XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel > Intel Info And Support
Reply
Old 02-12-2007, 08:42 PM   #1
NickS
I am Xtreme
NickS's Avatar
The Ultimate Core 2 Duo Guide: Chipsets, Guides, Links, and more!
Intel P35 Chipset
  • Great overclocker. 500-600MHz FSB easy on a good board w/Dual, mid-high 400's with quad. I think I saw one 500FSB shot on a quad with a DFI board a while back.
  • Supports Crossfire
  • PCI-E 1.1
  • Clocks RAM well if you have the high FSB to back it up.
  • Runs warm!
  • Generally a prime choice for any CPU/RAM/GPU combo. Great bang for buck performance.
  • Get P35 over X38 if you don't plan on going Crossfire.
  • Has extremely fast Matrix RAID
  • Supports DDR3
  • Good performance clock-for-clock - close to X38, better than 680/780i
  • The best boards to get now are the Foxconn Mars, DFI P35 Lanparty series, Abit IP35 series, MSI P35 Neo2-FR or Platinum.
Intel X38/48 Chipset
  • Great Overclocker: 500-600FSB usually, on dual core. Expect 400-480 on quad, maybe a bit more if you got a really good board/CPU.
  • Ability to run Crossfire w/full bandwidth slots.
  • PCI-E 2.0
  • Runs very warm, TDP is high.
  • Best for benching with Crossfire, Pi, etc.
  • Best clock-for-clock performance.
  • The two boards to get on this chipset are the Intel BadAxe2 (XBX2) and the Abit AW9D-Max. They both do the highest FSB out of all of them, out of the box and usually provide the most stable computing environment with the best OC.
  • Supports DDR3.
  • Best boards seem to be the ASUS Maximus Formula, Abit X38 QuadGT
NVIDIA 780/790i Chipset
  • Good overclocker, seen 550+ MHz FSB out of it so far on a dual. Seems to top around mid-high 400's for quads still. Not much info as of yet.
  • Runs very warm. (Hottest out of these four chipsets)
  • Good for all chips generally.
  • Your only choice for NVIDIA SLI.
  • PCI-E 2.0
  • Supports 3x SLI aka Tri-SLI.
  • [Slow RAID.
  • Ability to run memory @ any speed you want.
  • Takes a considerable amount of tweaking for it to be even be considered usable for competitive benchmarking (CPU wise)
  • Supports DDR3 (790i)
  • Not much info on these boards yet, but more will be added. As of now though, they do seem pretty buggy from what I've read. More so than 680i in most cases.
Temp Threads: Threads that contain useful info that pertains to the "now," and will be outdated quickly (such as a batch of new BIOS' or something.)For more information, these threads may be of assistance..
Motherboard Specific Threads
....ASUS Threads
....Giga-Byte Threads
....Abit Threads
....DFI Threads....680i Threads
....780i Threads
....MSI Board Threads
....Misc Board Threads
I hope you all like this little guide, feel free to post input to add for the chipsets! I'm open to it! I'll try and edit+add daily.
__________________
C2D E7200 @ 3.6GHz, 1.31v
Stock Q6600 HS/F
MSI P45 Neo3-FR
G.Skill 4GBPQ 8000's
Sapphire HD3870 Toxic 512MB
WD3200AAKS Single Platter
Enermax Liberty 500w
X-Fi XtremeMusic
CoolerMaster CM590
Vista Home Prem. X64 SP1
Westinghouse L2410NM
Logitech MX500, Saitek Eclipse, Logitech G25
NickS is offline   Reply With Quote
Old 02-12-2007, 08:49 PM   #2
jt710
and on the fifth day, god said, "Let there be Sticky"
and it was good.
thanks!
__________________
JT || E6400 @ 3.2 || p5B deluxe w/ 1004bios || G.Skill HZ|| XFI Gamer 7.1 || OCZ Gamestream 600W || XFX 7900 GS || Antec 900 w/ TuniqTower
jt710 is offline   Reply With Quote
Old 02-12-2007, 10:27 PM   #3
virtualrain
Good stuff NickS... Hope mods sticky this.
Some suggested additions...
- How about adding quad core FSB results with various chipsets? That's a more common question these days.
- Oskar (DFI BIOS engineer) reported on the new DFI Club forums that 680i chipset overclocking varied widely depending on the particular silicon. The implication was that overclocking 680i might be highly dependent on luck.
- There is also some issue with RAID on reference 680i boards (at least) which is being discussed here... http://www.xtremesystems.org/forums/...d.php?t=128803
virtualrain is offline   Reply With Quote
Old 02-12-2007, 10:40 PM   #4
Shaolin3a
Good information and links. Will be referring to this often. Vote for sticky here as well!
Shaolin3a is offline   Reply With Quote
Old 02-12-2007, 10:42 PM   #5
m0da
m0da's Avatar
Send a message via AIM to m0da
STICKY+1
this is an amazing compilation nice job!
virtualrain has some good suggestions as well.
__________________
m0da is offline   Reply With Quote
Old 02-13-2007, 12:35 AM   #6
mr_knowitall15
mr_knowitall15's Avatar
STICKY THIS!!!! And then ban anyone who starts another what mobo thread once this has been stickied!
__________________
"Roses are FF0000, Violets are 0000FF, All my base are belong to you."
Intel Badaxe2
Core 2 Duo E6600@411x9=3.7Ghz
2x1GB Corsair Dominaor 8500C5
Evga 8800GTS-320
X-Fi Platinum
2 Seagate 320Gig 7200.10s
PCP&C 750W Silencer Quad
TT Armor Case with 25cm Fan.
mr_knowitall15 is offline   Reply With Quote
Old 02-13-2007, 12:37 AM   #7
adamsleath
Xtreme Guru
adamsleath's Avatar
yeah thats wot i was thinking...
btw setting all voltages [except vcore,ram] to "auto" worked a treat for me
__________________
q9550@3.75GHz|GTX295[SOLD]|4x2GBDDR2|P5Q-Pro|640GB WD X2|Vista 32+64 dual boot|BenQ G2420
adamsleath is offline   Reply With Quote
Old 02-13-2007, 05:42 AM   #8
PanteraGSTK
Xtreme Cruncher
PanteraGSTK's Avatar
Now this this thread would have been nice to have before I asked...I just wish I could buy them all and do a direct comparison of how high the fsb will go, memory flexability, RAID performance...everything. That way I won't have to ask what to get, I can buy them all and decide which one is best for me....Whatever happened to motherboard comparisons and chipset compairisons? I haven't seen a GOOD one in a long time.
__________________
gone: Asus P5N-E SLI 650i 0505 BIOS
gone: Gigabyte S3, rev C1, F7 BIOS
gone: G.Skill 512mbx2 6400hz @ 500mhz 2.35v 4-4-3-5
gone: Evga 7600GTS @ 600mhz core and 1600mhz
E6300 @ 3500mhz 1.495v
2x1gb crucial ballistix tracer 8500 @500mhz 4-4-4-12 2.2v
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
Scythe Infinity 2X Kingwin 80cfm 120mm fans
other irrelevant crap.
100% OC
Max OC on my crappy S3 1.8v vcore DICE cooling
Come crunch with us. Click me to find out more.
PanteraGSTK is offline   Reply With Quote
Old 02-13-2007, 05:59 AM   #9
dinos22
...you two characters
dinos22's Avatar
Nick that info about 680i is redundant about bugs
Has some pretty serious bugs, data corruption and a few others IIRC.
that's been solved with bios updates
i do think that SuperPI performance is lower than 965/975 though ...they are yet to fix that....i've asked for some extra memory timings in bios but no word yet
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 02-13-2007, 06:05 AM   #10
PanteraGSTK
Xtreme Cruncher
What about the VERY slow RAID on the 680i?
__________________
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
100% OC
Old 02-13-2007, 06:07 AM   #11
dinos22
dinos22's Avatar
HD tech but if you actually bother to test in real life you will find out that it doesn't stand out form the pack
none of these motherboards have true raid controllers people don't full yourselves with those gimmicks....if you want a proper raid controller go get a LSI card or something similar
__________________
Team.AU
Got tube?
Old 02-13-2007, 06:11 AM   #12
PanteraGSTK
Xtreme Cruncher
I've always wondered if on-board RAID was worth it. I've ONLY used add-in cards and have never been dissapointed...
EDIT: I forgot. I had an Epox withthe 760 amd chipset that had a Promise controller. It lasted a whole month before corrupting all of my data in RAID 0 so RAID and me are not friends. I guess thats whay I'd like to give it another go.
__________________
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
100% OC
Old 02-13-2007, 06:15 AM   #13
GrimReaper
GrimReaper's Avatar
awesome Make this a sticky
__________________
"WW3 will be fought with nukes, WW4 will be fought with rocks!":
GrimReaper is offline   Reply With Quote
Old 02-13-2007, 06:24 AM   #14
PanteraGSTK
Xtreme Cruncher
I looked at LSI and Areca cards. I don't think I will be buying a RAID card that costs more than my motherboard. I know they are good, but crap thats expensive. Any recomendations on a CHEAPER reliable RAID 0 card? Sorry I can't stop asking questions, but I don't like on-line reviews for the most part and you guys have more experience on this site than anywhere else I've been so thanks.
__________________
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
100% OC
Old 02-13-2007, 06:53 AM   #15
shimmishim
shimmishim's Avatar
Send a message via AIM to shimmishim Send a message via Yahoo to shimmishim
in teh intel 975x section when you say it can take a lot of volts (2.1+), i assume you're referring to the chipset voltage. is this correct?
__________________
Main Rig:
CPU Intel E8400 Q816A @ 4250MHZ
Mobo Asus Maximus Formula
Memory 2x2GB G.Skill PC-8000 4GBPQ
Video Cards Galaxy 8800GT
PSU Silverstone ST75F Strider 750W
Hard Drive Maxtor 7200.10 (Seagate rebadged) 320GB SATA | WD 2x36.7GB Raptors in RAID 0
Cooling D-tek FuZion | Swiftech MCP655 | Thermochill PA120.2 | 4 Yate Loon D12SM 120MM
9.89s 9min59.078s
shimmishim is offline   Reply With Quote
Old 02-13-2007, 07:09 AM   #16
p0tter
p0tter's Avatar
Great post Nick, Sticky!
Id recommending updating with some very basic C2D cpu info.
i.e. multi, FSB, stock clock speed (maybe steppings, but that can get wild).
__________________
Asus P7P55D Pro
•Intel i5 750 @ 3.8 (181x21 @ 1.35v)
•G.Skill 12800CL7D-4GBRH²
•XFX HD-587A-ZNF9 Radeon HD 5870
•Windows 7 64 Ultimate
•Dell 3007WFP
p0tter is offline   Reply With Quote
Old 02-13-2007, 07:57 AM   #17
xoqolatl
Thrusters on full!
xoqolatl's Avatar
Send a message via MSN to xoqolatl
NVIDIA 680i Chipset
(...)Runs kinda warm, per norm. with NVIDIA chipsets.
Kinda warm? it's hot like the deepest deep of hell! I burnt my finger once with NB heatsink.
Lapped Core 2 Duo IHS Pictures - A little gallery of peoples' lapped Core 2's. Has some neat tips/tricks in it.
Would that be about my n00b observations to lapping? thanks very much!
__________________
Originally Posted by miahallen View Post
FurMark is a waste of time.....it's not ranked on HWBot
W3520 on Rampage II Gene | hardmounted TRUE + 2x 120mm push-pull | 3x 2gig of HCF0
Zombie GTX280 | look mom, i has no IHS | Thermalright HR-03 GT
Lian-Li PC-A70B | Brushed aluminium tank
MOA 2009 Poland #2
Test bench: Clarkdale, several AMD Confidentials
xoqolatl is online now   Reply With Quote
Old 02-13-2007, 10:40 AM   #18
kiwi
Xtreme
kiwi's Avatar
Send a message via MSN to kiwi Send a message via Skype™ to kiwi
965 is not fairly cool, you can almost boil eggs on heatsink
__________________
kiwi is offline   Reply With Quote
Old 02-13-2007, 01:03 PM   #19
PanteraGSTK
Xtreme Cruncher
This is a great comparison between chipsets.
__________________
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
100% OC
Old 02-13-2007, 02:20 PM   #20
crazyea
crazyea's Avatar
I'm not sure about this as I tested a little higher on my evga 680i then on my p5w dh deluxe using the same stripe size and hard drives.
__________________
| eVga x58 3x Sli | i7 920 w/ Ultra 120 Extreme | Radeon HD 5850 |
| 6x1GB Aenon DDR3-1600 | WD6401AALS | Antec Sonata III w/ 500w |
crazyea is offline   Reply With Quote
Old 02-13-2007, 02:22 PM   #21
crazyea
crazyea's Avatar
The p5w dh has hardware raid built in. Is that not true raid?
__________________
Old 02-13-2007, 02:27 PM   #22
Wiggy McShades
Wiggy McShades's Avatar
no mention of the quad GT? right now its the best performing 965 board.
edit: other wise pretty sweet job
__________________
Wiggy McShades is online now   Reply With Quote
Old 02-13-2007, 02:40 PM   #23
NickS
I am Xtreme
NickS's Avatar
Added: Mention of QuadGT under 965 Chipsets
__________________
Stock Q6600 HS/F
MSI P45 Neo3-FR
X-Fi XtremeMusic
CoolerMaster CM590
Old 02-13-2007, 03:03 PM   #24
dinos22
dinos22's Avatar
just looked it up it seems that the spec mentions Silicon Image 4723 Hardware RAID controller which seems to be a two port eSata controller so you probably can't use it with internal drives. i can't find any writeups comparing that controller to the other ones on the mobo...intel and jmicro.....
__________________
Team.AU
Got tube?
Old 02-13-2007, 03:23 PM   #25
crazyea
crazyea's Avatar
no, the j micro is esata. the silicon is hardware raid for internal drives.
In the following picture the orage sata ports are for the asus ez-backup (hardware raid) which can be configure as raid 0, 1, or big via jumper.
http://www.pbase.com/eltonandersen/image/74197662
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
