XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 02-05-2007, 11:28 PM   #1
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
1333 FSB Mod, Confirmed To Be Working By Me.
Updated for Easier Pic.
This is showing the bottom of the CPU as if you had it upside down, facing you.
Original Post.
got bored tonight and was looking around at VR forums and came across a old pic Shamino posted awhile back and thought... why not give it a shot...
so I took one of my spare conroes, and got my conductive ink pen, did the mod, let it dry, took my PC apart and popped this in... and it almost worked.
it booted at 1333, then I rebooted, and it went back to 1066... and was jumping back and forth.
so I took the CPU out, and saw, I didnt have a nice clean connection between the two BSEL pads... so I traced over it again, and let it dry, blah blah blah...
10 minutes later... it works.
now, it's working just fine.
boots up everytime at 7 x 333.
no big deal really since I know this CPU can do over 590, but its still fun to have a higher default FSB for the hell of it.
I wanted to see if this works, so I could try it on my quad core CPU...
hoping theres a slim chance in hell, that if it boots at 1333, the chipset strap will be looser, and give me some extra OC room.
thats a 1-100 shot... but if I never do it, how can I say it wont work??
atleast this one worked.
what would be kinda interesting, is if you took a E4300, and did this mod to it, assuming you knew the CPU could do 3 ghz, it would boot up at 9 x 333 for 3 ghz.
that would be pretty cool for those cheap boards that been coming out at Frys and such, with the CPU.
anyways, next try is to make my Quad Core do the same thing...
not really holding my breath on it, but its worth a shot.
heres the boot up speed I got from CPUZ after the mod.
http://valid.x86-secret.com/show_oc?id=165085
total down time, about 20-30 minutes, to take it apart, do the mod, let it dry and put it back together.
last note...
before doing this kinda mod, make sure you have a bios on your board that will allow a 1333 FSB CPU to be used in that board.
__________________
Kunaak is offline   Reply With Quote
Old 02-05-2007, 11:45 PM   #2
elyrly
elyrly's Avatar
interesting post
__________________
Processor: Core 2 E6400 @2.67GHz Lapped
Motherboard: ASUS P5W DH Deluxe (1707 Bios)
Graphics: MSI 7900GS 256MB @ 450/1320
Memory: 2x1GB Micron PC4200 “D9CRZ” fatbody chips @833MHZ 4-4-3-12 2.45v
Power: Antec Neo HE 500 Watt
Sound: Creative X-Fi XtremeMusic | Sennheiser HD595
Harddrives: 250GB WD2500KS
Cooling: Tuniq Tower 120, Zalman VF900-CU, OCZ XT
Case: Antec P180
elyrly is offline   Reply With Quote
Old 02-06-2007, 12:00 AM   #4
Kunaak
Kunaak's Avatar
heres some better proof that it works.
you can't fool the "Auto" setting.
set it to auto in bios, it should go back to default 1066...
but as you can see here... it doesn't.
__________________
Old 02-06-2007, 12:02 AM   #5
s e t h
Champion
s e t h's Avatar
cool Kunaak. nice idea
most interesting to me would be to see if this has any effect on fsb walls when using 6x.
all the conroes i've had have walled somewhere below 500fsb :/ (some as low as 460 even on p5b-dlx)
so here i am buying and selling cpu's just trying to find one that will go to a decent speed on LN2 without having to buy the hellishly expensive unlocked series.
(intel i hope you read this...fix your fbs wall issue please )
s e t h is offline   Reply With Quote
Old 02-06-2007, 12:13 AM   #6
Kunaak
Kunaak's Avatar
I honestly dont believe CPUs have FSB walls.
2 years ago, if you claimed to be able to get a Pentium 4 to 500+ on the FSB. people would have just said you were a liar.
today, people do it all the time, in these latest 7 and 8 ghz LN2 tests with pentium 4's and the latest generation boards.
__________________
Old 02-06-2007, 12:23 AM   #7
s e t h
Champion
s e t h's Avatar
ummm...well you would if you had 2 e6600 at 6X multiplier that stopped going faster at inexplicably low fsb on a p5b-dlx known to go much higher on the fsb.
swop one chip for the other and the fsb wall changes....and this all while hovering below 3ghz for the core....
fsb walls exist...you just have to look for them
Old 02-06-2007, 12:31 AM   #8
Kunaak
Kunaak's Avatar
Originally Posted by flytek
ummm...well you would if you had 2 e6600 at 6X multiplier that stopped goin faster at inecplicably low fsb on a p5b-dlx known to go much higher on the fsb.
no they dont.
the P5B deluxe has a NBCC that gets higher the lower you set the multiplier.
say you have your E6600 and are setting 6 x 500 cause you think that will work.
Multiplier divide by set multiplier = X, take X and multiply that by the FSB, then take that number and multiply that by 4 and you get the NBCC.
9/6 = 1.5 x 500 = 750 x 4 = 3000 mhz.
a 3 ghz NBCC is extremely high and in 90% of cases will not be bootable.
a CPU with a lower default multiplier has a far better chance at hitting 500 then a CPU with a high multiplier, which is why you see E6300's do it all the time, but never a E6700.
yes, the 4 meg cache will hold them back... but even a 4 meg cache CPU can hit 500 stable... so thats not the issue.
its the north bridge core clock.
a typical NBCC will not like going higher then about 2400 mhz before freaking out.
if your doing default multiplier, 2400 is enough for a 600 FSB.
but once you lower your FSB, you start to drastically decrease your CPU's ability to hit stable FSBs that are really high cause you greatly increase the NBCC faster.
__________________
Old 02-06-2007, 12:51 AM   #9
s e t h
Champion
s e t h's Avatar
funny that...as i was using 2 e6600's so as not to have the issue supposedly created by non default multipliers.
both e6600 have fsb walls
one at 460 and the other at 495fsb.
now the the really strange thing is that changing the miltiplier back to default and using -70' phase cooling made the fsb wall on both slightly worse....
so after extensive testing i can comfortably say the theory of the nb strap and default multi creating a NB fsb wall is not applicable in this case.
also i can say with 100% certainty that changing the multiplier does nothing to move the fsb wall.
and lastly two of the exactly the same cpu (using whatever multy is needed to rule out core speed as the wall) can and do have FSB WALLS at different frequencies.
if you have 2 of the same cpu like i did at the time you will be able to see the same behaviour i would think.
unless your board walls first or the cpu's are so identical that spotting the differece becomes difficult.
Old 02-06-2007, 01:11 AM   #10
Kunaak
Kunaak's Avatar
enough with your CPU, if you wanna discuss it further, start a topic please and dont hijack mine.
Quad Core 1333 FSB Mod Works.
__________________
Old 02-06-2007, 01:21 AM   #11
erwinz
very nice..
__________________
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800 , E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
Ati FireGL V5100, Elsa FireGL V3100
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
Silverstone OP650
raptors, baracuda
erwinz is offline   Reply With Quote
Old 02-06-2007, 01:22 AM   #12
Millyons
Millyons's Avatar
I wonder if there is any way to play with Bsel pads to force the 1066 strap all the time on a 1066 strap cpu....mostly for Asus P5Bdlx that switches strap at 401 by itself, could something like that work?
Millyons is offline   Reply With Quote
Old 02-06-2007, 01:44 AM   #13
s e t h
Champion
s e t h's Avatar
oh well...this just reminded me of the lanparty revb days when ppl modded the cpu's default fsb and wound up getting higher clocks from it.
thanks for reminding me of that situation as now i can test this method you brought to my attention and see what effect it might have on conroe fsb walls.
will post back if this does indeed wind up helping max clocks in certain situations
Old 02-06-2007, 01:49 AM   #14
Kunaak
Kunaak's Avatar
Yeah....
it does help alittle for Quad Cores.
Been Running 350 FSB tops for the last 2 days (since I moved from the P5B deluxe to this board 2 days ago) and now, I can get 366 stable.
still no 400+ very easy... it will boot, but wont make it into windows at more then 400+ yet.
but still, this is a improvement of 16 FSB.
pretty cool so far.
__________________
Old 02-06-2007, 01:59 AM   #15
G H Z
Champion
G H Z's Avatar
Good to see it working on Quad, lot's of chip's may get some remodeling on the underside now. Nice one kunaak.
G H Z is offline   Reply With Quote
Old 02-06-2007, 02:41 AM   #16
caater
caater's Avatar
btw kunaak, the idea of NBCC was discarded. even by Tony
but nice to see that bsel trick has an use now with those 1333 fsb bioses..
when i tried it a while back, i had asus p5wdh and of course it didnt help at all.
by the way - does the 1333 nb strap kick in with 1333 fsb cpu or does it still require booting at 401+ as usual?
__________________
R.I.P. mobile celeron
caater is offline   Reply With Quote
Old 02-06-2007, 02:47 AM   #17
HamidFULL
Send a message via MSN to HamidFULL Send a message via Yahoo to HamidFULL Send a message via Skype™ to HamidFULL
very nice we should only short red line with conductive pen for FSB 1333?
__________________
www.HotOverclock.com Founder & Editor in Chief
Upgrading to X58 ...
Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
abit IX38 QuadGT Rev1.0 (X38 Rev.01)
4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
HDD 120GB Maxtor Max.10 6L120M0
PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
HamidFULL is offline   Reply With Quote
Old 02-06-2007, 02:51 AM   #18
Kunaak
Kunaak's Avatar
Heres the Mod as I did it.
__________________
Old 02-06-2007, 02:54 AM   #19
loc.o
Xtremely Addicted
loc.o's Avatar
Send a message via MSN to loc.o
Right, lower multi doesnt mean less FSB.
Thats what id like to know, 401 or at another point..
__________________
loc.o is offline   Reply With Quote
Old 02-06-2007, 03:05 AM   #20
over@locker886
Champion
over@locker886's Avatar
Send a message via MSN to over@locker886
I think believe CPUs have fsb walls..
Why?
I tested my E6600ES in Asus P5B-Deluxe..
Max FSB test, with..
6x ratio: 530Mhz with air
7X ratio: 530Mhz with air
8x ratio: 530Mhz with air
8x ratio: 566Mhz with Vapochill LS
I think need cold (delta temp) for cpu, if we break over fsb wall.
__________________
"AMD gives me back the old/real overclocking feeling"
over@locker886 is offline   Reply With Quote
Old 02-06-2007, 03:09 AM   #21
Tony
the jedi master
Tony's Avatar
Pre 1333fsb support added to bios this mod did not work, Post support we now have it working.
__________________
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Tony is offline   Reply With Quote
Old 02-06-2007, 03:14 AM   #22
Movieman
I'm feeling BLUE!
Movieman's Avatar
Kunaak:
We've been doing this over in the WCG section for a couple months now on the woodcrest and clovertown rigs.
The clovers are essentially Kentsfields with some added instructions to run in duals. Keep in mind that the boards we work with don't have the OC features that the gaming boards have so we had to get a little creative.
I've run my dual clovertown 2667/8mb/1066 up as high as 3330/8mb/1333 using the 10 multi and to 3271 using the 9 multi.
Thats with 1.35v.
We're also handicapped using FBDimms and there's a 370 "wall" in the boards but it's still impressive to see 8 cores at those speeds.
As to what it will do, go look at HWBot on Sisoftsandra or wPrime..
All on stock volts but there are volt modds available up to 1.55 for these boards. I get a little skittish on moving the volts over 1.45 as these are $500.00 boards with $3000.00 in chips and $700.00 in memory.
__________________
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch View Post
If you have lost faith in humanity, then hold a newborn in your hands.
Movieman is offline   Reply With Quote
Old 02-06-2007, 04:06 AM   #23
Hazzan
Brotherhood
Hazzan's Avatar
Send a message via MSN to Hazzan
amazing I will try with my E6300 and E6600
Hazzan is offline   Reply With Quote
Old 02-06-2007, 04:11 AM   #24
mrlobber
mrlobber's Avatar
Send a message via Skype™ to mrlobber
Try to tell this to all the people who have had various E6400 cpus which mysteriously stop at, for example, 480x8, 480x7, while another E6400 cpu can do 480x8 or 525x7, on 1333 strap, all the other hardware being the same.
Also, the GTL reference voltage mod existence confirms this as well as some users who have been banned for posting things about the FSB wall I wouldn't like to discuss openly here.
Other than that, nice find on the 1333fsb mod Might try it on my 6400to see what does it change
__________________
away & gone
mrlobber is offline   Reply With Quote
Old 02-06-2007, 04:17 AM   #25
Naughtyboy
Send a message via ICQ to Naughtyboy
Kunaak I assume you are doing this on your P5N32...if so, what bios are you using ??
__________________
Originally Posted by Ugly n Grey
I was watching late night TV and this was rolling through my mind all night.....
"Why in the name of Papa Smurf would you put your d1ck in a hot apple pie?????????"
Naughtyboy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
