Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: AIRCHILLER + Single-stage (worklog)
    -100c Club Member
    Mar 2005
    Poland
    Exclamation AIRCHILLER + Single-stage (worklog)
    Hi
    Mine next project - rather won't be boring like all 2 stagers - it'll be cooling chamber (to put inside mobo + all other stuff, except hdd and psu ) plus SS , all on one plate ...
    Specs :
    Compressor: two Danfoss SC18CL - one for airchiller, one for SS
    Evap for SS: Steeper 40mm tall/42 mm diam., enclosure for all newest CPUs, 1.0 meter braided DN10 suction line (with
    stainless steel mesh)
    Evap for airchiller : Evaporator from split A/C unit
    XV: captube 0.9 mm for SS, Alco TI-HW for airchiller
    Condensor: two 1.9 kW + 254 mm fans
    Refrigerants : R507 in both
    Case : custom made, welded frame, custom perfored side panels, all powdercoated on black color, wheels.
    Chamber :HARD moded Ladycook small fridge
    Others: Control panel on top of chamber (switches for both SS and airchiller, switch for PC), Danfoss controller for airchiller, Frigomec 0.88l receiver.
    Bone stock frigde ...brand new ... .
    Some reduction on parts used in frigde .
    Mine new welding machine- MIG/MAG Esab C250 3ph .
    Mine father helped me with welding a bit and later with grinding .
    That was only 4 fun ...just a try on trash piece of metal .
    Fridge got small accident and had must been painted ...so paint is fresh high gloss black acryl ).
    I decided to weld suction line holder for more safety .
    Clear coat this time also .
    First time I've must use ladder when I build cooling system .
    First tests, temperature inside chamber without any fans mounted.
    Here with two 120mm - nice gain .
    I was pumping hot air inside chamber from hairdrier working at 1st speed and taking over 700W energy - during 30min test temperature moved from -31*C (I've wait long, for lowest temperature) till -10 C - thermal probe was mounted in piece of cooper put inside chamber. It's not final .
    Some heavy piece of brass inside - that's tip from future owner of this unit to use big pieces of cooper (but I don't have it, only brass) as a "cold magazine" .
    Probe inside small cooper piece (don't have bigger ).
    That's what we should say "ARCTIC FAN" .
    That's loadtest of SS loop - make -40C@260W but I don't think that's most important part of this unit .
    Regards
    Peter
    I am Xtreme
    Dec 2003
    Omaha, NE
    Wow very impressive as usual piotres! I wonder if the board in the airchiller will be affected by condensation at all. I love -40 at that load on a SS. You are the chiller god!
    Thermaltake Xaser VI Case
    ASUS P7P55 Motherboard
    Intel i7 870
    AMD 4870X2
    8 gigs of OCZ Fatal1ty DDR3
    CoolIt Boreas 12 TEC CPU cooler
    Coolermaster UCP-1100W PSU
    Quote Originally Posted by {GOD}Raptor22
    I find it exceedingly humorous how you sit here and continue to play keyboard warrior even though you know you are wrong.
    Oct 2004
    Crazypc.ro
    Hi piotres,
    Just an ideea: the enclosure of the hole setup shoud be purged with CO2 or N2
    What about the hdd and dvdrw and psu, what are the plans?
    regards,
    q
    I am Xtreme
    Dec 2003
    Omaha, NE
    Its a refrigerator... I doubt that is has the sealing air tight capabilities to do so and when benching, to do anything you will have to vent the gas out. Won't be worth it. Just have to run it for a while before putting equipment in to ensure ample humidification. Probably worth setting up in a dehumidified room.
    Intel i7 870
    AMD 4870X2
    Xtreme Mentor
    Aug 2006
    Atlanta
    Love the work and attention to detail ... but am wondering how your going to condensation proof the mobo, psu, videocard ect...also wondering how it will perform with a hot video card inside and psu inside. I think my 4870x2 is much hotter than a blow drier...
    Cant wait to see it tested with live equipment its going to be very cool ... yes the PUN was intended
    Again wonderful work!!
    Never empower an idiot with a response....
    http://en.wikipedia.org/wiki/Troll_%28Internet%29
    Seller/Buyer Reputation:
    Heatware: http://www.heatware.com/eval.php?id=50905
    Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
    Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
    iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
    Aug 2003
    Finland-Oulu
    Since im getting this unit, i give some answers
    Quote Originally Posted by [cTx]biglipzit View Post
    Quote Originally Posted by sdumper View Post
    - Actually good fridges are airtight and reason why they get frost is because ppl will open and close fridge door. And if some reason it would not be airtight, i have some ideas in my pocket to make it air proof.
    - Unit is for daily use
    - Of condensation, i will use many silica gel moisture bags to remove moisture (eg one bag is capable remove moisture from 1..1.5 cubic meter of air). Basically i put parts inside (in dehumidified/very low moisture room) , tens of gel bags and then do several test runs (only compressors are turned on, not computer) and let bags to catch the moisture. No moisture, no condensation
    -4870X2 is far away from hairdryer, it produces about 300w heat. But even -45c air temprature, gpu's wont be below 0c under load, due air temp condictivity is bad...but freezer gives possibility to run 4870X2 fan very high rpm due lowers the incoming noise from fan, what normally is way too much
    -PSU,HDD,DVD will stay outside of system.
    -110c club
    May 2008
    by the LAMP!
    it looks great i must say but
    as for the frost
    our home fridge has a fan so one opened and closed the air is sucked out by the fan as if to create a vacuum in the case maybe you could do something like this?
    would be easy to set up just a fan with a rubber flap on the back so when the fans off the rubber flap seals it shut
    I LOVE LAMP!
    Mar 2005
    Norway
    Vacum are bad if you want the air to cool something down really.
    -100c Club Member
    Mar 2005
    Poland
    Please nottice that on few last picutres there is a lot of frost inside because I've been pumping hot air by hairdrier inside the chamber for 30 minutes .
    I am Xtreme
    Dec 2003
    Omaha, NE
    Quote Originally Posted by piotres View Post
    Oh yeah that would do it. I am sure it will work great, even for everyday use. Once it is setup and running there won't be much need to open the fridge. Should be pretty neat. Can't wait to see what performance will be like when it is all up and running with the PC inside.
    Keep us posted!
    Intel i7 870
    AMD 4870X2
    Oct 2004
    Crazypc.ro
    The fridge is air tight enought.
    I think will work fine just having a CO2 botle of say 2 liters, open it up and blast the enclosure, purge all air outside, when you set up the system or when u open up the door for dealing with the hardware...and u will have 0 humidity silicagel cant remove all water from air
    Aug 2003
    Finland-Oulu
    Quote Originally Posted by quintus View Post
    I think with silica gel packs i can remove most of water from air (i hope so), that rest is just so minor that it can't do any harm (we are talking 1~ gram).
    Of course if this method is not sufficient, then replacing air with co2 or nitrogen is only solution.
    -100c Club Member
    Mar 2005
    Poland
    Sorry pics should be working again tomorrow - I've reached limit for transfer for basic web account (3.4GB sucked from http in 12 days by You (mounthly limit is 3gb) - thanks a lot people :P - really I'm happy that so much people look at mine topics) so I must have upgrade for plus account which should be active tomorrow.
    Jun 2007
    Wilmington, NC
    Rock and Roll Peter. Keep up the great work. I look forward to seeing where this goes.
    -100c Club Member
    Mar 2005
    Poland
    More photos, unit is nearly finished :
    I've added 4 pcs of 80mm fans behind the evaporator - to mount them I had must cut hole in back of fridge which later I've covered with styrofoam and new cut piece of steel plate. I couldn't mount fans before evaporator because in that way motherboard with long GPUs can't be put inside chamber (too little space) .
    Testing Rig.
    Noloaded I've reached nearly -49.5C air temperature inside chamber (I haven't shooted that on photo, only -48.2C) .
    From that temperature I started load testing - pumping hot air throught 30 mintes produced by hairdrier (taking over 700W from 230V) by hole for cables on back of fridge .
    Big brass block (that round one) temperature after 30 minutes loadtest (remember - over 700W) .
    And same but measured by small cooper block .
    SS unloaded.
    SS loaded with 260W after 1 hour test .
    Now unit is standing for next 2-3 weeks for testing if it's leak free for sure (of course leak detector sprays haven't showed any leaks but I must be sure), after that - packing & shipping .
    Regards
    Peter
    -100c Club Member
    Mar 2005
    Poland
    Hello
    Unit is already 100% completed :
    Finaly, small cooper block after temperature (so also air temperature inside chamber) pumping hot air by hairdrier (30 min test) - start of test was from -43*C.
    Big brass block after same test .
    Then I start some real loadtests
    And that's all, unit is 93kg, total pack weight is 157 kg without palette . As You can see packing is heavy, but it must be heavy to be safe .
    Regards
    Peter
    May 2005
    POLAND/Cracow
    ladycook overclocking lol
    great job Peter
  18. #18
    -100c Club
    Jun 2005
    Slovenia, Europe
    1-5-7kg! :O
    Respect Peter!
  19. #19
    Xtreme Mentor
    Aug 2006
    Atlanta
    Nice house too...oh and yes the unit looks like its mass produced by a factory very very professional in appearance much respect!!
  20. #20
    Nov 2005
    Auckland, New Zealand
    Unit looks good but I suspect it will be a motherboard killer due to condensation.
  21. #21
    Feb 2009
    Athens - Hellas
    Congrats piotres this is a innovative construction
  22. #22
    (o.O)
    Jun 2008
    Ohio
    that is awesome, i love seeing *inside the box thinking
    Intel Core 2 Quad Q9450 Yorkfield @ 3.2GHz | Asus P5Q Deluxe mobo | 2x OCZ Reaper HPC 4GB (2 x 2GB) DDR2 1066 (PC2 8500) | Sapphire 4870x2 | Western Digital VelociRaptor 300GB 10k RPM | Intel 120GB SSD | Western Digital Caviar SE16 640GB 7200 RPM | Hitachi 2TB 7200 RPM | PCP&C 750W Power Supply |Cooler Master HAF932 | Windows 7 64-bit | Dell ULTRASHARP 2408WFP 24-inch Widescreen Flat Panel Monitor
    Join Us in the XS World Community Grid Forum & Help Fight Cancer and Other Diseases
  23. #23
    Dec 2007
    San Francisco
    Very great looking and innovative system there Piotres
    And to Rise: Condensation will not be an issue I'd imagine. Most would form on the evap anyways. And the Silica will get it out of the air pretty well.
    e8600: 6261 mhz (LN2)
    e8500: 5830 mhz (dice)
    Quote Originally Posted by xaxis View Post
    It's really unfeasible, unpractical, and for all intensive purposes... SHOULD NONE THE LESS BE ATTEMPTED!
  24. #24
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    Wow you do great work, love the ladder to access the project.
    I just love innovation, and that's what you keep pumping out,
    Top NOtch!
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
  25. #25
    Aug 2003
    Finland-Oulu
    Okay, After months of tuning & testing finally so small results available of this cooler. Currently bit different look of cooler
    Added sound insulation and rerouted aircirculation inside of compressors, eg air is doing S loops before getting out and walls are insulated with bitium + softcells. Currenly doing 55-60db from 2m away (using iphone as meter :P)
    Also controlbox added quickswitch for resetting cmos..eg holding switch does reset. The fridge door is sealed with silicon and havind side bolt+screw lock system that door is not opened by accidently.
    Before closing door:
    Air inside is circulating from behind blowed with fans end of fridge (door), and there is goes behind mobo (eg where all wires are) back to evap.
    Small results with set to keep air 0+ to -15c ...takes 15mins to cool down and 10mins to cool back to -15c.
    Result after running 30mins of 3Dmark03 NatureTest
    idle
    And finally, the myth of condensation, does it exsist? Simply no..i have opened door during run, no water visible and during run haven't have any symptons of condensation failures so far.
    In future pushing more cold (-40c) and see what happens
