Hello
I want to show You one or mine next cascades - this time it's simple 2 stager without any gadgets - just metal baseplate and 2 rotaries.
Specs :
compressors: Toshiba PG180-X1C on 1st stage (11000 BTU) and TECO KETC176ELBC-A on 2nd stage (10755 BTU)
evap: steeper, 40 mm tall
XV: Danfoss TES2 / captube 0.9 mm
HX: Plate HX, 12 plates
condenser: double condensor, 2 x 2 rows condensors, cooled by 4 x 120/38mm mm high flow fans (NBM and Sunon)
refrigerants : R507/R1150
oilseparator : ESK Schultze with automatic oil back
safety : RANCO cut-off
case : Steel zincked baseplate - 50 x 35 cm
others: LCD HX out temperature display, 2 gagues - on both stages' discharge, wheels for baseplate, 28 mm thick insulation on suction line![]()
First I've tried captube 0.8mm on 1st stage, but discharge on this stage goes over 22 bara when I load 2nd stage evap with 225W.....
..... so I decide to swap it for Danfoss TES2 TXV.
Now pressure is 14-16 bara all the time, even with 225W load. Near -56*C 1st stage unloaded
Small LCD thermo made around 5*C mistake, as always.
No load final charge.
225W load.
Cascade is ready
Regards
Peter
