About two years back I did a worklog for my murderMod Jr. It was time for serious maintenance and I decided to do some upgrading while tearing everything down. As usual, my desire to keep it simple is not going to work.
I intended to just replace the two 285's with two 580's and the coolers. That lasted all of 24 hours. I will now be replacing my MB, CPU, CPU block, VC's, VC blocks and the Aquaero. I am going with the following;
Asus RIII E
i7 980X
Aqua Cuplex Kryos HF
2 evga GTX 580's
2 EK Nickel blocks
12 GB Corsair Dominator GT 2000
New Aquaero & Aqua Power Adjust-I would appreciate any feed back on the PA
Repacing the blue tubing with red tubing-the MB is red & black
I cannot find any reason to replace my Feser Quad Rad
I will be using my existing TJ07 case because I cannot find anything I like better and the M|M gear is just too cool! Here is a pic during the original build.
I have a few outrageous ideas ideas regarding the new sleeving, but I may keep it simple?
Any thoughts, ideas or suggestions will be appreciated.
