Results 1 to 12 of 12
Thread: Steeper GPU containers (brazed, 100% cooper)
Threaded View
    -100c Club Member
    Mar 2005
    Poland
    Exclamation Steeper GPU containers (brazed, 100% cooper)
    Hello
    I got question if I would be able to make couple of containers to cool ATI5970 single card . I answer "yes" and that's what I've done .
    Containers are 100% cooper, made in old "plumber-brazing" style , but I've said mine client that that won't be anything special, and price is low . Of course they'll fit most of cards avalible on market, not only 5970 .
    They use 42mm diam/41mm tall cooper steeper core in base with some holes drilled . Containers have 42mm diameter and they're approx. 200mm tall .
    Mounting plate and backplate are stainless steel.
    Insulation is 19mm thick .
    That's photo together with mine CPU steeper cooper container .
    With Kindest Regards
    Peter
