Hi
That's SS for one nice guy from France ...first He had planned to buy Mach2/Vapo LS, later plan to order 1/3 HP SS from one builder in France and ...finally 3/4 HP (9000 BTU) SS with CPEV from me.
That's first time I've mounted CPEV near evaporator (CPEV outlet is connected by 10 cm, 5 mm OD pipe with evap). In that way CPEV works much better, reaction for tunning is much faster and pulldown time too.
No case, only metal baseplate, my customer said that He'll make case from plexi by himself.
Freezepack controller (by GSMaster) and suction pressure gauge, are extras which customer really wanted.
Unit beat mine "old" record with single (-88.1*C) - it has made -93.1*C.
Specs :
Compressor: Sanyo C-1RV137H11AA
evap: steeper by piotres
XV: CPEV Fach "PZ" mounted near evaporator head
condenser: 2 row, alu-cu, cooled by 4*120 mm NBM 12V fans
Refrigerant : R507/R410a blend
Baseplate : 49 x 35 cm zincked plate baseplate
others: REFCO low side gauge, FreezePack controller (by GSMaster)
Suction line together with polish CPEV .
When freezeControler arrived ..
First run ...and fighting for the COLDEST temperatures on evap (completelly closed CPEV) . RESULT : -93.1*C(that's now not WR
, becasue Symphy has beat me with -94.4*C but with single-stage 2.5 HP build by me
On 223W dummyload.
On 202W dummyload.
On 115W dummyload. As you can see -54*C in freezer's limit :-/ . Eg. real -54 = -54 on LCD, but eg. -60 real = still -54 on LCD, -65 real = -54 LCD etc. :-( .
Some tests on Conroe E6700es ..4+ Ghz/1.6V = lower that -60*C on evap in full stress.
and finally well packed ;-) .
Regards
Peter
