Hello
Today I want to show You worklog of sth less boring than rest of mine units: SS NL11F using Deluxe 0.5kW condensor, all closed in brand-new Chieftec Big Tower case
Specs :
Compressor: Danfoss NL11F
Evap: steeper 42mm diameter, braided DN10 suction flex hose
XV: captube 0.9 mm
Condensor: cold-ice custom "deluxe" 0.5kW with riffled tubes
Refrigerant : R507
Case : Chiftec Big Tower (brand new)
Others: Scythe Ultra Kaze fans, fan controller, blue temperature display, PC autostart module
Work till now :
Temperature display, thermostat to start PC automatic , and fan controller - all delivered by future owner of this ... case.
Also Scythe Ultra Kaze 120x38 mm HIGH flow fans ...
Now case will be limited only for one 5.25' bay ...some big reduction LOL.
I must move PSU higher to fit all in case ..specially when owner plan to use 164 mm long 650W PSU.
5.25' panel for controller - I must use old silver 5.25' mask, becasue orginal from Chieftec was not flat.
All till now ....
Regards
Peter
