Hello
I move this cascade from this topic : http://www.xtremesystems.org/forums/...=166418&page=3, becasue this contest finished.
This is quite ordinary cascade - metal baseplate, plate HX, R507/R1150, 4 gauges ...but it finally have 2x 12000 BTU,1HP compressors, not ordinary for me 9000-11000 BTU.
Specs :
compressors: Sanyo remark C-RN110H5A around 12000 BTU so 1HP on both stages
evap: steeper
XVes: ALCO TI-HW (designed for R22, but I bet it'll be working well with R507) + nozzle 01 / captube 0.9 mm
HX: plate HX , 12 plates
condenser: 3.0 Kw, alu-cu, cooled by 300mm/230V fan
refrigerants : R507/R1150
oilseparator : Shine Year automatic
safety : JOHNSON CONTROLS cut-off, 1.8 litre TORRECILLA expansion tank
case : baseplate 46 x 46 cm, zincked steel + wheels
others: 4*REFCO gauges, Anaconda shocks absorber on 1st stage's suction line,DIXELL XR20CX controller (turn on 2nd stage automatically when 1st stage is enought cold) .
Baseplate is ready.
Braided suction line and compressors,which I planned to use first .
Suction line ... green sleeve finally arrived yesterday, I'll put it on suction flex hose soon.
TORRECILLA 1.8L receiver will be modded to expansion tank.
Then ...
I've decided to use 12000 BTU 1HP compressor in both stages:
and more work ...
Finally, I've put wooden plate under steel plate to make it more stiff - those 1HP rotaries aren't light ;-) .
Temperatures during filling,no loaded, with almost no insulation(except that which You can see so on suction line and on HX) .
I've already almost made complete insulation, in next few days I'll made electrics and final tests on new 260W dummyload which is already waiting for frost.
Best Regards
Peter
