XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 02-01-2007, 05:31 PM   #1
pauldovi
QuadGT Arrived (56k warning)
QuadGT arrived today:
Removing the NB heatsink, cleaning it, and replacing it with AS5:
Seating the CPU and placing AS5 on it:
System put together, light show:
Basic BIOS Page
Wow... The LCD display is so cool. It has a ton of commands which is displays as it does POST and boot. You can see exactly what the BIOS is doing and if it fails what it was doing when it failed.
For example:
C1: Detect Memory: Detect DRAM size, type and ECC
1F: Load keyboard matrix
23: Check validity of RTC value
50: Initialize USB
FF: Boot Attempt
Very cool!
Windows is currently being installed. Then drivers and BIOS files. After that I will let her lose!
__________________
Q6600 G0 - 4870 512MB - 4GB DDR3-1600 - GA-EP45-DS3R - 2 x 7200.10 RAID 0 - OP650
pauldovi is offline   Reply With Quote
Old 02-01-2007, 06:00 PM   #2
newls1
Xtreme Cruncher
newls1's Avatar
Send a message via AIM to newls1
Looks great, have fun with it!
__________________
No more PC, damn economy
02 Tahoe with a *NICE* stereo! Soon to be:
2 300a alts, 4 AQ2200D amps, AQ90x4 amp, 4 18" AQ HDC3A's (2200RMS Watts each) multi batts in rear all G31's, MLA 15.4v module, etc.... Nearing 10,000watts
newls1 is offline   Reply With Quote
Old 02-01-2007, 06:03 PM   #3
PcCI2iminal
Xtreme Family
PcCI2iminal's Avatar
very nice
im waiting for numbers
__________________
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar X58A - 920~Gulf - G.SKILL2000CL8 - GTS250 - Hitachi 40gb 7200 - Giga-EZ 1000w
Kids
P4GD1 - Pentium M 740 - XMS Xpert400 - Gladiac 7900GTX - Raptor 36GB - Aopen 560w
PcCI2iminal is offline   Reply With Quote
Old 02-01-2007, 06:08 PM   #4
pauldovi
Windows just installed. Getting drivers up and running.
__________________
Old 02-01-2007, 06:53 PM   #5
pauldovi
First results:
CPU @ 1.50V, NB @ 1.60V, Memory @ 2.3V
__________________
Old 02-01-2007, 07:04 PM   #6
Ajfina
Ajfina's Avatar
very nice board , i got mine yesterday, like it a lot, just hate my memorys cant test the full potential for now until i recieve the new memorys i order, so far pretty good
__________________
[/size][/color]
Originally Posted by Evanesco
The Chineese New Year isnt an excuse!
Ajfina is offline   Reply With Quote
Old 02-01-2007, 07:21 PM   #7
pauldovi
Can't budge 444Mhz FSB. I can't increase the memory passed 1:1 either (@ 444Mhz FSB)
__________________
Old 02-01-2007, 07:30 PM   #8
MrDeeds
MrDeeds's Avatar
Nice nice nice. Even though i went commando im still considering purchasing this board also. The reason i stopped short was because i wanted to see the boards potential at overclocking memory.
My Aw9d-max couldnt get above Ddr-900 without ridiculous voltage so i wanted to make sure abit got their act together.
You may want to try the new beta bios. You can find it on abits forums.
__________________
Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
Originally Posted by chron
Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
MrDeeds is offline   Reply With Quote
Old 02-01-2007, 07:31 PM   #9
pauldovi
Doesn't seem to do to well with high memory speeds. Probably because of the 1066Mhz strap. But the 1T can help.
__________________
Old 02-01-2007, 07:51 PM   #10
Ajfina
Ajfina's Avatar
the board have some issues with high memory settings, but no that bad below 1100
from anantech
We take a look now at seeing how well our GEIL PC2-6400 memory operates in this board in both two and four DIMM testing. The screenshot above shows the actual memory settings used in our benchmark tests of the board. We do not modify the memory timings beyond the four major settings in our charts. The balance of memory settings are implemented automatically via the BIOS. abit implements slightly tighter memory and MCH timings than some of the other P965 boards we have tested.
abit AB9 QuadGT
Stable DDR2-800 Timings - 2 DIMMs
(2/4 slots populated - 1 Dual-Channel Bank)
Clock Speed: 800MHz
CAS Latency: 3
RAS to CAS Delay: 3
RAS Precharge: 3
RAS Cycle Time: 9
Voltage: 2.20V
We were able to set our timings to 3-3-3-9 by increasing the memory voltage to 2.20V with our GEIL memory. We were able to hold these timings up to DDR2-880 on this board before switching over to timings of 4-4-4-12 up to DDR2-1030 at 1:1 timings. We then switched to 5-5-5-15 timings at a 7x465 with a 4:5 ratio that resulted in a maximum stable memory speed of DDR2-1163. We tried out our Corsair Dominator PC-8888 and OCZ Flex XT memory but could not get the board stable at memory speeds greater than DDR2-1163.
abit AB9 QuadGT
Stable DDR2-800 Timings - 4 DIMMs
(4/4 slots populated - 2 Dual-Channel Bank)
Clock Speed: 800MHz
CAS Latency: 3
RAS to CAS Delay: 4
RAS Precharge: 4
RAS Cycle Time: 12
Voltage: 2.275V
Our settings of 3-4-4-12 at 2.275V were not quite as good as our ASUS P5B-E 1.02G settings of 3-4-3-10, but due to fairly tight memory timings elsewhere the benchmark results were actually better. We were able to keep this setting up to DDR2-860 before switching over to 4-4-4-12 settings that held stable until we reached DDR2-960 during our overclocking tests. The board was able to handle settings of 5-4-4-12 up to DDR2-1010. Our final settings of 5-5-4-15 at DDR2-1030 required a voltage increase to 2.325V.
__________________
[/size][/color]
Old 02-01-2007, 07:53 PM   #11
pauldovi
I think BIOS releases will help the memory a lot.
__________________
Old 02-02-2007, 12:24 PM   #12
JoeBar
Xtreme Mentor
JoeBar's Avatar
4:5 issues? Hope this will be resolved otherwise it will make this board a
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 02-02-2007, 02:54 PM   #13
Ajfina
Ajfina's Avatar
havent try 4:5 yet , need better memory(waiting for them)
__________________
[/size][/color]
Old 02-02-2007, 03:28 PM   #14
Millyons
Millyons's Avatar
hows the NB cooling after putin on the AS5...is it adequate enough...is that nb/pwm cooling real coper?
Millyons is offline   Reply With Quote
Old 02-02-2007, 10:18 PM   #15
pauldovi
With a 120mm fan over the NB / Memory / CPU socket the NB is at 35C and the PWMs are between 40-44C during full load after about 12 hours. Abient is 24C
__________________
Old 02-03-2007, 12:45 PM   #16
nightic
Abit QuadGT - E6600 @ 3.5GHz - 9 x 389
1:1 389 4-4-4-10
1066 strap
Super Pi mod 1.5 - 32M - 14m 34.532s
Abit QuadGT - E6600 @ 3.5GHz - 8 x 437
1:1 437 4-4-4-10
1066 strap
Super Pi mod 1.5 - 32M - 14m 18.094s
Abit QuadGT - E6600 @ 3.5GHz - 7 x 500
1:1 500 4-4-4-10
1066 strap
Super Pi mod 1.5 - 32M - 13m 56.515s
1:1 389 3-3-3-10
1066 strap
Super Pi mod 1.5 - 32M - 15m 12.985s
1:1 437 3-3-3-10
1066 strap
Super Pi mod 1.5 - 32M - 14m 57.297s
4:5 486 4-4-4-10
1066 strap
Super Pi mod 1.5 - 32M - 14m 01.890s
nightic is offline   Reply With Quote
Old 02-05-2007, 02:31 AM   #17
GrossmeisterB
Send a message via ICQ to GrossmeisterB
How did you measure "NB temp"??
And did you put AS5 underneath the "OTES"-cooler as well? To get better contact to the PWM regulators?? My PWM-regulators are getting very hot (like 75°C under heavy load and high Vcore, even with a 120mm blowing over CPU area... )
__________________
GrossmeisterB is offline   Reply With Quote
Old 02-05-2007, 03:01 AM   #18
fgw
fgw's Avatar
would be interesting to me too. is there a sensor near by?
from what i have read, the digital pwm's could get verry hot. 75c would be a rather usual temp under load. wouldn't care too much about this temps ...
i have put as5 under the heatsinks of the pwm's on my aw9d-max. couldn't see a real difference in temps. but on the other hand, it won't hurt either ...
__________________
Processor: Intel Core 2 Duo E6400 SL9S9 3200MHz (400x8) - E8600 SLB9L waiting on my desk
Motherboard: AB9QuadGT Bios=17 | Vcore=1,4475V | VDDR2=2.0V (everything else at default)
Memory: Muskin XP2-8500 Ascent (2x2GB) 400MHz
Video Card: Inno3D 8800GTS (G92)
Power Supply: Seasonic S12 650W
Case: Chieftec BH-01B-B-B
Watercooling: Laing DDC XSPC Top| Heatkiller CPU / NB / GPU | Black Ice GTS 360 / 3 Scythe S-Flex SFF21E 700rpm pull with custom shroud
Temps: 34C Idle | 53C Peak Load | 26C Ambient
fgw is offline   Reply With Quote
Old 02-05-2007, 04:29 AM   #19
GrossmeisterB
Thanks for the info!
There is no sensor on the NB, only a "system" temp somewhere on the board showing "in case temp"...
Maybe he used an external measurement?
And I'm not sure about the high PWM temp, without any fan and "high" load drawn from the CPU, they get very hot and the system will crash, I think the cooling wasn't designed for that extreme overclocking, but with a 120mm fan over that area, it works just fine...
I think I will have to do some more tests etc...I don't want to mod my board (because of the warranty), and if it's just a "little" decrease in temperature, I don't care that much...
__________________
Old 02-05-2007, 11:29 AM   #20
Eclipse3EB
Send a message via AIM to Eclipse3EB
Make sure that the VRM heatsink is properly touching the VRM's after AS5. When I did mine using the "thinnest layer possible" principle of thermal paste application, I noticed my VRM temps shoot up to 160C at load, then my system would crash. I removed the heatsink and noticed that there was absolutely NO contact.
I guess there's a reason the brown stuff that comes stock on the heatsink is so thick. Anyways, I fixed it by globbing on a lot more thermal paste so now there's at least a little bit of contact. My load temps (at stock voltage) is about 70C now.
__________________
Processor: Intel Core 2 Extreme QX6700 @3.477Ghz (267x13)
Motherboard: AB9 QuadGT | VCore = 1.4775V (1.38@Load) | Vdimm = 2.0V
Memory: OCZ PC2-6400 (2x1GB) @400MHz / 4-4-4-15
Video Card: PNY 8800 GTS @500/800MHz
Power Supply: Thermaltake Toughpower 700W
Case: Antec P160W w/ 2x Yate Loon D12SL-12 LED @ 1200rpm
CPU-Cooling: Zalman CNPS9700 LED @ 1200rpm
Temps: 45C Idle | 84C Load | 20C Ambient
Eclipse3EB is offline   Reply With Quote
Old 02-05-2007, 11:42 AM   #21
situman
Xtreme Mentor
situman's Avatar
Send a message via AIM to situman
so any quirky behaviors with the beta bios? For example, mouse/kb not working. CD roms disappearing. Board boots weird...?
__________________
Asus Rampage Formula X48
Intel Q9650 @ 4.33GHZ
OCZ Platinum DDR2-800
Palit 4870x2
Creative Xi-Fi Extreme Music
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
situman is offline   Reply With Quote
Old 02-05-2007, 11:59 AM   #22
Revv23
I am Xtreme
Revv23's Avatar
Send a message via AIM to Revv23
I want this board, i have been dieing for a 1066 board... but its so buggy!!!
If abit would get on thier bios support it would be the best board out IMO.
It would be amazing if they got 1t working too...
Revv23 is offline   Reply With Quote
Old 02-05-2007, 12:21 PM   #23
pauldovi
I had thought that system temperatures were the NB temperatures... I guess not.
I did not put any AS5 or change the cooling method on the PWM. Someone had mentioned that the AS5 can induce a electric field on the PWM affecting its performance. IDK....
DVD drive disappears sometimes. Same thing happened on the P5B Dlx... strange. The 1T times down work very well at high Mhz. Could use a 1333Mhz strap. Other than that, BIOS isn't bad. It isn't great either.
__________________
Old 02-05-2007, 01:10 PM   #24
fgw
fgw's Avatar
i don't have the quad yet, but i use an w9d-max. the system temp on the aw9d-max is read from a temp sensor located on the motherboard but definitely not near the nb! may be the 965 chipset has a temp sensor built in, but i doubt its displayed as system temperatur!
if interested, have a look at the aw9d system temp sensor here, post #11 and post #12:
http://forum.abit-usa.com/showthread...=118264&page=2
i think the bad temp readings after replacing the stock tim with as5 comes from uneven contact surface between the pwm's and the heatsink. this is a known problem at some other boards. don't know if the quad is effected too. would be best to check before applying as5 and reinstalling the heatsink.
don't see any benefit in using 1T and at the same time switching to 1333 strap introducing higher latencies.
__________________
Old 02-05-2007, 01:11 PM   #25
situman
Xtreme Mentor
situman's Avatar
anyone else seen any other issues? Very interested in this board.
__________________
Palit 4870x2
Corsair HX1000
LL 343B Case
Thermochill 120.3
2xMCP355
KL 350AT
KL 4870X2 FC WB
DD Chipset Block
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
