Hi
It's simple dual evaporator unit, using one rotary compressor, and captubes as a expansion valves. No heat-exchangers. It has been made for some OC sesions (which are planned for future)
I've used one "CPU" evaporator + one "GPU" evaporator, to make possible using it on SLI configurations or as a CPU+GPU cooler (just by swap enclosure on "CPU" evap) .![]()
SPECS :
compressor: Daikin YZG-22RY1T1 (rotary)
evaps : piotres's custom CPU + custom made GPU evaps
expansion valves: 2* 0.8 mm captubes
condenser:2 row, alu-cu, cooled by 2* Sanyo 120mm fan + 2* NBM 120mm, all 4 for 12V
refrigerant: R410a & R507 blend
base: Chipboard baseplate 40 x 30 cm, painted matt black
others: High side gauge mounted on condensor's top
Braided suction lines, both around 100 cm long.
Suction sleeve with white stripe - I like it very much.
1st run ...sorry for not nice looking old insulation on suction accumulator.
No load final temperatures .
CPU evap 225W / GPU evap = 200W / Sum = 425 W
Around -33*C on both evaporators.
High side pressure with final charge during no load.
Regards
Peter
