XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 04-12-2006, 01:02 PM   #1
piotres
-100c Club Member
piotres's Avatar
Send a message via ICQ to piotres Send a message via MSN to piotres
R507 single-stage @ - 88.1 *C :-D
Hi
Some weeks ago I got few rotary compressors ...so I decided to make a single-stage unit with one of that devils, to check how they perform .
Specs :
Compressor: Sanyo C-1RV137H11AA
evap: chilly1 patern (made in Poland )
holddown: PCV 10mm
XV: CPEV Fach "PZ"
condenser: 1 kW, 2 row, alu-cu, cooled by orginal 230 V fan
Refrigerant : R507
Case : Chipboard case, dimensions 51x39x42 cm, painted black, alu mesh on the front panel
others: SLHX
The heart of unit
Evap ..same as always
Making a SLHX
Some pipe work
Filling with R507
That's first run frost
Insulation complete and electric instalation done
Case just after painting .
Complete unit
Let's see what that baby can do :
Very "small" vac .. only sth like -0.97 bara... LOLLL
Some nice numbers, remember that's just pure R507 .
Have You ever seen lower temperature in Single-stage unit ??
Mine A64 3000+ Venice benching rig
That's stressed with 3000+ Venice @ 3211 MHz on 1.82V ... -55.5*C evap loaded (during SuperPI) , CPU around -15 to -18*C .
That's ...hym ..idle ..let's say that's idle - mine CPU has a coldbug when it reach -30*C on CPU, so after 5 second of end of SuperPi run I have got -60*C evap and freezed Windows ..so really I can't test it in idle I hope will be able to run @ sth like -60*C evap (maybe evan bit lower) idle on simillar CPU like mine .
That unit is currently for sale .
Regards
Peter
piotres is offline   Reply With Quote
Old 04-12-2006, 01:10 PM   #2
andL64
andL64's Avatar
Send a message via ICQ to andL64 Send a message via AIM to andL64 Send a message via Yahoo to andL64
looks really awsome !
great temps and nice casing! really never seen this temps on ss
i want to get R507 for my 1st stages for the cascade should be better than R290
__________________
. . . WHO put this thing together? ME !
. . . WHO do i trust? ME !
. . . f*** it, as****
andL64 is offline   Reply With Quote
Old 04-12-2006, 01:18 PM   #3
Vapor
Admin
Vapor's Avatar
Wow! That's awesome! How does would it hold up against a dual core load?
OT: Is that the pic I took (of GHZ's Opty 148) in your background? If so, I have a much higher-res version if you want
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 04-12-2006, 01:20 PM   #4
Waus-mod
ln2nl
Waus-mod's Avatar
I love it.. i really love it.
Im not into but is the loaded themprature not a high?
__________________
*EDITed by IFMU*
Signature Removed by XS Staff for not following XS Policies
Forum Policies
Waus-mod is offline   Reply With Quote
Old 04-12-2006, 01:26 PM   #5
piotres
-100c Club Member
piotres's Avatar
OT: Is that the pic I took in your background? If so, I have a much higher-res version if you want
I think it should be sth about -50*C on evap loaded with CPU like FX-60
That pic on my background is ...Yes it's Your's goodly Opty 148...I just like that pic ...very artistic .
Regards
Peter
Old 04-12-2006, 01:29 PM   #6
epion2985
Xtreme Mentor
epion2985's Avatar
Thats a nice peace of work right there.
Yes I have seen a few single stage units here in -80's with no load and -50's with load. Still damn nice.
Whats the hp, displacement, power consumption, and noise on that rotary?
__________________
French Duron Poof
Every time you lap a swiftech block a kitten dies
"Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
HEAT
epion2985 is offline   Reply With Quote
Old 04-12-2006, 01:31 PM   #7
krullet
krullet's Avatar
Send a message via MSN to krullet
got damit thats some nice work, ing nice temps
__________________
SYSTEM: |QX9650 | DFI P35 / EVGA 780I | CRUCIAL 2*1GB | 9800GTX | SILVERSTONE 1KW |
HOMEPAGE
krullet is offline   Reply With Quote
Old 04-12-2006, 01:48 PM   #8
Athens[2004]
Athens[2004]'s Avatar
Very nice job piotres , i can see that u brazing some metal around [outside] the evap so u can mount the hold down . U can do it more easie -> just drilling around the evap[outside] 2mm and put a safety instead of brazing .
+ So u can remove the safety anytime -> remove the holddown and change insulation <---[example given]
__________________
Post Qu1ck d1e Young.
Athens[2004] is offline   Reply With Quote
Old 04-12-2006, 01:49 PM   #9
Gautam
Captain Jinx
Gautam's Avatar
Send a message via AIM to Gautam Send a message via MSN to Gautam
Excellent work! I've been waiting a while to see someone push the SS envelope a bit harder. With all these cascades and DI/LN2 containers floating about, its almost as if people forgot about 'em. :p
__________________
Originally Posted by FUGGER View Post
I put on my shoes before I put on my pants.
Gautam is offline   Reply With Quote
Old 04-12-2006, 01:56 PM   #10
piotres
-100c Club Member
piotres's Avatar
Thanks for advice Athens, but with mine way of mounting I can change the brackets easy too ...I'm using seger ring, so I can swap eg. a GPU bracket on the evap in some seconds I think that, when You write "safety" You was thinking about a ring around evap, am I right ?
Regards
Peter
Old 04-12-2006, 02:19 PM   #11
boostedevo
Gigabyte Champion USA
boostedevo's Avatar
Now THAT'S a single stage
boostedevo is offline   Reply With Quote
Old 04-12-2006, 02:21 PM   #12
PoL
PoL's Avatar
Sweeeeeeetttttt..... will be hard to decide.
__________________
Intel Core 2 Quad Q6600
GSkill F2-8000CL DDR2-1000 2x2GB
Abit IP35 Pro
XFX NVidia GeForce 6800GT @ 435/1210Mhz
2x WD Raptor 36GB RAID 0
Antec TruePower Quattro 1000w
Windows Vista Ultimate x64
PoL is offline   Reply With Quote
Old 04-12-2006, 02:28 PM   #13
Athens[2004]
Regards
Peter
yES. <---- my awesome English
__________________
Old 04-12-2006, 02:36 PM   #14
gclg2000
gclg2000's Avatar
Send a message via AIM to gclg2000
Looks good...
Is that a "T-couple" probe with a type "K" sensor plugged into it???
__________________
I like building Vapor phase coolers......
......to cool mynipples!!
Heat is "gclg2000"
95-0-0
-100C Cascade Club
gclg2000 is offline   Reply With Quote
Old 04-12-2006, 02:48 PM   #15
piotres
-100c Club Member
piotres's Avatar
Originally Posted by gclg2000
Looks good...
Yes it's "K" ... Voltcraft K102 is thermo designed for K-probes only
Old 04-12-2006, 02:54 PM   #16
dinos22
...you two characters
dinos22's Avatar
whoa...........that's nice dude
i have a little brother blackbox with R290 and 1HP rotor hheheh.......i'm waiting for gas upgrade
i reckon your idle temps are lower than -29C as my idle temps at 3.5GHz with 1.66v are -31C....shame the CPU can't take it real cold...........that's a monster vcore
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 04-12-2006, 02:58 PM   #17
piotres
-100c Club Member
piotres's Avatar
Hehe, during mine phase-change tests I'm always trying to push mine Venice to give the biggest load he can give ...so I always set 1.55V +123% in bios
Old 04-12-2006, 04:01 PM   #18
Weee
Send a message via MSN to Weee
Wow, LOADED temps, what a concept.. that's really awesome work there!
__________________
I had the fastest 32M Opteron time for about 1/2 day, and I'm damn proud of it
Weee is offline   Reply With Quote
Old 04-12-2006, 04:33 PM   #19
kayl
-100C Club Member
kayl's Avatar
Send a message via MSN to kayl
Regards
Peter
i think that is the lowest noload temp that i have seem.
Drewmeister still makes the coldest single stage loaded systems though at -60c load hight volts/OC
peter are you entering the autocascade compertition. that thing with some ethylene might hit -100c
__________________
GIG X58-UD5, i7 960 5535 i7950 5352Mhz E8600 6300Mhz
Kayl Block Frozen SS systems
Cascade CPU/GPU Tubes
kayl is offline   Reply With Quote
Old 04-12-2006, 10:52 PM   #20
johann
johann's Avatar
Nice man! That Rotary pulls a wicked vacuum sweeet.
__________________
My Phase change builds thread
johann is offline   Reply With Quote
Old 04-12-2006, 11:25 PM   #21
Sub zero
Great piece of work who wil be the first to -100 on a SS
__________________
You ever get the feeling your being watched!!
Sub zero is offline   Reply With Quote
Old 04-12-2006, 11:28 PM   #22
fatty
-100C Club
fatty's Avatar
Send a message via MSN to fatty
Very nice job Peter
__________________
Originally Posted by s7e9h3n
Hell, if it would unlock this godly 154, I'd put on a tutu and dance around like a ballerina
Mach 2 Problems Click
My Work
fatty is offline   Reply With Quote
Old 04-12-2006, 11:32 PM   #23
piotres
-100c Club Member
piotres's Avatar
Thx Guys
Kayl, yes I'll rather enter to autocascade competition, but begining of July it's the eariest time I'll start work on auto-c ...first I must pass my maturity exam in may, than build a single-stage(s) and 2-stage cascade in June, and maybe in July I'll start work on auto-c
Peter
Old 04-12-2006, 11:39 PM   #24
Jaco
Xtreme Cruncher
Jaco's Avatar
impressive work ! ( again)
__________________
Jaco is offline   Reply With Quote
Old 04-12-2006, 11:53 PM   #25
andL64
andL64's Avatar
nonload is insane really but load i think is "only" very good, lol
well i didnt reach that temps on my co2 cascade LOL but i can hold the temps better, and with dc
but this work is really awsome!!! give me one of these rotarys :P
seEn
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
