Results 1 to 25 of 68
Thread: Danfoss SC18CLs GPU SLI/CF Cascade - worklog
Threaded View
    -100c Club Member
    Mar 2005
    Poland
    Hello
    It's mine first SLI cascade, some mounths ago I have tried to make dual-evap one, but it didn't work fine becasue of too small condensor . This one has quite big condensor - dual fan 200mm each 230V, 3.6 kW condensor . Cascade will be using silent Danfoss SC18CL compressors and of course oilseparator with float. Adds like Dixell controller and 4 REFCO gauges kit started to be "normal" in mine cascades - everybody want that . Cascade will be using R507 on 1st stage and R23 on 2nd stage.
    Specs :
    compressors: 2 x Danfoss SC18CL
    evaps and suction flex hoses: two GPU evaps : steeper design, 24mm tall, 42 mm diam., plus 120 cm long suction lines DN10 braided
    XV: probably Danfoss TS2 on 1st stage/ captubes 0.9 mm on 2nd stage
    HX: Plate HX, 12 plates
    condenser: 3.6 kW condensor + 2x 200mm, 230V fans
    refrigerants : R507/R23
    oilseparator : Shine Year with automatic oil back
    safety : Danfoss KP5 cutoff
    case : Laser cutted and powder coated case (white) plus black details, wheels
    others: Dixell XR20CX to control 2nd stage start, 4* REFCO panel gauges, expansion tank 1.1l Torecilla, two white CCFLs inside, 350 mm 230V blower fan on back wall.
    It's worklog, now I've got bit longer break in work over it, becasue of problems with getting case for it, one workshop make me that since 5 weeks so change it finally for another, becasue I don't like if somebody threats me in that way . I hope case will finally arrive to me next week .
    Case will be BIG one, with 350 mm blower fan . Case will be white with black details .
    Two GPU evaps after final cleaning .
    Big condensor and rest of parts .
    That's 350 mm fan .
    Condensor which I've parted for desuperheater for 2nd stage and condensor for 1st stage .
    REFCO Gauges and Danfoss KP5 cut-off.
    I've new googles , special designed for acet-oxy brazing - Nemesis IRUV 5 .
    Suction lines .
    1.1 l Torecilla receiver modded to expansion tank.
    More pics during few next weeks ...
    Best Regards
    Peter
