Hello
That's chiller for mine good friend PMP . He want to cool using it whole config like :QX CPU (QX6850ES now), 2* 8800 ULTRA, Asus Striker mobo - as You can see quite hot stuff. That's second edition of his chiller, first was build on smaller aspera compressor, and small condensor and just can't cope with so huge load :-/ . So I decided to built it completelly new.
Name of chiller is taken from legendary (in Poland) russian refrigerator.
Specs :
compressor: Rotary 6826 BTU
heat exchanger: plate HX 12 plates
XV: Danfoss TS2 + Frigomec 0.88l receiver
condensor: 1.9kW cooled by orginal 230V fan
refrigerant : R134a (finally)
case: metal case 46 x 46 x 46 cm, black powder coating
others: electronic controller Dixell XR20C, one 230V fan 250mm on the back of case, Laing D5 pump, Swiftech small reservoir.
Laing D5 + Swiftech res..
Around -30*C with no-load on pure R507 .![]()
Power consumption when chiller is cooling liquid , as You can see on pic rotary musn't be so hungy.
-13*C liquid on 605W heater. Pure R507.
Finish.
Chiller has been on one polish ocer meeting in Gdansk. There is had been cooling Asus Striker mobo, liquid was around -25*C all the time
But condensation with R507 was too big, liquid was just WAY too cold. So decision to try R507 and 134a blend. Temp on 605W load with that blend.
But for owner...it was too cold still. So finally I put pure R134a, temperatures are like +2*C@605W .
I hope that owner will post some pics here in future.
Regards
Peter
