Hi
Sometimes ago, Dalkarian ask me about chiller, because He liked the Titan 507 chiller build by me.
After some ideas, we finally decided to built it in that specs:
compressor: Danfoss NL11F
heat exchanger: Plate HX , 12 plates (first time it was homemade HX, 25 cm, 35mm OD pipe with 3 meters 1/4' inside)
XV: captube 0.8 mm
condensor: custom made 195 x 167 x 60 mm , alu-cu, 0.395 kW, cooled with two Thermaltake Thunderblades Blue LED 120/25 mm
refrigerant : R507
case: metal case 59 x 21 x 23 cm, black, plexi window, glossy coat
others: elctronic controller Everycontrol (from -40*C to +99*C), Xilence Blue LED 120/25 mm on the back of case, custom made plexi grills on fans - snow flake pattern, suction line acumulator
Cutting pattern in left side panel.
First homemade HX ...later after first tests with water inside, I decided to swap it for plate HX, becasue I wasn't happy with chiller's performance .
Noload temps, no water inside ...and that's last picture with homemade HX ...![]()
Brand new plate HX.
I've test it with 1.5 litre water+alcohol + Maxi-Jet 1000l/h pump + 12 mm ID hoses ...cooled down 1.5l liquid :
11*C -> 0*C = 2 mins.
11*C -> -15*C = 12 mins.
11*C -> -19*C = 20 mins.
As You can see on the picture Everycontrol controller is laying around 7-8*C (gives higher temperatures that it's on real).
Liquid after 20 minutes.
Chiller is already in Dalkarian's house, I hope it cooled well Conroe E6600 + ATI X1900XTX.
Regards
Peter
is the remedy
