Hi
Krullet has sent me his SLI kit for complete rebuild it to use 2 containers on G80 series. So I've put here new bases from mine 3.0 series SLI containers ...I let to tell rest pictures
Containers staight from Krullet's house .
"Old" kit after cleaning from insulation (it had been sticked, gah, dirt work) .
After unbrazing old bases ..inside had been much dirt, sth like very heavy oxidations ...I think that had reduced heat transfer pretty good![]()
I must to cut tubes to fit them for new bases which are ...
BIGGER(new vs old bases)
Thiner container brazed ...
Thicker near done ...I need to make a mod with add some plate to make tube thiner in down part.
Just before cleaning ...
Tomorrow I hope to clean, polish, and insulate them, so I hope to finish work.
Regards
Peter
(new vs old bases)
