XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 10-03-2007, 04:06 AM   #1
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
ASUS Maximus Formula SE
Got a nice package today Thanks Asus & HWI. Results tonight after work.
Bios 0504 seems to have some issues, the dividers for sure. If you are having probs try 0401 again
*Update 12-02-2007* Thread becomes rather long. OP should have been updated a long time ago, sorry for that.
From Eastcoasthandle:
Originally Posted by Eastcoasthandle View Post
Here is one example of some of the information lost in the shuffle:
-Check Asus website for bios updates regarding ASUS Maximus Formula and ASUS Maximus Formula SE. Remember there are not removable bios chips for these boards. You use any bios on this forum at your own risk!
-You get better N/S Bridge temps when you remove the factory TIM and apply AS5 Ceramic.
-When updating from one bios to another RESET YOUR CURRENT BIOS TO STOCK, NONE OC SETTINGS BEFORE FLASHING
-If the fusion water block on the chipset doesn't come off you can use a hair dryer to heat it. Or, you can cool the MB in the frig for a few hours in to chill the thermal compound. Either suggestion can damage your MB, you do this at your own risk!
-If you water cool the NB (SE version) it's best to use plastic clamps or worm drive, from Anandtech
-The black PCIe x1 port is proprietary for the included sound card
-Yes, there is a 1.03G out there http://www.xtremesystems.org/forums/...&postcount=806
-It maybe worth the time to put a small 40mm fan on the s/b heatsink
-P5E is an excellent board if you are not looking for the features of the Maximus Formula
-Ultra 120 Extreme and clearance from the South Bridge heat sink using a 8800 http://www.xtremesystems.org/forums/...&postcount=920
-SE has option for 3 thermal sensors however you have to buy the thermal sensor cable separate
-Use a 8-pin 12V connector
-In order to get charted voltage results using OCCT, start Everest and go to:
-Preferences
-External Applications:
Enable shared memory must be checked
Kup's links to bios files:
Originally Posted by kup View Post
Most of the released Bios' for the Maximus Formula...
MF0401.zip
MF0504.zip
MF0505.zip
MF0602.zip
MF0701.zip
MF0702.rar
MF0802.zip
MF0901.zip
MF0902.zip
MF0903.zip
And here is the AsusUpdate that allows downgrading from the 09xx series.
AsusUpdate v6
By Talonman:
Official Water Cooling Thread of the Stock Maximus SE ROG NB Club:
http://www.xtremesystems.org/forums/...d.php?t=164610
Water cooling the Asus Maximus SE X38 using aftermarket blocks and sinks:
http://www.xtremesystems.org/forums/...d.php?t=162085
Getting RAID to work on the ASUS Maximus SE
http://www.xtremesystems.org/forums/...d.php?t=166867
More info and with structure here: http://www.xtremesystems.org/forums/...d.php?t=168119
Thank you guys
__________________
loc.o is offline   Reply With Quote
Old 10-03-2007, 05:15 AM   #2
LyP0
hehehe, got the same bord over here mate
to bad I also have to work, i've been realy exited to start
jah jonge, dan gaat t eindelijk beginnen. De hwi contest. Hoop dat je klaar bent voor een stevige competitie.
__________________
cpu : e6850 @ 3.5ghz
cooler : boxed
mem : balistix 8500 @ 1000mhz 4-4-4-4
board : asus p5k-e wifi
graphics : 7800gtx
harddisk : wd raptor 74gb
dvd : nec 7173A
dvdrw : optiarc 18x
psu : enermax liberty 620W
screen : dell 3007wfp hc
LyP0 is offline   Reply With Quote
Old 10-03-2007, 05:55 AM   #3
Teqqles
Designed for WC I see, will be interesting to see just how well this performs...
Teqqles is offline   Reply With Quote
Old 10-03-2007, 06:15 AM   #4
GLENBOY
GLENBOY's Avatar
nice one loco
GLENBOY is offline   Reply With Quote
Old 10-03-2007, 06:37 AM   #5
DMH
DMH's Avatar
Really nice mailbox,waiting for tests
DMH is offline   Reply With Quote
Old 10-03-2007, 06:45 AM   #6
hornet
hornet's Avatar
Send a message via MSN to hornet
The holes in the PCB will be that is compatible with a swiftech mcx 159?
This in the zone of the NB.
Like this looks that this heatpipe stayed of outside.
__________________
hornet is offline   Reply With Quote
Old 10-03-2007, 07:01 AM   #7
rabor
rabor's Avatar
Whats the product code of the SE version?
I think I rather have the non-watercooled NB-sink, even though I got a wc-ed rig.
__________________
Approx. 1½ metric tons of computers, periphz & server..
rabor is offline   Reply With Quote
Old 10-03-2007, 07:22 AM   #8
pmp
pmp's Avatar
For now non-SE edition is not yet available. My source tell me it will be available by end of this month. But simultaneously SE version will be phased out.
pmp is offline   Reply With Quote
Old 10-03-2007, 08:00 AM   #9
hornet
hornet's Avatar
That is a good news, I expect that is confirmed.
__________________
Old 10-03-2007, 08:10 AM   #10
CornerJack
CornerJack's Avatar
loc.o, I have too the motherboard
__________________
THE site : http://www.overclex.net/
Soon http://www.microcx.com/
WR E4300 : 4680MHz (9x520) !
Thanks EVGA and Asus France !
CornerJack is offline   Reply With Quote
Old 10-03-2007, 08:21 AM   #11
rabor
rabor's Avatar
Wery pwetty..
What size are those in-/outlets?
CornerJack, did you buy it retail? If so where?
__________________
Old 10-03-2007, 08:41 AM   #12
Zeus
Xtreme kickass
Zeus's Avatar
Send a message via ICQ to Zeus
Tell me more! :P
What chipset? SLI? DDR2 or DDR3 support? or both?
How come i haven't got one, i'm from the Netherlands as well.
__________________
Asus Crosshair III Formula | Phenom II X4 965 C3 | 2x2GB Dominator GT 2000 C8 | 2x ATI HD5770 Crossfire | Silverstone DA800 | Samsung F1 1TB
Watercooling: Heatkiller V3 LT | EK 5770 Delrin fullcover | PA120.2 & PA120.3 | DDC2+ Delrin top | EK 200mm res | Tygon R3400 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE
Zeus is offline   Reply With Quote
Old 10-03-2007, 08:55 AM   #13
jagt
jagt's Avatar
So how would this work without connecting the waterblock? I'm rather hesitant to connect an Asus made waterblock into my higher-end watercooling setup. Are these blocks known to be restrictive?
__________________
- Intel Xeon W3520 #3848A352 D0 @ 4.4GHz
- DFI LanParty UT X58-T3eH8 (bios 05/08)
- 3x2GB Corsair Failinator GT 1866MHz 7-8-7-20 (3x2GB Patriot Viper 1600MHz C8 backup...)
- Sapphire Radeon HD 4870 X2 2GB @ 872/1000
- ~5TB assorted WD/Seagate
- SB X-Fi XtremeMusic & Logitech Z-680 THX
- Tt Toughpower 1200W Modular
- CM Stacker T01 Black
- Eizo FlexScan SX2761W 27" & Samsung 226CW 22"
CPU Loop: MCP655/D5 - Swiftech Apogee GTZ - Thermochilll PA120.3 - YateLoon SL's - 1/2" MasterKleer
GPU/Chipset Loop: MCP655/D5 - EK-FC4870 X2 Acetal CF - Swiftech MCW30 - Thermochill PA120.3 - YateLoon SL's - 1/2" MasterKleer
jagt is offline   Reply With Quote
Old 10-03-2007, 09:22 AM   #14
WeaponX
WeaponX's Avatar
I envy you Netherland guys, we're suffering over here in the US. If you don't mind me asking, how much was the board? (US currency of course )
Hopefully you'll have results up soon
__________________
Home PC: Intel i7 @ 4.2ghz l EVGA X58 LE l Corsair Dominator 2000mhz GT (3x6GB) l Asus 4870 512mb l Intel SSD 80gb 2G l WD Black 1T storage drive l WD MyBook 500gb External l Samsung SH-S203N DVD l Creative X-Fi Fatality Pro l Corsair 1000HX l Asus MK241H 24" LCD Monitor l Corsair 800D Case l Windows 7 Pro 64 bit l Sennheiser HD-590
Watering Cooling: Swiftech 320 Res (3 X Gentle Typhoons 1500rpm) l Swiftech Pump w/XSPC Res Top l Heatkiller 3.0 CPU Block l Feser One Liquid
-Impossible is not a word
WeaponX is offline   Reply With Quote
Old 10-03-2007, 09:29 AM   #15
SynGroW
SynGroW's Avatar
Send a message via ICQ to SynGroW Send a message via MSN to SynGroW
It was for free
Asus sponsored 10 boards for a Dutch overclocking contest and all the guys posting here (including me) got one of those 10 boards.
__________________
| Core 2 Duo E6600 @ 5304MHz | Biostar TForce P965 Dlx | XFX 7800GT | 1GB Crucial Ballistix PC5300 CL3 |
SPi 1M: 9.953s
SynGroW is offline   Reply With Quote
Old 10-03-2007, 09:29 AM   #16
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Originally Posted by Zeus View Post
Tell me more! :P
X38, only DDR2, no SLI - only CF.
Where is results
Martin
__________________
Burn i5 750 // Foxconn burn Asus P7P55D Deluxe // 2 x 2GB A-Data XPG 2000 // Sapphire HD 4870 // R0 Maxtor 250GB + WDR 74GB // CM 690 Pure // Antec TPQ 850W
DEVIL K-ce is offline   Reply With Quote
Old 10-03-2007, 09:43 AM   #17
T2k
Banned
I hate you guys./ I'm hunting this board for mnore than a week now... it's still not available in the US...
How much you guys paid?
T2k is offline   Reply With Quote
Old 10-03-2007, 09:47 AM   #18
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
now show us some numbers loc.o
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 10-03-2007, 09:51 AM   #19
WeaponX
WeaponX's Avatar
Originally Posted by SynGroW View Post
It was for free
NOW I really hate you guys, I'm going to need the addresses of all 10 people ASAP! Time for some breaking and entering and armed robbery lol.
If you guys can take some more pictures of what's all included in the box (accessories including the fitting sizes) and it's Quad Core overclocking abilities, I will cancel my flight to Netherlands to rob you guys
__________________
Old 10-03-2007, 10:05 AM   #20
Zulusman
Zulusman's Avatar
....and screens
Cant wait
__________________
BoinC freak
Zulusman is offline   Reply With Quote
Old 10-03-2007, 10:15 AM   #21
SynGroW
SynGroW's Avatar
I just made some pics, will upload them in a sec.
__________________
SPi 1M: 9.953s
Old 10-03-2007, 10:19 AM   #22
Zeus
Xtreme kickass
Zeus's Avatar
Hmmm, don't know about x38 chipset with DDR2.
This chipset really starts to shine if one can use it in conjunction with DDR3 but perhaps these 10 dutch golddiggers can prove me wrong.
__________________
Old 10-03-2007, 10:20 AM   #23
CornerJack
CornerJack's Avatar
The bundle is the same that Asus Blitz Extreme P35 : http://www.overclex.net/hardware/240...-Blitz-Extreme
__________________
Old 10-03-2007, 10:25 AM   #24
SynGroW
SynGroW's Avatar
__________________
SPi 1M: 9.953s
Old 10-03-2007, 10:29 AM   #25
CornerJack
CornerJack's Avatar
Just to see, difference between Asus Maximus Formula and Asus P5E3 Deluxe
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
