Hello![]()
I want to show You Pudi's chiller built by me. It had been built after long talks and decision changes ...from chiller into Tt Mozart TX case, throught chill cased into lian-li V2000 and finally ...stand-alone cased chiller which will be standing under Lian-Li cube case.
Specs :
compressor: Danfoss SC18CL
heat exchanger: plate HX 12 plates
XV: Danfoss TS2 TXV + Frigomec 0.88l receiver
condensor: 1.5kW cooled by 4x 120mm/25mm Scythe SFLEX 1200 fans
refrigerant : R507+R134a
case: metal case 46 x 46 x 35 cm, black powder coating
others: electronic controller Dixell XR40C, 4x 120mm/25mm Scythe SFLEX 1200 fans on the back of case + 4x 120mm/25mm Scythe SFLEX 1200 fans on the front of case, Eheim 1048 pump into 1.7l reservoir, hoses inside chiller 12/16 mm .
Pictures hasn't been taken from start - I hadn't got digicam for some days.
And the party begin.
Upppsss - Pudi won't be happy seeing so much frost. Luckily system has digital controller
-26*C liquid without load.
i and +8*C on heater taking 605W from 230V socket.
Wanna some drink ?![]()
And after party .....
Regards
Peter
