Hi
It's mine next STRONG Single-stage ..next after that one : http://www.xtremesystems.org/forums/...d.php?t=144781, almost same specs, compressor is exact same model, this time I have finally got -62*C@225W, so 4*C improvement.
Specs :
Compressor: HITACHI CHV33YC6-U - it's "tiny" 18000 BTU/ 1.5 HP rotary![]()
evap: steeper 40mm tall/40 mm diammeter
XV: captube 0.8 mm
condenser: 3 row, cooled by one 200mm/230V 5W fan
Refrigerant : R507+R410a blend
Case : Zincked plate 50 x 40 cm baseplate
Others : SLHX - 15mm with 1/4' inside, around 50 cm long
Finally I must change 4x 120mm Delta fans for one 200mm/230v fan with big shroud, becasue that power supply for fans wasn't working OK and damaged Deltas. Also power switch wasn't working OK, so finally owner has lovely, green button
Insulation on all pipes is 18mm thick.
And finally -62*C@225W. I haven't checked unloaded, but I think it's lower than -70*C
Best Regards
Peter
