Well i've had that case for about 6 days and yeees i'm goin to put there some PC goods
But now there's new twist, the watercooling!
The HW:
AMD X2 7750
Asus M3A78-CM
4GB DDR2
Sapphire HD4830
Nexus NX5000
+Dvd drive and 160GB hdd, lan rig why i'd need bigger?
Watercooling:
Rad: Hardware Labs Black ICE Radiator GT Xtreme M184
Pump: MCP335, from my main rig, going to retire watercooling from there.
Cpu Block: XCC CU block, man these are old but works like charm on X2 cpu.
Gpu Block: Swiftech MCW60.
Watertank: No idea yet, anyhow will be hidden under psu plate.
Mods:
White sleeving on the psus and other cables.
Custom made pcb for frontpanels cabling.
Pics:
I know she's little dirty in this old pic, will take new tomorrow...
The battle plan.
So empty...
Cable for psu, tho not goin to be used since i'm not going to use psus orig covers.
__________________
ಠ_ಠ Serious smiley demands you to crunch You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
--->Blog<---
Originally Posted by SF3D
I will soon send e-mail to bulldog, solid and puunakki, cause they are the ones who have been misleaded in the beginning.
We're still waiting those emails
Main rig: Intel and ATI with ZOMGWTFBBQ Overclocks.
That's a pretty cool idea. Where did you get the G5 case from?
Found this from mato78's forums
Arr just noticed than i've to remove vga and dvi connectors from motherboard, not enought clearance between mobo and backpanel connector board :F
E: Here's the main reason for removing the dvi and vga connectors:
No free space there... Pic by: pirloui from insanelymac.
__________________
--->Blog<---
This is what you all have been waiting... Updates!
Well i eventually decided to use Nexus NX-5000, great psu btw!
Tho need to cut and remove some of those cables, must leave atleast 2 molex, 24pin atx connector, 8pin esp connector and 2 pci-es. And yea sleeve all of those =)
Yes there is enought clearance for psu/pump rooms cover.
The stand offs for cover, it were pretty interesting than G5s orig psus mounting holes are at same spot at 2 with normal psus 2 mounting holes
1mm plate of aluminium which will become cover for power room.
Ready for soldering rampage =)
Awesome or pure awesomeness?
__________________
--->Blog<---
__________________ XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
wow, this looks awesome, i love builds like this....partially cause ive never seen it been done before....cant wait to see how it turns out and where everything is going to fit in......best of luck!!
__________________
Originally Posted by kinghong1970
yea.. i need help... seriously......last time i went to the bathroom, it seems that the male has the pecker that pokes the female, right?
i'm confused...
Originally Posted by lennox
holy cow do you really run 1/2" tubing without clamps? that's like banging a prostitute without a condom!
Lian Li V2000B Special Water cut: DFI LanParty X48 LT T2R : Q6600 @3.21 ghtz : 2x Samsung Spinpoint F1 32mb cache 1tb HDD's : HD 4870x2 : 4GB domminator : Swiftech GTZ block : PA120.3 : DCC 18w res top : DCC 18w res top : EK FC 4870x2 :
finally someone who doesn't cut out the back and ruins the looks of the case
best looking pc case ever
__________________
Rig1: X4 955 BE |MSi 5850 OC|4gb OCZ DDR3
Asus M4A785TD-M EVO|Lian Li V350|HX620|Noctua NH-U9B
Rig2: E2140 @3.2 ghz|Abit iX38QuadGT|HD3870|
Looking for a new 13" Notebook with non-glare display; dedicated FireGL/Quadro
Originally Posted by s0lid
Well that cases macs logic board were busted so don't know is it really gone down the drain
E: Done
I know ... you're rescuing it. I just have a soft spot for the G5. Had one I passed on to my brother when I got more serious about gaming. For everything else, it was a very elegant machine.
You are really doing a great job - probably almost as difficult as building a case from scratch, given all the detail you are putting in to get it right.
