Results 1 to 12 of 12
Thread: Semi-solid CPU 70/54mm 100% cooper
Threaded View
    -100c Club Member
    Mar 2005
    Poland
    Hi
    Semi-solid by piotres . 100% copper.
    Base part is 100% same as in 70mm diam solid , like showed here: http://www.xtremesystems.org/forums/...d.php?t=247238 , pipe is 54mm copper.
    Specs:
    -100% copper (except enclosure )
    -1.33kg mass
    -70mm/54mm diameter
    -200mm tall
    -40mm bottom thickness + 12mm and 5mm holes in bottom
    -hole for mounting K-probe in bottom
    -19 mm thick PCV enclosure
    -2.0mm thick steel powdercoated backplate
    -19mm thick armaflex insulation
    Sorry I forgot to make photo showing weight, but it's 1.33kg, You must trust me .
    Do You like it ?
    Thanks for looking
    With Kindest Regards
    Peter
