07-09-2006, 02:55 AM
#1
The Official Core 2 Duo Overclocking Thread
Need a favour guys. Can you post in the format of:
Username - *Speed and stability* (*vcore*) | *Cooling* | *Mobo* | *Ram*
It'll take me all year to do each post on my own. Thanks
Well, seeing as there's a 65nm Intel OCing thread and an OC thread for almost every A64 based architecture known to man, I thought why shouldn't we have a Core 2 Duo Overclocking thread?
Please post screenies/links of your results obtained with Allendale or Conroe CPUs. Remember to also list which CPU, MoBo, RAM and cooling you were using. If known, plese also post the BIOS revision of your MoBo. Also state your vCore.
Atleast a Pi 1M shot is required, however feel free to post other benchmark results as well. A dual prime screenshot of >1 hour (>3 hours preferred) would also be appreciated for proof of basic stability, but is not mandatory.
Finally, please try to keep OT discussion to a minimum in this thread.
Please click on a username to go to the single post
Key:
Proof of stability included
Proof of stability not included
Full specs not included
Results:
Allendale
E6300
K.I.T.T. - 2800 MHz Prime Stable (1.20v) | Stock Cooling | ASUS P5W DH Deluxe, 0602 BIOS (now on 0088. tried 0604 as well...no changes.)
yoti - 3013 MHz Prime stable (1.27v) | Air cooling | Intel Bad Axe Rev. 302
Bolef2k - 3003 MHz Prime stable (1.46v) | Air (Scythe Ninja Plus) | ASUS P5W DH Deluxe 0078 BIOS ----- welcome!! to XS
E6400
Mykou - 4 MB cache ES 3123 MHz Pi 1M Stable (1.4v) | Noctua NH 12 + 120 mm paspst | Asus P5W DH Deluxe 0605 BIOS
Conroe
E6600
njkid32 - 3926 MHz Pi 1M (1.5v) | Air Cooling | Intel Bad Axe Rev. 304
eva2000 - 3750 Mhz Prime stable (1.44v) ; 3860 MHz bench stable (~1.5v) | Water | Intel Bad Axe Rev. 304
Supertim0r - 3600 MHz Prime stable (1.3875v) ; 4050 MHz Pi 1M Stable (1.5v) ; 3958 MHz single Pi 32M stable (1.4v) | Big Typhoon | Bad Axe Rev. 304.
gocchin - 3787 MHz Prime stable (stock vCore) ; 3810 MHz Pi 1M Stable (stock vCore) | Zalman 9500 | Bad Axe Rev. 304
CompGeek - 3850 Mhz Prime stable (1.52v) | Water | Bad Axe Rev. 304
Rol-Co - 4182 MHz Pi 1M stable (1.65v) | Big Typhoon | vModded ASUS P5W DH Deluxe
kiwi - 3336 MHz 3DM01 stable (1.55v) | Water | Bad Axe Rev. 304 (0908 BIOS)
Devious - 3807 MHz Prime stable (1.45v) | Water |ASUS P5W DH Deluxe
PcCI2iminal - 4118 MHz Pi 1M stable (1.62v) | Water | ASUS P5W DH Deluxe
epox4life - Retail 4080 Mhz pi 1M stable (1.65v) | SS Cooling (Stock Vapochill LS) | P5W DH Deluxe
E6700
freecableguy - 4600 MHz Pi 1M stable (1.62v) | SS Phase | ASUS P5W DH Deluxe (0078 BIOS)
X6800
Nightprowler_77 - 3739 Prime stable (1.55v) | Water | ASUS P5W DH Deluxe
As of now, anyone failing to post their full specs including MoBo, cooling and vCore will not be added to the list unless amended. Dual Pi 32M or 1 hour of prime is mandatory if your overclock is to be considered stable.
__________________
The rig
CPUs: E6300 ES B0 @ 3220 MHz w/1.35v orthos stable | E6600 B2 @ 3400 MHz w/1.43v --> Sold | Xeon 3050 L2 @ 3304 MHz w/1.45v orthos stable
MoBo: Asus P5K-E WiFi-AP @ 520 x * orthos stable --> Still testing THE best board I've ever used.
Graphics: 256 MB Connect 3D Radeon X1900XT @ 661/828 (core/mem)
RAM: 2 x 1 GB Team Xtreem PC2 5300 @ DDR1010 4-4-4-8 / DDR1100 5-5-5-12 w/2.25v orthos stable (more MHz to squeeze out yet!) --> Still testing
HDDs: 300 GB (16 MB Cache) and 80 GB Maxtor Diamondmax 10 drives
Optical: NEC ND3500AG DVD +/- RW
PSU: Antec True Power 2.0 550W
Currently air cooled w/Arctic Cooling Freezer 7 Pro + Stock GPU Heatsink
Moving Back to H2O Soon
H2O
Swiftech MCR220-QP | Laing D5 | AquaXtreme MP-05 Pro LE | DangerDen Maze 4 LP | 2 x 120mm NoiseBlocker SX1 fans
Coming soon
9800GT ??? / HD 2950 Pro
Lappy
MSI MS1022 14.1" Widescreen Barebone | Celeron-M 360 1.4 GHz @ 1.86 GHz / Pentium M 715A | GeForce 6200 Go | 80 GB Fujitsu HDD | Sony DVD +/- RW
Waiting for
Nehalem
07-09-2006, 03:00 AM
#2
Allendale E6300 ES | Asus P5W DH Deluxe (0602)| 2 x 1 GB Team Xtreem PC5300
Prime Stable @ 400 x 7 w/1.235v set in BIOS (1.2 after vDroop)
Super Pi @ 2877 MHz
__________________
The rig
H2O
Coming soon
Lappy
Waiting for
Nehalem
07-09-2006, 03:04 AM
#3
Hiding from the cops and people I ripped off
Here is mine on air  On badaxe with 1.5v in bios using 1333 strap.
__________________
07-09-2006, 03:06 AM
#4
Asus P5W DH bios 0602
E6600 @ 4.050
2GB Team Group Xtreeme 667 *loose timings
http://valid.x86-secret.com/show_oc?id=103438
primed over 8 hours @ 3.4 Ghz @ stock volts
07-09-2006, 03:26 AM
#5
Memory Addict
E6600
@3750Mhz at 1.441v dual stressprime haven't tried dual stressprime higher than 3750Mhz yet
@3861Mhz at 1.465, 1.488v to 1.511v for benching
E6600 QPGE B1 Step 5
Swiftech G4 Storm + Thermochill 120.3 + MCP650
Intel D975XBX Badaxe rev304 stock no mods
700W OCZ GameXStream PSU
Dual Stressprime 2004 idle and load temps:
Room ambient: 25.3C
CPU idle: 33C/34C
CPU load: 59-60C for both cores
@9x416fsb = 3750Mhz
vcore = 1.441v
mch = 1.725v
fsb = 1.395
vdimm = 2.2v
Pcmark05
3dmark05 breaking 22k!
here's 3dmark2003 with 42k barrier just broken
3dmark2001 new high
07-09-2006, 08:46 AM
#6
E6300 ES B0 step 4 @3013MHz 1.3 V in BIOS, 2,6 GHz 24/7 !.3 V
Intel Bad Axe moded rev. 302
Air cooling: Cooler Master Hyper LP 3
You can see my PC in my sig.
Validation:
http://valid.x86-secret.com/show_oc?id=104686
__________________
Abit IP-35 Pro* INTEL XEON 3110@4050 MHz Air cooled* DDR2 2x1 GB * WD 300 GB * Cooler Master Stacker 830 * Tagan TG530-U22 * Radeon HD2900XT * Pioneer DVR 110D * Pioneer DVR 109-DB * SONY SDM X93 * Creative Audigy 2 * Creative Megaworks 250D*EPSON STYLUS PHOTO R1800
07-10-2006, 09:18 AM
#7
INTEL inside
prime 1.3875vcore 1.9vdimm set in bios :
1m 1.5vcore 2.2vdimm:
32m 1.4vcore 1.9vdimm:
1333strap
1067strap
3D :
E6600 "ES" Step 5 B1 (1.35v - 1.5v)
Bad Axe 304 stock
2gig Team Group 667 "D9" (1.9v - 2.2v)
TT BT + Panaflo L1A
Powerstream 520w
XFX 7900GT 650/1900
__________________
24/7 PC : Biostar Tpower P45, E8400 E0 @ 4.4ghz, 4gig G.SKILL F2-8000CL5D-4GBPQ, Asus 8800 Ultra, Corsair HX520w
benching stuff : P5K Premium, DFI LANParty Dk P35-T2RS, XBX2 <3..., few "D9" kit, few Q66 ES / E8400 / Q9550 ES, 8800GT and GTS, OCZ PS600W, Zeus 750w, Phase change, Tuniq, Ultra 120E...
07-10-2006, 05:02 PM
#8
Overclocking X.I.P. Otaku
E6600 Stepping 5
Unmodded Bad Axe 304
Zalman 9500 Air Cooled
3.8ghz AIR on STOCK VCORE
07-11-2006, 05:35 AM
#9
gocchin,
Can you post your temps? Idle & Full, plz!
What mems do you have?
07-12-2006, 07:05 AM
#10
hmmm, I had already started one a few weeks back.
E6600, 3850MHz, 1.57v set on bad axe - supposedly 1.52v actual, water, prime stable
__________________
Putting in my 18ghz for Rosetta, are YOU? PM me or another XS Rosetta Team member to get started.
Conroe (Core 2 Duo) E6600 Engineering Sample Step 5 @ 3.85GHz 24/7 (Up to 4050MHz for Super PI)
Intel BOXD975XBXLKR "Bad Axe" rev.304 Mobo
2x 1GB G.Skill DDR2 @ 433MHz 4-4-4-12
2x eVGA 7900 GT SLI @ 725/850 (Up to 800/1000 for benchmarks)
Originally Posted by dmn_link (Gamespot)
Am I being watched by a hacker?
I just went to change my display picture for my Windows account and saw and account that i have never created before. The account name is ASP.NET Machine A...'s .
07-12-2006, 07:22 AM
#11
Xtreme Cruncher
That's awesome compgeek
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
07-12-2006, 08:33 AM
#12
If everyone would post their revision as well, that would be great. (Mine is a B1 - Step 5)
Thanks lawry
__________________
07-12-2006, 08:53 AM
#13
Banned
Here's another for the collection:
E6700 ES (stepping 5), 1.62v, single stage phase change cooling, Asus P52 DH Deluxe (BIOS 0078)
07-12-2006, 08:55 AM
#14
INTEL inside
have you tried a few P5W to hit 460fsb or you just did the vmod ?
__________________
07-12-2006, 08:59 AM
#15
can we make prime stability the standard in this thread?
__________________
07-12-2006, 10:24 AM
#16
I am Xtreme
No offense, but prime is overrated. I'm sure it will be hard to push something like that as many people don't use it. Then we'll have the guys preaching prime is the only way to tell if an o/c is stable. yadda yadda.
I personally don't use prime, never have. Super pi 32m, then R@H.
I think its going fine as it is.
__________________
Donate to XtremeSystems!
Gaming: Intel Core i7 920 @ 3.9ghz, Asus P6T Deluxe, 6GB Wintec AmpX DDR3-1600, Sparkle GTX260-216, PC Power & Cooling Silencer 750w Quad, 2x Raptor X 150gb Raid 0.
Workstation: Intel Pentium e5200, Zotac GF9300DE mITX Wifi, 4GB DDR2-800, XFX GTS250-1GB, 1TB Samsung F1, Stuffed into a Sugo SG05!
HTPC: AMD X2 4850e, Zotac GF8200-C-E mITX Wifi, 2GB DDR2-800, 320GB 7200.10, Stuffed into Sugo SG05!
Webserver: Supermicro 811i 1U chassis, Supermicro X5DPA-GG, 2x1.6ghz LV Xeons, 1gb Reg Ecc, 2x320gb WD's Raid 1.
Sammy: 2x Intel LV Xeon's 1.66ghz, Intel SE7520BB2, 4gb Reg Ecc DDR2-667, 74gb Raptor, 8x320gb 7200.10 Raid 5.
Sammy.2: 2x Intel LV Xeon's 1.66ghz, Intel SE7520BB2, 2gb Reg Ecc DDR2-800, 74gb Raptor, 5x750gb Samsung F1's Raid 5.
Sammy.3: 2x Intel LV Xeon's 2.0ghz, Supermicro X6DLP-EG2, 2gb Reg Ecc DDR2-800, 8x1TB Samsung F1's Raid 5.
07-12-2006, 03:57 PM
#17
D-m.o.s.t
E6600 air cooled
1.65v
TT BT cooled ambient 15C
asus p5wd dh voltmodded/modded chipset
max s-pi 1M stable
max ss
validation
07-12-2006, 04:12 PM
#18
Well, we need SOME standard because clocks are going to be all over the charts and not neccessarily clear.
__________________
07-13-2006, 12:51 PM
#19
Xtreme
Prime is sh*t, try rosetta
Old B0 step, Vcore 1.55V I think, Intel Bad axe 304 bios 0908, corsair 8000ul, water cooled xtx at stock, 3D stable
__________________
07-13-2006, 01:44 PM
#20
D-m.o.s.t
e6600@4ghz air cooled
asus p5wd dh deluxe @stock
2x 512mb corsair 8000UL
7950gx2 @ stock settings/cooler 91.31 driver
2001 score
07-13-2006, 05:41 PM
#21
I ask that you post the results in code or an Excel screenshot, so the column divisions are easy to follow.
Otherwise, great thread!
07-14-2006, 07:39 AM
#22
E6800 Stepping 5.
Vcore 1.55 --> undervolts to 1.51
Mobo: Asus P5W DH Deluxe- no mods
temps i Everest are bad  hope its a softwareissue.
Cooling: High end water.
Fore som reason a 14 multi made things more stable at this speed. I think this mobo or bios(604) has some FSB 300+ issues.
__________________
GAME: [QX9650@4.0Ghz] [Gigabyte P35-DQ6 ] [8800GTX] [ 4GbG.SKILL 6400 2GBHZ ] [DELL 24]
HTPC: [C2 X6800 @3.4Ghz ] [Shuttle SD37P2] [Asus 7300GT Silent] [2Gb Kingston ] [37 Samsung M87]
SERVER /GAME: [Core 2 Q6600@3.2Ghz] [Asus Striker ] [8800GTS x 2] [4Gb OCZ] [Nec 20WGX2]
07-14-2006, 08:42 AM
#23
Captain Jinx
Step 5 6700 on Prometeia Mach II-
Very easily 3D stable:
PCMark05 (equally stressful as Prime95 IMHO):
1M up to 4200 but I don't have a screenie. All I have is this relaxed DI run:
Oh, and 32M back on the Prometeia.
As far as truly stable with this particular processor goes, I would say a flat 4 GHz is where its happiest. Benchable nearly 300MHz beyond that, but not useable for more than several minutes on end. I'd like to see more Prime/PCMark results from Conroes, they are a more accurate gague of where they can actually run for practical usage.
__________________
Originally Posted by FUGGER
I put on my shoes before I put on my pants.
07-16-2006, 11:21 PM
#25
Another result for me.
1.45v in bios.
Swiftech Apex water.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
