
Prometeia Mach 2ST - COMPLETE REBUILD
Prometeia Mach 1 - MOD
AIRCHILLER + single-stage
Ordinary SS with rotary compressor, in blue case
Piotres' first liquidcooled SS
White cascade with bypass valve
Portable benching SS (with rotary compressors)
One more small benching SS
Deep Purple cascade
Cheap, blue CHILLER based on rotary compressor
SS + chiller = 2 in 1
Value 2stage cascade
Strong and silent waterchiller (-22C with 500W load)
Daily, 24/7, silent CASCADE with case
Rotary SS in black case
2x 2HP cascade in case (-100*C @ 315W)
SS dual evap CPU + GPU with orange pipes
2x 2.5 HP cascade (-103*C @ 315W)
Vapochill LS, Prometeia Mach 1, LD unit - MODDED
Prometeia Mach 2 GT MODDED
Cold plate in vapochill LS case
Repaired units (Prometeia + 2x LD's units)
Suction Lines :
Suction Lines - ALL
LN2/Dry-Ice containers :
Spiral/steeper DI/Ln2 CPU container
GPU steeper, copper containers
Xtra simple CPU copper container
Simple copper, brazed, 54 mm CPU container
Xtra Simple GPU DI/Ln2 Container rev 2.0
5.0 GPU SLI/CF containers for Ln2/DI
Krullet's SLI containers' rebuild
GPU copper containers for 4870x2 and other GPUs (DI/Ln2 tubes)
Chipset Ln2/DI container
Semi-solid copper CPU DI/Ln2 container
GPU steeper SLIM containers
SEMI-SOLID CPU 70/54mm 100% copper
SOLID COPPER containers for CPU -60 mm diameter, 70mm diameter, 70x70 mm
SOLID COPPER container for CPU -80 mm diameter
SOLID COPPER container for CPU -70x70mm version2
SOLID COPPER container for CPU -70x70mm 140mm long 3.2+kg
SOLID COPPER container for CPU -70x70mm NICKEL plated
If that's possible- please don't write any answers in this topicthanks in advance .
Best Regards
Peter
thanks in advance .
