Hi
Some weeks ago I've seen an announce that Tuko want to buy new single-stage . He wanted to buy sth to cool his QX6700, because he wasn't happy with modded vapo LS+ quadcore connection. He wanted a custom 46x46cm (base) case and temperature display
. Suction line is very short (but can be bit longer, by taking some of it from case's inside
), because it's 24/7 cooler, to use under PC case.
Specs :
Compressor: Sanyo C-1RV137H11AA
evap: steeper by piotres
XV: captube 0.8 mm
condenser: 1 kW, 2 row, alu-cu, cooled by orginal 230 V fan
Refrigerant : R507
Case : Custom metal case, 46 x 46 x 43 cm, painted black
others: Dixell XR40C controler, used as a temperature display, 240 mm fan 230v on back wall of case
Some nice temps during filling with R507.
On 215W dummyload it's making around -44-45*C .
Unloaded is "only" around -50*C, because unit is tunned for quadcore loads.
Just before closing the case .
Dixell isn't laying very much.
Regards
Peter
. Mine friend said that 2 rotaries in cascade (8000-9000 BTU) are more silent than one Danfoss SC21CL
