Hi
I want to show You mine latest cascade, it's 2 stager based on 2 rotary compressors, plate HX, Danfoss TS2 valve, Danfoss OUB1 oilseparator, some extras like four REFCO panel gauges or dixell controller and .... metal, BLACK case. We like that kind of cases, do we ?
Specs :
compressors: two Sanyo C-1RV137H11AA rotaries
evap: steeper by piotres
XV: Danfoss TS2 / captube 0.8 mm
HX: plate HX , 12 plates
condenser: 2 row, alu-cu, cooled by 4 x 120mm/12 V NBM fans
refrigerants : R507/R1150
oilseparator : Danfoss OUB1
safety : cut-off
case : metal case, 46 x 46 x 43 cm, black paint
others: 4*REFCO panel gauges, Dixell XR10C controller (turn on 2nd stage automatically when 1st stage is enought cold), homemade receiver before Danfoss TS2, big 230 mm/230V fan on the back wall of case
Suction line is braided one, 18 mm thick insulation and red sleeve.
Sorry for some dirty old insulation on compressors' accumulators.
Finally I've add shock absorber to 1st stage suction line (called "anaconda" here in Poland) and add also second drier to 2nd stage
Some first run digits.
Final charge, no load![]()
And here loaded with 225W.
We have tested that cascade on E6700 till now, and we got around -98-99*C loaded, and -100-102*C idle on evaporator with 4.7 GHZ / 1.7 V (end of bios in stock asus P5B DLX) .
I hope You like that project.
Regards
Peter
