Page 1 of 22 123411 ... LastLast
Results 1 to 25 of 536
Thread: Lapped core 2 duo IHS pics
    Xtreme Guru
    Dec 2006
    Philly/NJ
    For those of you that have lapped your core 2 duo IHS, could you post some pictures? before during and after maybe so i can get an idea of what to expect when i get mine.
    May 2004
    Sherbrooke, Quebec, Canada
    I'll start:
    During lapping:
    Finished result:
    Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
    2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
    *** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
    Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
    Xtreme Guru
    Dec 2006
    Philly/NJ
    Quote Originally Posted by pH(x)
    This isn't a Core 2 Duo, but the prerequisite and practice-lapping run (on a $96 chip) to put in my future 65nm P5W DH DLX system.
    I lapped this Dual Core Smithfield 805 and got an 11C decrease in idle temps by doing so.
    You can see stock therm compound residue -- highlighting the uneven intel IHS
    Lapped in Figure-8 to 800 Grit
    Lapped in Figure-8 to 15 Microns
    Both cores are stable at 1.3GHz over stock speeds, 44C on air, Arctic Cooling Freezer 7
    your pics arent loading unfortunatly..
    Dec 2005
    NYC
    Quote Originally Posted by Spawne32
    Damn www.uploader.ws! Well, fixed, though through a slower host.
    And btw I don't believe in using metal polish, makes your processor look pretty, but you are in fact doing harm to your thermal conductivity.
    By applying a solvent like Brasso to your processor's IHS -- more chemical molecules are put between your heatsink of choice and the IHS, so by polishing and adding chemicals to the surface you are realistically hurting your heat transfer.
    Jul 2006
    Here is my 6600.
    Intel I5 2500K
    Asus P8p67Pro
    G.Skill RipjawsX 2X4GB
    WD Raptor 64GB
    MSI TwinFrozr 5850
    Corsair TX750W
    Ultra 120
    Xtreme Guru
    Dec 2006
    Philly/NJ
    mmmm all these mirror finishes
    May 2004
    Same here. Got a 10C decrease in idle temp and 5-6C got load temps on my e6700.
    Nov 2004
    These results make gets me tempted to lap mine. Beautiful work guys, always love shiny things!
    Jan 2005
    Love the shiney finishes, what makes me wonder though is why don't people like Intel actually ensure that the IHS is flat, after all they are the 1's concerned with heat output and effective cooling. Can't be that hard can it, just need to mill it flat somewhere in their production cycle.
    Apr 2004
    Helsinki / Finland
    - Team Skootterit
    - SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
    - SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
    Feb 2005
    Smurf in My Loop
    Quote Originally Posted by Dani
    lapped polished
    My gawd!!! How long did it take you to do that?
    MSI Big Bang XPower
    Core i7 930 @ 3.38 Ghz
    6 x 2GB Patriot DDR3 1600
    XFX Double D 7850
    Therltake Toughpower 1200
    Thermalright Ultra 120 Extreme
    OCZ Revodrive 3 120GB
    Corsair 700D
    Dell 2405FPW
    W7 Pro 64 bit
    Oct 2004
    Bedford, England
    Nice work theer Dani
    E6600
    E4300
    Lapping helped the E6600 a lot because it was shaped like a spoon, but the E4300 didn't get any decrease in temps whatsoever.
    Q6600 G0 L720B058 @ 3.8GHz | Asus Maximus Formula (Rampage 0403 Modded) | 4x2Gb GSkill PC8000 PQ @ 1015MHz | XFX 9800GX2 XXX @ 680/2080 | 2 x WD Raptors RAID0 | 1 x WD5000KS | Samsung S203B DVDR/W | Samsung SM245B + Panasonic TX37LZD80
    D-Tek Fuzion | PA120.3 + Shroud + Nexus Fans | MCW30 | Laing DDC w/ Petra's DDCT-01s Top Combo | Tygon 1/2" Tubing | T-Line
    Apr 2006
    Omg dani and herm how did you get that finish?
    what kind of paper did you use?
    "WW3 will be fought with nukes, WW4 will be fought with rocks!":
    Xtreme Cruncher
    Jan 2007
    Denmark
    Here is some pics of my work.
    My E6400:
    My Scythe Infinity which i polished a bit:
    Watercool Project! (Check it out!) (New update: 25/07-2007: Pics of costom made RAM-cooler + lapjob)
    System:
    Intel Core 2 Duo E6420 @ 3600 MHz, 1.52 Vcore
    Asus P5K Deluxe
    Crucial Tenth Anniversary PC-5300 2 x 1024 Mb @ 900 MHz, 4-4-4-9, 2.05 Vdimm (Costom cooled)
    Inno3D 8800 GTS 640 Mb @ 648/1512/1021
    Corsair HX520W
    2 x WD Raptor 74 Gb (RAID0)
    Antec P180B (3 x Scythe S-FLEX SFF21E @ ~ 10 V)
    Samsung SyncMaster 226BW 22"
    Sunbeam Rheobus
    Watercooling:
    Swiftec Apogee GTX (Bowed)
    Swiftec MCW60 (Swiftec MC14 and MC21 ramsinks)
    Thermochill PA120.3 (3 x Shakoon Silent Eagle 2000 @ ~ 6.5 V)
    Laing DCC-2 18W (Aplhacool top)
    EK Multioption 150
    Masterkleer 7/16" ID
    EK High-Flow fittings
    Oct 2004
    Bedford, England
    Quote Originally Posted by GrimReaper
    1200 grit wet'n'dry because it was the finest grade I could find, (1500 or 2000 grit would be ideal) but I put some metal polish on the paper before lapping (figure 8 motion) Afterwards I just used isopropanol to clean out or dissolve any residue the polish left behind and that was that. For the final cut I prefer to use wet'n'dry that is pretty much worn out or at least has had heavy use as it seems to give a more uniform finish. The keyy is to take your time doing it, I spent about an hour or more to get the finish in those screenies, but in all honesty as long as it is 'flat' thats enough.
    Jul 2006
    alpena, michigan
    very nice everybody.
    cpu: 2600k@ 4.5ghz
    mobo: asus p8p67 deluxe
    ram: gskill ripjaw x F3-10666CL7D-8GBXH
    gfx: gigabyte gtx460
    psu:corsair 520hx
    case: antec 900
    cpu cooling: Prolimatech Megahalems Rev.B
    500mhz cas 3 club: http://valid.x86-secret.com/show_oc.php?id=235630
    p4 511 2.8ghz@ 5004mhz :http://valid.x86-secret.com/show_oc.php?id=124434
    p4 541 3.2ghz@ 4909mhz :http://valid.x86-secret.com/show_oc.php?id=157470
    Apr 2006
    Quote Originally Posted by HermS
    very interesting I used a 2500 wet paper on my heatsink and it looks like I just rubbed it on a tar road
  18. #18
    Dec 2006
    Dublin, Ireland
    Can anyone tell me how this compares to taking off the IHS altogether ? I've a Venice I wanna get working on (just waiting on lanparty nf4 to ship) and I'm wondering which I'd get better temps with: lapping or removing the IHS.
    p.s: Nice mirror finishes all!
  19. #19
    I am Xtreme
    Oct 2005
    Quote Originally Posted by [ IE ] unity
    Remove the IHS :-P. I popped my 170 and both my 8800s.
    polishing the lap job with brasso is not a good idea because it leaves a layer on the IHS.
    well that is what I have read before numerous times, also it woudl seem that just leaving the IHS bare as your are going to use TIM would be a better idea?
    fermiNow Dave will see FERMI where ever I go
    Quote Originally Posted by jbartlett323 View Post
    So please return to the "Darkside of the Moon" and check your "Pulse" while you wait for the "Animals" that will be "Obscured By Clouds". And watch me wave as I say "Wish You Were Here" in "A Momentary Lapse of Reason"
  20. #20
    Oct 2004
    Bedford, England
    On AMD chips the IHS's are usually pretty flat in my experience so lapping might not be that beneficial. There are gains to be had from removing the IHS completely, but it's a risky job and the risk outweighs the benefit in my opinion.
  21. #21
    I am Xtreme
    Oct 2005
    Considering folks have been recording high temps on the 8800s anyway, i am glad I popped mine, MOST think I am crazy HA!
  22. #22
    Dec 2006
    Dublin, Ireland
    Well this CPU was like ~60 euro so no big loss if I do kill it when taking off the IHS Then again according to this http://www.xtremesystems.org/forums/...d.php?t=132319 S939 chips are becoming rare now maybe I should keep it @ stock as a collector's item to make lots of money selling it
  23. #23
    Xtreme Cruncher
    Jan 2007
    Denmark
    Quote Originally Posted by phelan1777
    I polished it with 99% Isopropyl Alchohol aftwerwards, which should remove the layer. Temps has improved alot anyways
    System:
    Asus P5K Deluxe
    Corsair HX520W
    Sunbeam Rheobus
    Watercooling:
    EK Multioption 150
  24. #24
    Jan 2005
    Some of these lapping pics are awesome. Last HSF I lapped was I think a GlobaWin, my current Theralright 947U is fairly flat but it it makes like 10C diff then I'm definately going to contemplate lapping the IHS and HSF when I move to C2D in a few months time
  25. #25
    Xtreme Guru
    Dec 2006
    Philly/NJ
    good god almighty ive never seen such sexy mirror finishes, dani your takin pictures with your processor half way down the block!
