Hi
It's ordinary cased SS with rotary compressor . Nothing interesting , really. The simplest SS that can be done (+case) .Owner of this unit doesn't want anything fancy, he just want strong SS with case. So it's ...
Specs :
Compressor: LG NK185PAD rotary around 10000 BTU
Evap: Steeper 40mm tall/42 mm diam., enclosure for all newest CPUs, 1.0 meter braided DN10 suction line (with stainless steel mesh)
XV: captube 0.9 mm
Condensor: 1.9kW ROEN-EST + 254mm 230V fan
Refrigerant : R507
Case : Metal case, powdercoated on blue color
Others: LED temperature display, two 120x38mm NIDEC fans on back of case
I used case which I had been using for 3 days (those SS which was built in that case needs biger condensor, so this case was too small).
This time I try to clean-up electic more . Sorry for funny descriptions in table , but I'm not electrician and I haven't got an idea how can I wrote that more professional ;-( .
I try new way of polishing also.
Unloaded during test in +25*C room.
Loaded by 260W dummyload, in +25*C room , after 2 hours test.
Best Regards
Peter
