Page 1 of 205 12341151101 ... LastLast
Results 1 to 25 of 5113
Thread: ASUS P5B-Deluxe; Problems & Fixes
    Aug 2006
    It seems that a thread similar to the P5W-DH one is needed for us P5B-D owners. There are many threads littered in this subforum and many replies to threads in the Overclocking subforum which contain a ton of information on problems and possible resolutions for various uses of the P5B-D, mainly overclocking. I think it would prove useful for many people to have this information consolidated and verified so that users may better troubleshoot issues they are having.
    This thread might start a little small, as I don't have a ton of time right now to add to it, but I will try and get the ball rolling. I'll try and keep it up to date with good information. To help contribute to this thread, please reply with an an issue your are having. If you have any contributions to make with support and fixes, it would be greatly appreciated. If you are going to make a reply, please do so in an organized fashion. For example, please post your system specifications and configuration in your post, to minimize confusion and misinformation. You should include:
    • Processor:
    • Bios Revision:
    • Memory:
    • Configured Voltages: vCore, vFSB, vNB, etc.
    • Configured FSB:
    • Configured Ratio:
    • Configured Memory Timings:
    • Any other applicable configuration modifications:
    I will lead with an example as the first reply, as I am also currently experiencing an issue, but for now, read on. I hope my post count doesn't scare anyone away.
    Bios Revisions:
    The currently listed bios revision on the Asus support website is 0614. This version, and other releases may be found via FTP @ ftp://dlsvr01.asus.com/pub/ASUS/mb/socket775/. Beta bios revisions are also available if you know where to find them.
    -- Bios Revision Functionality
    Any bios revision after 0502 (I believe) had Multiplier Downscaling available in the CPU Configuration section of the bios.
    Currently, it appears that the bios revision 0507 has divider issues with certain memory. As well, bios revision 0502, though apparently free of the divider issue, has memory timing problems with certain modules.
    Overclocking
    Generally, from what I can decipher (which may not be correct), is that most of Allendales and Conroes are fully capable of an FSB between 350 and 400. It would seem to me that more often that not, barring any other complications, these processory are capable of that mark. As well, it has appeared that mostly, that FSB point can be reached with modest increases in core voltage and modest aftermarket air cooling. That said, most of the problems are coming from various motherboard and/or memory related instabilities and misconfiguration.
    -- Bios Settings Screenshots ADDED: 09/15/06
    Check out this thread for a good start on what you should have your bios settings set to for starting your overclocking.
    -- Complete Failure to go Past 280-300 FSB using 0507
    Please remember that in 0507, there appears to be a divider issue with certain memory. Check and make sure that your are not currently running your memory with a divider, and if your are, try it without. If you must use a divider, downgrade your bios to 0502.
    -- Multiplier Fluctuation
    This is a commonly overlooked detail by those jumping in to the P5B-D. By default, The P5B-D bios revisions enable settings in the CPU Configuration of your bios that dynamically adjust the multiplier of your processory to conserve heat and energy. You can disable it by disabling the C1E and SpeedStepping options.
    General Performance
    -- "Chassis Intruded!" Message; CMOS-Clear and Chassis Intrusion Jumpers ADDED: 08/24/06
    If you are getting a "Chassis Intruded!" message upon trying to boot, you will be unable to do anything whatsoever. As reported, to fix this, you must clear CMOS via an on-board jumper. Refer to your manual and locate the jumper, and be very careful, as the Chassis Intrusion jumper is right next to it. -- [Credit: anarinsk]
    -- Double-restarts, Power fluctuations, Fake-restarts, etc. ADDED: 08/24/06
    Many users are experiencing a supposed problem in which cold booting or rebooting the system will trigger an immediate reboot after the initial one occurs. It is not known whether or not this is something that is user-generated or not, though some users have reported it occuring at stock, right out of the box. It is also not know whether this could be detrimental in any way to the user's system.
    -- Default vDimm and Higher Rated Memory Voltages ADDED: 08/24/06
    By default, all bios revisions (I believe) will have the memory voltage at 1.8v. This may cause an issue with some memory that is rated for 2.0v-2.1v or higher. Some users have experienced success using 2.0v or 2.1v modules at stock and then changing the vDimm on the bois, while others have not. Generally, the best way to combat this problem is to find a stick of memory that's rated at 1.8v-1.9v and boot with it. Once that's accomplished you can alter the vDimm in the bios to a bootable level for your other memory.
    -- Wifi-AP Functionality and WXP 64-bit ADDED: 08/22/06
    If you are experiencing wireless connection issues using Windows XP 64-bit (and quite possibly 32-bit) and the P5B-D Wifi-AP Card/Antenna, try downloading the driver from the Asus Support Website. Download the same exact driver as is on the CD, the only difference is, the driver is unsigned, and Windows will need confirmation before continuin the install an unsigned driver. -- [Credit: dissident]
    -- PLL for ClockGen ADDED: 09/15/06
    Firstly, you'll need the beta version of ClockGen that adds support for the P5B-D. In the PLL setup section, choose CY28551 (it shouldn't automatically detect it).
    Modifications
    -- vDimm, vMCH, and vDroop
    The third post from the top in http://www.xtremesystems.org/forums/...=110121&page=5 illustrates the mods pretty well. I couldn't locate a post detailing the process, but I'll update this section with it if I can find a guide for it.
    09/15/06 Edit: Sorry for the absence to this thread, I've been busy lately with school. I'll try and keep checking it and adding helpful things.
    Aug 2006
    • Processor: e6400, Allendale
    • Bios Revision: 0507
    • Memory: Corsair XMS2 PC2-6400, 2x1GB, Rated @ 5-5-5-12; TWIN2X2048-6400
    • vCore: 1.250
    • vFSB: 1.300
    • vNB: 1.250
    • vMem: 2.000
    • Configured FSB: 400
    • Configured Ratio: 7
    • Configured Memory Timings: 5-5-5-12
    • C1E and SpeedStep off, Locked PCI Express Frequency locked at 100, PCI Sync Mode at 33.33.
    Firstly, since I'm using 0507, I was unable to boot in to Windows past 290 FSB using a divider. From 290 FSB though, I went straight to 400 FSB running 1:1 and it booted in to windows fine. Using Core Temp, my temperatures read at idle ~42C. Under dual prime load, ~51C. Dual prime immediately errors out using any memory tests, but I using small ffts, I was able to achieve a 4 hour stable run. I'm not quite sure if I should up the memory voltage a little more, as the Corsair sticks are rated for the configured speed at 1.9V. When I get off work I'm going to try to move the multiplier to 8 and see what vCore is required to remain stable.
    Jan 2006
    Fl
    Sticky please........
    E6750 G0 POS!
    GA-P35-DS4 Rev. 2.0
    Visiontek HD4870
    Maxtor SATA 160
    OCZ Reaper 2x2 1066
    X-Fi Fatality XG Pro
    Tsunami Dream/Thermaltake TP650
    Mar 2006
    Europe - Black Forest - Celtic Area
    oh ...yes
    good job
    Der Freyheitsmuth, der von dort herueberwehte nach Deutschland, hat freylich hie und da die Nachtlichter umgeworfen, so dass die rothen Gardinen an einigen Thronen in Brand geriethen, und die goldenen Kronen heiss wurden unter den lodernden Schlafmuetzen; - aber die alten Haescher, denen die Reichspolizey anvertraut, schleppen schon die Loescheymer herbey, und schnueffeln jetzt um so wachsamer, und schmieden um so fester die heimlichen Ketten, und ich merke schon, unsichtbar woelbt sich eine noch dichtere Kerkermauer um das deutsche Volk. Armes geknechtetes Volk! Verzage nicht in deiner Noth. H.H.1830
    _____________________
    Q 9550 E 0 @3Ghz@1,0 V - EP-45 DS4P - 4x 1024 MB Corsair 5400_UL vers.1.2 - ATI 3850 bios mod. - in 19" silent desktopcase - Panasonic PHD 8 - HDMI blade
    Jun 2006
    if you are using the built in wifi-ap and are also using windows xp 64 bit, and find that the internet connection keeps cutting out and you have to "repair" it to get it to work, try downloading the same driver that is on the Asus CD only the unsigned version from asus website. This will fix the problem. I don't know if this problem exists with the 32 bit version.
    To actually install this driver you have to tell windows you will specify which driver to install.
    The built in wifi-ap and the antenna bring in much better reception then my addon card ever did... nice setup it is.
    Intel i7 2600K @4.??, Asus P67 Pro Mobo
    noctua nd-d14 - Cooler Master HAF 932
    Geforce GTX470 - 16GB Ram G.Skill RIPJAWS
    128GB Crucial Solid state drive, and a few 2TB drives
    60 inch samsung LCD LN60C630
    Lenovo t60p - Core 2 duo T7200
    2GB RAM - 120GB hard drive
    ATI x1400 - fingerprint reader, NMB keyboard, etc.
    Xtreme Guru
    Aug 2005
    Burbank, CA
    So far im stable at 3ghz 334x9 with my ram at ddr1000, im using the g.skill 2gb hz.....vcore is at 1.350 but 1.3 in windows, also the fsb nbvcore is set to auto, i cant seem to post anything at 400 fsb, seems like over 350 im having problems......i raised the cpu volt all the way to 1.5 still no post, tried 400x6 no post, tried raising the nb vcore to 1.45 nothing, fsb was raised nothing, pci x is at 100 and pci is at 33.......spread spectrum is disabled, any ideas, im using the 0507 bios.
    Jul 2006
    Thanks for making this thread. One thing, the official bios from asus's website is 0507, not 0405. I hope this link works correctly.
    http://support.asus.com/download/dow...Language=en-us
    I'm also hearing that this board (along with most 965 boards) is having trouble running micron D9 memory. Can anyone comment on that. I've seen many people who have it working but than someone will say they do not work.
    Aug 2006
    Quote Originally Posted by mkorpal333
    Actually on the ASUS site the latest official listed BIOS is 0405. I think they took the other one down or something.
    Xtreme Cruncher
    Jul 2005
    London - UK
    Quote Originally Posted by JayG30
    it's the asus servers screwing up.
    they never took it down, just they often do this. 0507 should still be on FTP
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    Aug 2006
    Quote Originally Posted by lawrywild
    Ah makes sense. Just the site listed will not direct you to the 0507 BIOS.
    Curious, since my board will be here tomorrow, is the 0507 considered a better BIOS for most? I'm getting everything ready to flash. I got to get a lot done tomorrow. Basically get the system from parts to a finished computer ready to go out on Thursday.
    Jun 2003
    France
    Quote Originally Posted by GAR
    did you try with ram 1:1 ?
    maybe a multi pb for the ram ...
    May 2005
    Processor: E6400
    Bios Revision: 0507
    Memory: G.Skill 6400hz
    Configured Voltages: 1.425v vCore, 1.3v vFSB, 1.25v vNB
    Configured FSB:492
    Configured Ratio: 1:1
    Configured Memory Timings: 4-4-3-8
    7X multiplier
    http://valid.x86-secret.com/show_oc?id=114435
    E8400, Asus P5Q-D, GTX280, X-fi music, 4X1GB D9's, Scythe Ninja, corsair 620
    Mar 2006
    Zizo you never posted what you changed to get so high with the 507 bios
    May 2005
    Quote Originally Posted by aggybong
    I just did!
    http://www.xtremesystems.org/forums/...9&postcount=70
    Xtreme Guru
    Aug 2005
    Burbank, CA
    you kno what, i think the g.skill ram has an issue with other dividers, 1.1 worked much better and was more stable, my sandra bandwidth with 500mhz was 6900, with 400mhz 1:1 dividers my bandwidth now is 7300, anyone else get this, problem with this setup........i got my system to prime at 3.6ghz 400x9 the reason it wasnt posting was because of the ram dividers, so anyone with g.skill hz 2gb set and this board should stick to 1:1 dividers, ill report any other issues or problems i run into. so far my system is running like this
    3.6ghz @ 1.500v in bios, 1.42 in windows
    400x9 mem 1:1 divider....ddr800 @ 4-4-4-6-2-20-10-10-10-10-faster
    mem 2.3v
    cpu 1.5000
    fsb 1.300
    nbvcore 1.250
    auto
    auto
    Mar 2006
    Guys, I might have these P5B-D problems figured out. It's really damn strange, but it appears to work for me.
    Simply, with the 507 BIOS:
    8x375 will not work. 7x375 will not work. No matter what settings I use, I simply cannot boot, or if I do, Windows will blue screen while loading.
    7x458 DOES work! I'm in Windows and I've been running Prime95 for 35 minutes now. I've even verified this by using the exact same settings I do with 7x458 but instead dropping to 7x375, which resulted in a blue screen while loading Windows. Could this have something to do with automatic strap adjustment when going over a certain FSB?
    My advice would be to bypass the 300 range FSBs and even the early 400s (so far the lowest I've tested is 7x425) and see if that helps, because it did for me.
    Oct 2003
    France
    Hello,
    I wonder if someone as the same pb when multiplier is different from 9. (defaut on E6600) In that case if I reboot the computer from Windows or exit the bios with saving change, my computer stop, 2s later power on led and stop instantaneously and 2s later boot without any pb. (my OC is really effective and no msg from the bios about a possible trouble)
    Another thing strange: with 4 sticks of 1go bios detect me only 2.93go, windows XP (32 or 64 bits) too. CPUZ see 4096mo with 4 sticks
    Processor: E6600
    Bios Revision: 0507
    Memory: 4 x 1go Gskill 6400HZ
    Configured Voltages: vCore 1,325, vNB 1,45 vDimm 2,0v
    Configured FSB: 400
    Configured multiplier: 8
    Configured Memory Timings: 4/4/4/12/4/30
    Any other applicable configuration modifications: Lan2/Audio/Serial/FDD disable. Wifi card dismounted in order to use 2 more USB
  18. #18
    Apr 2005
    Notts Uni
    This thread for sticky
    I have x2 rigs on their way now with:
    P6B-D's
    E6300's
    Tuniq Tower's
    Team Xtreem 2gig kits
    Il post here when my rigs are upped and problems are encountered.
    Lol Dead
  19. #19
    Jul 2006
    Mars
    @ gar
    i could post 400fsb by raising both nb en fsb termination by one
    Core i7 2700k@4,8ghz HT off- 1.41v / Gainward GTX580 GooD 850/1700/2200 / 2X4Gb G.Skill Ares 1833C9 / Z77 Sabertooth / Crucial M4 64 Gb / WD 320Gb and 640GB / Corsair H80 / Corsair 620 HX
  20. #20
    Dec 2004
    Seoul, South Korea
    Nice job. go sticky!
  21. #21
    Nov 2005
    Germany
    i have only problems with 4:5 divider (wont boot over 480Mhz ram!), but 2:3 & 3:5
    work without problems (boot with 615Mhz ram!).
    Processor: E6300
    Bios Revision: 0507
    Memory: G.Skill 6400HZ
    Configured Voltages: 1.45v vCore, 1.40v vFSB, 1.25v vNB, 1.70v vSB
    Configured FSB:486
    Configured Memory Timings: 4-4-4-8
  22. #22
    Nov 2003
    NYC
    Processor: E6400
    Bios Revision: 0507
    Memory: Corsair XMS PC8500
    Configured Voltages: 1.35v vCore, Auto vFSB, Auto vNB, Auto vSB
    Configured FSB:365x8
    Configured Ratio: 2:3
    Configured Memory Timings: auto
    When I get my wcing setup i'll push further =P
    At the moment the processor is quite toasty idling around 50c
  23. #23
    Jul 2006
    Nasgul do you have screens of your bios settings I would love to see them
    GAR what temps is that system putting out with no load?
    thanks
    sparks
  24. #24
    Apr 2005
    Processor:
    Processor: E6600
    Bios Revision: 0502
    Memory: GEIL DDR2 6400, 4-4-4-12
    Configured Voltages: vCore: 1.35 , vDimm 2.1, Rest Auto
    Configured FSB: 350
    Configured Memory Timings: By SPD = 4-4-4-12
    My board is primestable at 350fsb, but it fails prime at 360( rounding errors ) and it wont boot at 370. I have no idea what to do to get it higher tbh.
    With 0507 bios and the exact same settings as i use now i fail prime at 350fsb:\
  25. #25
    Apr 2005
    Ok i know this probably is a stupid question, but what is "vMch" and how do i change it on p5d deluxe?
