- Forum
- Hardware
- Intel
-  Intel Core Temperature Monitor plugin for MBM5 (WinXP) - download now!
							Version 1.1 Available Now! MBM5 Update 3 Available Now!
 Core(TM) Temperature Monitor Plugin for Motherboard Monitor 5
 Distributed under license by The Tech Repository (www.thetechrepository.com).
 Copyright (C) 2006 freecableguy (FCG). All Rights Reserved.
 Monitor actual Core(TM) (DTS) temperatures directly from MBM5!
 Supports Yonah, Conroe/Allendale/Woodcrest/Merom, and Kentsfield/Clovertown.
 This plugin for MBM5 allows the user to simultaneously monitor up to 16 cores using Intel Core(TM) technology. All sensor update intervals, logging options, alarm settings, and display characteristics can be set through the popular MBM5 interface to be displayed along-side all other motherboard and video card temperatures/data. Free for use, free for distibution. Easy to setup and a great aid to overclockers and enthusiasts alike. Download version 1.1 now!
 Motherboard Monitor 5 Update 3 is available for download exclusively from The Tech Repository! This update is cumulative and does not require any other updates to be installed prior to patching. This update correct a general incompatability between version 1.0 of the Core(TM) Temp plugin and the CPU usage display setting that resulted in incorrect temperatures for one or more cores.
 Version History:
 12/02/2006 - 1.0 - initial release, coreplugin.dll v1.0.0.0010, coretemp.sys v1.0.0.0005
 12/10/2006 - 1.1 - coreplugin.dll v1.0.0.0036, coretemp.sys v1.0.0.0006
 - Corrected bug where some quad-core processors would display core temperatures 15C too low as a results of incorrect Tjunction calculation.
 - Added support for internal display and calculation of CPU usage. Native MBM5 CPU usage support is disabled when the plugin is loaded when using MBM5 Update 3.
 - Increased maximum core support to 16 cores.
 - Changed default sensor numbers so that cores temperatures shown in the system tray can be read in order from left to right starting with 'Core 0'.
 Download Core(TM) Temp plugin v1.1 and MBM5 Update 3 from here
 -FCG
- You may not post replies
- You may not edit your posts
Forum Rules
