Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Cosmo chiller
    -100c Club Member
    Mar 2005
    Poland
    Cosmo chiller
    Hi
    I want to show You my last chiller project - it's chiller to cool CCD camera in home astronomical observatory .
    Specs :
    compressor: Aspera NE2134GK
    heat exchanger: plate HX 12 plates
    XV: captube 0.8 mm, around 190 cm
    condensor: 1.9kW cooled by orginal 230V fan
    refrigerant : R507
    case: metal case 55 x 50 x 43 cm, black powder coating
    others: electronic controller Everycontrol (from -40*C to +99*C), two 230V fans 120/38mm on the back of case .
    Case is powder coated .
    Around -29*C liquid in first run .
    Chiller takes around 350-400W .
    Finally -31*C liquid .
    With some insulation stuff ....
    Regards
    Peter
    May 2006
    Philippines ^_^
    very very nice.. I'm planing to build a chiller my self..
    hey what pump do you use??
    your casing is looking good.. I hope to see it in action..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    Join XS WCG or \/ !!
    Dec 2005
    Earth:\USA\OHIO
    Very Nice Peter
    Got an Xtreme System? Bring it here! <----
    Xtreme Cruncher
    Feb 2006
    Emmaus, PA, US
    case is fairly large for a basic chiller, but looks good nonetheless
    |Rig: AMD Athlon64 X2 6000+ Windsor|6gb DDR2 800|Dual 250gb Western Digital RAID0|8600GT|
    (12:16:17 AM) OC3D NoL: NOL EAT ANNOYING NOOBIE
    (12:16:19 AM) OC3D NoL: RAWRRRR
    Banned
    Apr 2006
    Portishead, Bristol, England
    Case is so wrong, just look like you have taken a Cascade case and modded and it then sprayed it up.
    Well in fact you have!
    Meh still not bad at all -31c water!
    Mar 2007
    Tripoli, Greece; Toronto, Canada
    what hoses are you using there?
    -100c Club Member
    Mar 2005
    Poland
    Customer use quite crap 400l/h pump from Tt Big Water kit . But I think I'll be replaced soon.
    Hoses are ordinary, cheap 12/10 mm hoses from local shop .
    Yep first that had been planed to be cascade case ... but not sprayed, that powder coat .
    Pics in action soon.
    Peter
    Xtreme Cruncher
    May 2007
    In a hell hole called Sac
    I want it.
    Quote Originally Posted by [XC] Kayin View Post
    Should the RIAA ever target me, I will immediately forfeit US citizenship and move back to reservation, which has no extradition policy and would probably tell Whitey to get bent or we'll scalp you and take your women...
    Free Omastar!
    [SIGPIC][/SIGPIC]
    -100c Club Member
    Mar 2005
    Poland
    Two pics from customer, instalation of chiller is for me bit messy but that's not mine problem I think .
    @2long4u : I want sth like BMW M3 or Lancer Evo ...and cash for gasoline .
    Regards
    Peter
    Xtreme Cruncher
    May 2007
    How about a 77 chevy with 4"lift kit and 35x12.5 BFG Mud terrain tires. You could run over both thoes cars. It is soon to have a new engine built by yours truly.
    Free Omastar!
    [SIGPIC][/SIGPIC]
    Xtreme Mentor
    Mar 2006
    Redvers, Sask, Canada.
    Now he's a hard core astronomer! Reflective telescope, they be the best!
    Hey want to know where to get the perfect load tester for chillers? Thoughs cheap water cooler/heaters! I just got a 490W heater out of one in a ready made shell! Look into it mate!
    Bring back natural selection! No more warning lables!
    The one and Only MG Pony
    Apr 2006
    Middle of Nowhere
    That's a nice CCD cooler. Must get very little noise. But I gotta wonder where the user could set the telescope up where he could both: use the chiller and: be in an area where you wouldn't get light interference. That thing would suck up batteries rather fast but I guess you could use a generator.
    __________________
    Budgets, Bling, We Need Not These. We Have Science!
    Xtreme Mentor
    Mar 2006
    For a CCD thats not much of a heat load, it would be easy to make a low temp chiller that only used up 2Amps.
    Mar 2007
    quick question, using a larger plate hx cause any probs?
    Xtreme Mentor
    Mar 2006
    Quote Originally Posted by Athanatos View Post
    No not really in a system that small, just wasted material that could have been saved. a simple home made Hx, and a 300W Compressor would have been more then enough for that system.
    Mar 2007
    Quote Originally Posted by Xeon th MG Pony View Post
    good to know, got my eye on a 30 plate on ebay for cheap
    Xtreme Mentor
    Mar 2006
    well, 30 would be too big, as you do have to maintain a certain internal volocity, I'd say 16 is pretty big for such a system, but not horroridly over sized.
    I'd go to rons shop and get the 6,000 BTU Coaxial condencer, they're cheap and will work well. That way gravity will be more then enough to ensure oil return.
  18. #18
    Aug 2007
    Smile
    how much does it cost to get a chiller made ?
    i would like to cool my gpu and ram
  19. #19
    Xtreme Mentor
    Mar 2006
    Depends on how fancy you want it, and if you want all new parts.
  20. #20
    Mar 2007
    Quote Originally Posted by piotres View Post
    Awesome work
  21. #21
    May 2007
    Burlington Ontario
    I'de love to build something like this.
    How much for all new parts? roughly that is
    Motherboard Asus P5K Deluxe
    CPU E6850 @ 3.8ghz 1.5Vcore
    Ram OCZ Reapers Pc8500 2gb 4:4:4:12
    Hard drives 1 x 74gb Raptor 10k + 1 x 250gb Cav for storage
    Case Lian Li 1200bPLUS2
    PSU Corsair 620w
    GPU EVGA 8800ULTRA (660/1080) 13223 on 3dmark06
    Watercooling MCP655, Micro res, Mcr320, Fuzion, EK full coverage GPU block
  22. #22
    Nov 2006
    Poland / Rypin
    "I want to show You my last chiller project (...) "
    Why this is your last chiller project?
    Say us plx.
    Schedule of Live Extreme Overclocking - info Thread
    Quote Originally Posted by K404 View Post
    "My Backup is bigger than Your Backup"
  23. #23
    Nov 2004
    Poland
    Quote Originally Posted by Fatalbert View Post
    Say us plx.
    I think it's mean last built chiller, not his last chiller overall
    Quote Originally Posted by AndreYang View Post
    wtf..your cpu is better.
  24. #24
    Nov 2006
    Poland / Rypin
    Maybe
  25. #25
    -100c Club Member
    Mar 2005
    Poland
    Sure ...it's mine latest build .
