Page 1 of 21 123411 ... LastLast
Results 1 to 25 of 504
Thread: 680i overclocking thread
    Jul 2005
    My results for the eVGA are back. Rather disappointing.
    FSB tops at 449. I mean literally 449. A hair higher than that will not post. I know this system including this CPU can do 485 on my previous P5B deluxe. Wondering if I should return this board or not.
    Intel Core 2 Duo E6400 L625A491 @ 3.2 Ghz 1.36V dual prime stable 25+ hrs large FFTs |
    4GB (4x1024) D9GMH 1:1 |
    P5B deluxe | 8800GT | XiFi Xtreme Music | 2x Raptor 150GB Raid 0 | Westy 37w3 | Zippy PSL-6850P(G1)-PCIE4 PSU | Lian Li v1200Aplus WC|
    Apr 2005
    There seems to be a bug when setting a certain FSB causing the system not to post. What you can do is trying going a little higher in increments of 5. I seem to be stuck at the same spot you are at. I can't wait to go home to do some more testing. I have a 850 watt zippy, EVGA 680i and 6600 B stepping that needs some attention
    See this link to see what I'm talking about.
    http://www.vr-zone.com/?i=4215&s=14
    Nov 2003
    NYC
    will it do over 3200mhz with the 8x multi?
    Jun 2005
    The MotherShip
    cambrian can you run orthos blend at 449?
    "Behold, I am Funkadelic. I am not of your world. But fear me not, I will do you no harm. Loan me your funky mind and I shall play with it. For nothing is good unless you play with it. And all that is good, is nasty!"
    ("What Is Soul," Funkadelic, 1969)
    Jul 2005
    1) tried it at 8x multi --> same results, craps out at 450 FSB
    2) tried the suggestions provided by the link --> does not work; even at multiple FSB: 1825, 1855, 1875, etc; I tried it in linked/unlinked modes, both produce same results
    3) I noticed that I can orthos large FFT's for 10+ hours at 400x8 at 2T timings but at 1T orthos failed in 2 minutes. My RAM is really good and can go up as high as 980 mhz.
    4) Yes I can run orthos (large FFT's) for 5+ minutes under 449 FSB without failing; I can also run 400 FSB 10+ hrs large FFT's without failing as mentioned in #3.
    Xtreme Mentor
    Jun 2002
    They have an updated bios that helps here but they won't let it out yet.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Sep 2006
    dont rma the board.. keep it, bios updates will fix some stuff and if maybe u can go sli now too
    gigabyte 965p-s3
    intel c2d e6300 @ 3.255 24/7 (stock hs/f)
    corsair xms2 (twin2x1024a-6400c4) ddr2 800 @ 930 5-5-5-15
    xfx 7600gt @ 650/841 [560/725 stock] (stock hs/f)
    samsung spinpoint-p 160gb
    antec sonata2 w/ 450w trupower2.0 psu
    i love my budget gaming rig <3
    highest OC so far.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    450 from a board thats basically as tight in latency as the 975 boards, is actually pretty good.
    you can go back to the P5B, but you sacrifice alot of latency for a higher OC.
    compare your super PI times to your 965 board, and you will see what I mean....
    Jul 2005
    Quote Originally Posted by xgman
    dude, hook it up!
    Jun 2006
    Chicago, IL
    Quote Originally Posted by Kunaak
    I agree with Kunaak, i'd keep the board for at least another week to see if there are any gains from a bios update or until the people having better luck with the board post their settings.
    Asus Commando 6600 week 28B @4.2 1.475v(1.475 in bios) 525x8 4-4-3-4 1150mhz 2.3v
    2x1gb Patriot Pc-8000 Xbl | X1600 Pro | 2 Wd 36gb Raptors
    Seagate 750gb | Vapoli V2000B SS | Pc p&c Black Silencer 750
    Quote Originally Posted by chron
    Its DDR2 - doesn't it need to be ran with 2 sticks at a time?
    Jul 2006
    Greece/Germany
    Quote Originally Posted by MrDeeds
    Dito - a list on the 1st Post with the various Results would nice,too.
    iLL
    Xtreme Mentor
    Jun 2002
    Quote Originally Posted by cambrian
    dude, hook it up!
    I'll get there, but between the bios/mem issues and the capacitors in the way of the backplate, I am not as much in a hurry as I was earlier today. I wish someone wiould share that darn P20 beta bios that Hardocp and VRzone were given. I never had this much trouble getting a beta bios from Asus.
    Someone from EVGA says maybe the updated bios next wed. Seems like along time . .
    Jul 2005
    yeah the capacitors right where the back plate would be is really annoying and stupid. I had to add extra padding to tuniq tower back plate so it would it won't crush those damn capacitors. If you look at the Asus board, it does not have that problem...Very well thought out on Asus' part I think
    And the bios problem is going to be a hassle in the future. Asus has been really good with releasing bioses. eVGA remains to be seen but so far not impressed.
    Banned
    Aug 2006
    man and i nearly bought that mobo.....gotta wait till next week and see what happens before i buy any mobo
    May 2004
    San Diego, CA
    The whole releasing of a BIOS is what held me off getting an eVGA. I dont trust em yet.
    intel i7 3770k 4.40GHz
    ASUS Maximus V Extreme
    EVGA GTX 680 FTW
    16GB GSKill 2400MHz
    (1) OCZ Vertex 3 60GB SSD
    (1) Samsung 840 Pro 256GB SSD
    (1) 1.5 TB WD Caviar Green SATA
    Sound Blaster X-Fi Titanium Fatal1ty Professional
    Corsair 700D
    Corsair AX850
    Water Cooled (EK blocks on CPU and GPU, TA 120.4, DDC-1+ with XSPC ResTop)
    May 2005
    Montana, USA
    I ordered one.... I watercool so the capacitors on the back wont be an issue for me. As far as BIOSes are concerned, there should be a flood of solid BIOS releases for the reference board because several partners are essentially releasing the same board. The only thing that would be different is the hex code that identifies the company name.
    i7-2600K @ 4806Mhz 102.3x47 1.368v LinX stable
    MSI P67 GD-80
    16Gb Corsair 8-8-8-24 1T 818.2Mhz
    MSI GTX560Ti 1005/2250 1.062v
    Crucial m4 256Gb SSD
    Corsair TX850 | 64bit WIN7 Pro
    Custom watercooling
    47" 1080p LCD | Onkyo 876/ Polk 5.1 surround
    Oct 2006
    England
    Any one know anything about the beta bios from nvidia thats newer than the one from evga? Its meant to fix FSB problems.
  18. #18
    Jun 2004
    Well Iam waiting for my vendor to get these in..Cant wait to come off the MSI 975x board..392fsb max..So the 449fsb will be really nice for me..Plus being able to run any Nvidia Drivers I want to..(SLI)
    HA just got a call my vendor has them 219.00 shipped EVGA..Should have it Tuesday..
  19. #19
    Banned
    Aug 2006
    Quote Originally Posted by gmod
    why are you getting it that cheap?
  20. #20
    Nov 2002
    Houston
    Quote Originally Posted by slykid
    Because MSRP on the board is $229. Anything over that and you have experienced early adopter pricing syndrome.
  21. #21
    Xtreme Guru
    Aug 2005
    Burbank, CA
    i couldnt get 450x8 to post.....im at 400x9.........my superpi times are slower than my p5b deluxe tho........with ddr1067 i get more bandwidth with my 680i but with ddr1000 and less bandwidth my p5b did super pi in 13.987 this one does 14.124.........wierd.............................. ...if posible could u guys include a picture or a discription of your bios settings thanks.
  22. #22
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Coolaler also showed that P5B is better performing than 680i in spi.
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
  23. #23
    Apr 2006
    Brasil
    Muste be a FSB "hole":
    http://enthusiast.hardocp.com/articl...50aHVzaWFzdA==
    Try 1845MHz FSB (461).
  24. #24
    Apr 2005
    max fsb 466 x 7, no pic were done as i thought i'll go more > 470.
    max 461 x 8.
  25. #25
    Xtreme Guru
    Jul 2004
    evga motherboard don't expect a lot.
    sorry that was mean.
