Results 1 to 25 of 32
Thread: Black and naked :)... 2x 1HP cascade ;)
Threaded View
    -100c Club Member
    Mar 2005
    Poland
    Smile Black and naked :)... 2x 1HP cascade ;)
    Hello
    This is VERY typical and quite boring, ordinary cascade - metal baseplate (welded frame), plate HX, R507/R1150, no gauges, 2x 13000 BTU,1HP compressors.
    So simple, without bling-blings so it's not such expensive as cased cascades ..
    Specs :
    compressors: Sanyo remark C-RN110H5A around 13000 BTU so 1HP on both stages
    evap: steeper
    XVes: Danfoss TS2+ nozzle 01 / captube 0.9 mm
    HX: plate HX , 12 plates
    condenser: 3.0 Kw, alu-cu, cooled by 300mm/230V fan plus alu-cu 2x120mm desuperheater for 2nd stage
    refrigerants : R507/R1150
    oilseparator : Temprite 340 + Castell handvalve + Danfoss sightglass
    safety : RANCO cut-off, 1.5 litre FACH expansion tank
    case : baseplate with welded frame 70 x 53 cm , black painted+ wheels
    others: Anaconda shocks absorber on 1st stage's suction line and ...that's all
    Frame made by my Father and his helper . That's a lot Dad .
    Only one suction line will be used here, other one is for another order .
    Next part of work and some description after I'll back from holidays so after 17.08 till that time I'm offline
    Now I go ) .
    Best Regards
    Peter
