Page 1 of 4 1234 LastLast
Results 1 to 25 of 93
Thread: Stacker 832 Getting Watercooled (*Heavy Pics*)
    Jun 2007
    mars
    Arrow Stacker 832 Gettin Watercooled (*Heavy Pics*)
    Hello,
    here is my log for watercooling amazing CoolerMaster Stacker 832
    First of all let me introduce how it was before
    Hardware for my rig will be following:
    CPU Intel Core 2 Duo 6420 (gonna change it to Q9450)
    Mobo DFI X38
    Memory 4x1Gb CSX Diablo DDR2-1200 (Micron D9GMH)
    Video XFX 8800GTS 320Mb (don't know is it worth to change it to 3870x2 or wait for the next single chip top from ATI?)
    HDD Samsung F1 1Tb
    Sound Creative X-Fi Platinum
    Some SATA DVD RW with lightscribe
    PSU Seasonic M12 700W
    And water parts will be these
    Radiators: Thermochill PA120.2 and Thermochill PA120.3
    CPU block: D-Tek Fuzion
    Pumps Laing DDC1-T 10Watt with EK Top 3/8 barbs (choose 10W to have lower noise, higher reliability, hope they will be enough for my loops)
    Reservoirs EK Multioption 150
    Waterblock for memory MIPS Ram Freezer 4 (coz i almost hate such air coolers as OCZ or Corsair)
    Chipset block: EK ASUS3 (but i think it wont fit on new DFI X38, so i need to get smth else)
    Later i'm planning to add mosfet and video blocks.
    And I'm going to build a dual loop setup.
    Ok, now let's go
    Unsurpassed power, 10000 RPM
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
    Aug 2004
    Minneapolis, MN
    Nice selection of parts. Be careful with using the gel stuff under the Laing DDCs. They tend to heat up quite a bit and can cause the pump to fail.
    I am Xtreme
    Oct 2005
    I second that, the gel even deformed a bit under my RD30, so it works well under non heated items for shock absorbing.
    fermiNow Dave will see FERMI where ever I go
    Quote Originally Posted by jbartlett323 View Post
    So please return to the "Darkside of the Moon" and check your "Pulse" while you wait for the "Animals" that will be "Obscured By Clouds". And watch me wave as I say "Wish You Were Here" in "A Momentary Lapse of Reason"
    Jun 2007
    mars
    I need to make 4 major cuts: top, bottom, bottom stand (where wheels are) and mobo tray.
    Friend of mine did all the hardest work for me
    Top
    Bottom
    Stand
    And tray
    Next I did a big work with sanding and smoothing edges. Result was excellent
    Then I did 4 brackets for mounting rads, and drill a bunch of holes.
    Bottom radiator is ready
    Sk8board is ready
    Top radiator is ready
    And tray is ready also
    Guys, pls check this thread about pumps mounting
    http://www.xtremesystems.org/forums/...d.php?t=178038
    What do you think?
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
    Dec 2007
    Washington State, USA
    Quote Originally Posted by rioja View Post
    Frend of mine did all the hardest work for me
    What do you think?
    Clean that puppy out.
    Jun 2007
    mars
    Sure, i will clean all my parts when will be doing final assemble. My PC is in veeery dusty and dirty room, and i'm too lazy to clean this room regularly
    Now some additional shots.
    Clearance between floor and rad is 3cm. I hope it will be enough, if not then i may rise a rad ~1cm higher and make another wheels.
    I like my Seasonic M12 700 Watt, it is very quet and has standard size so it is possible to have 120.2 and PSU at the top
    UFO hangar
    In my opinion top rad has enough air. I will make additional duct in top-front plastic cover, to get more air.
    Case inside
    And just like this pic
    Next step will be doing 3 major things: mounting res, mounting pumps, cutting the hole in plastic cover.
    After that it will be painted, not sure with color yet, black is annoying already for me.
    Thats all for now, please standby
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
    Jun 2007
    Athens
    very nice the rad on the bottom is fine i have the 831 with the rad mounted on the bottom and the is no problem with it and the temps the only problem is the dust :/ the bottom rad is pulling the dust like crazy
    CPU : Q9550 / Board : Asus P5E64 WS Evolution / Ram : 2x1 OCZ D9GTR DDR3 / Vga : HD 4870 / PSU : PPC&C 750W / SSD Ocz Vertex 30Gb / All under Water & Tec's
    Overclockers Wannabe Athens Dept...
    Jan 2008
    Sacramento, CA
    lookin good! packin alot into one case!
    Jun 2007
    mars
    A litle update, reservoirs installation.
    I've made 2 alu stripes, 1.5cm wide
    mounted the holders
    and cut 4 holes in the case. Here is how it turned out
    from inside
    and outside
    Stripes are thin and quite unnoticeable and at the same time solid and almost don't bind.
    I'm satisfied.
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
    Jan 2008
    Looking good
    PC
    CPU: Q6600 Mobo: XFX 780i Ram: 4gb OCZ Platinum 1066mhz VGA: XFX GeForce 8800 gts 512mb HDD: Seagate Barracuda 500gb x 2 Case: Silverstone tj07
    Cooling
    CPU: D-tek Fuzion, quad nozzle + washer NB: ViperJohn 780i SPP/NF200 waterblock VGA: EK-FC88 GT/GTS (G92) Rad: PA120.2 Fans: Noctua NF-P12-1300 x 4 Reservoir: Swiftech MCRES-Micro Tubing: Tygon R-3603 1/2" ID 5/8" OD Pump: Swiftech MCP655 vario
    Sep 2006
    Philippines
    great setup
    Apr 2007
    Poland
    good looking dual loop stacker. i'm waiting for next photos.
    Banned
    Feb 2008
    Buffalo, NY
    Looks great! I am very intersted in this seeing as how I have the exact same case as you do
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    Looks good. Can you give us some more pics?
    Mar 2006
    Los Angeles CA
    not bad at all, diggin the reservoirs.
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Sep 2007
    Belgium
    You should use the left barb of the res for a better bleeding process.
    System: E8400 // P5Q-E // Ballistix // HD3850 // HX520 http://valid.x86-secret.com/show_oc.php?id=419486
    Thermochill pa120.3 // D-tek FuZion bowed+ costum nozzle // MCW60 // EK150 // dcc1 18w w/top
    Jun 2007
    mars
    Thank you guys for comments and advices!
    I finished some more work and ready to share results.
    Next after reservoirs, it's time for a pumps.
    Pumps are Laing original DDC1-T 10 W, with EK tops 3/8 barbs
    Also I have some antivibration/sounddumpening pads, not sure what material
    but most ppl say do not use it, correct?
    So for awhile i skipped it, and mounted pumps directly to the case. Too sad that Laing don't include any mountings, holders, bolts etc to their pumps, and I had to use any stuff I could find. Maybe I wiil buy smth special for this somehow.
    More 4 holes in the case, and pumps are in the case.
    Between front panel and pumps a left some space for 12 Cm fan (optional).
    Next mod, and one of the most difficult i think, was a making air vent at front-top cover, to get top rad brief better and just coz of cool look. This step required a big accuracy becoz it is computer face
    After you cut rear wall on those cover, you will get some gap and bindings of the bottom wall, becoz it rests into the rear. So I installed a mesh from 5.25 bay cover, and made some support. Now it seats and holds same firmly as before mod.
    Look how it is
    Since only one HDD will be in my rig I decided to throw out HDD cage and use smth else.
    I always like production of Zalman Korea, since time of my first mod, becoz of high quality and excellent look. And I am glad that product from them may find place in my setup
    to be continued
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
  18. #18
    Sep 2007
    Belgium
    Res is ok now
    The spacers from the HDD cooling thing are good to mount your pumps :p
    They are good against vibration ^^
  19. #19
    Jun 2007
    mars
    Quote Originally Posted by MorGo7h View Post
    Res is ok now
    I thought exactly about the same, perhaps this is the best Zalman product ever
    I even can spend another $25 for one more cooler, specially for 5-6 more of these legs, it would be quite silly though
    I already have 2 addititional legs for spare (manual said it should be only one for spare though).
    But pump has only 2 mounting points, so if I'll do smth like this
    it won't be a good?
    Or I can make some kind of stands, cut a circle in middle, where motor is, mount pumps to this stand, and tight stand to case through 3 or 4 Zalman legs. So each pump will have 3 or 4 mounting points then. What do u think?
    One more advantage from pumps with Zalman standofs is fan in front, blowing to the pumps and HDD
    Anyway, I've finished installing last thing - HDD
    I need an option to install fan in front of pumps and HDD, so I had to lift HDD by drilling 4 more holes. Next how it looks at whole
    Finally! Case ready for painting
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
  20. #20
    Jul 2006
    Portugal
    Very very nice...
    You are doing exactly what im planning to do with me CM Stacker 830. My only difference there is that I would be using an additional Single RAD at the back of the case... hook them all up to one loop and have the 3 different rads between components... Top Dual RAD ---> CPU ---> NB Block ---> Rear Single RAD ---> Single ATI 3850 (CF Later) ---> Tripple Rad ---> Pump ---> RES ---> 288 Watt TEC (To Chill The Liquid) Back to Top Dual RAD. Im planning on using the new Koolance blocks. Still not sure what RES and Pump Ill be getting.
    The TEC will get cooled by a Cooler Master GeminII.
    PS Give us some Temps when you got it all going will ya. WEEEKEEED!!!
  21. #21
    Mar 2004
    You're doing very similar to what I'm doing, just out of curiosity though, where did you get the brackets you've got holding your tripple rad in place or did you make them yourself?
    I need to get my stacker modded and up and running within the next 3 weeks in order to make i33, nothing quite like a deadline!
  22. #22
    Jun 2007
    mars
    AsSuLuTo
    Brackets are some sort of building materials. I've got couple meters of these, just cut length i needed and drill a holes. They're made from aluminium 1.5-2 mm thikness.
    What is i33?
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
  23. #23
    Feb 2008
    Denmark / Aarhus
    This is indeed very nicely made looking forward to see more
    Desktop I5-3570k, 8GB Ram, GTX 560, Silverstone TJ08-E, Crucial M4 128GB, 750W Silver Power, ASUS P8Z77-M
    Laptop ThinkPad W520 2720QM /2 x 4 GB ram / Quadro 1000M / Crucial M4 128GB + 500Gb Hdd / FHD Screen / Intel WiFi Link 6300 AGN WLAN / 9 Cell Battery
    Laptop 2 New Macbook Pro Retina / i7 QuadCore / 650 GT / 16GB Ram / 512 GB SSD
    Server: Athlon II X4 640, ASROCK K10N78, 8GB Ram, LSI MegaRaid 8 port, 64GB Vertex 1, 5 x 1 TB WD Raid6, 3 x 3TB Seagate Raid5
  24. #24
    Mar 2004
    AsSuLuTo
    What is i33?
    I may have to have a look out at the builder merchant. i33 is a massive LAN party in the UK.
    I need my case all spruced up for then.
  25. #25
    Feb 2007
    Turkey/İzmir
    Dual Internal Loop ın 832 waow just amazing
    Intel Core i7 930@ 4.0Ghz | Gigabyte EX58-UD4P | 3x2Gb OCZ 1600mhz | Palit GTX280 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi| Iphone 4
    Hardwarena Overclock Team
