Hello
I want to present SS in silver case 490x210x230mm with Danfoss NL11F compressor and R507 freon. Nothing fancy, just cased and small SS
Specs (final) :
Compressor: Danfoss NL11F
Evap: steeper 42mm diameter, braided DN10 suction flex hose
XV: captube 0.8 mm
Condensor: Unseen BIG cube, with 120x38 mm Delta 12V plus 120x25 mm pushing fan
Refrigerant : R507
Case : Custom, metal case 49 x 21 x 23 cm, painted on metalic silver
Others: Tt Thunderblade on the back of case (with LEDs removed), blue CCFLs inside case, sound insulation, Eliwell EM300 temperature display, plexi window in case.
(look at posts on page no 2 to see final result)
Unit is not finished ...
thanks
best regards
peter
