Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: Project: City of Light
    Oct 2007
    Hi, everyone, I have a new project here.
    It will be called City of Light (more explanation on the name later).
    This mod's "canvas" will be a Lian Li V2100 (old school style) which I acquired new for around USD 200. Thankfully it doesn't have the "Plus" package which I probably would've thrown out anyway. Also it only has the sound insulation on one panel, which is a 'plus' to me since I'll be cutting on it and won't have to tear it all off!
    Here's some links if you want to see what it looks like...though I imagine most of you are familiar with it:
    http://www.gideontech.com/content/articles/286/1
    http://www.firingsquad.com/hw/4317/L...ll_Tower_Case/
    City of Light will feature dual WC loops, silent operation, and a killer motherboard cover. I might throw in some home-built or modified waterblocks, too.
    This is a long term mod. I'll work on it most weekends but rarely during the week. I've already done some work, so my first several updates should be pretty regular. Please don't ever hesitate to ask questions or to make comments or give criticism. The interactive aspect is the whole reason I'm doing this log!
    It will focus equally on aesthetics, performance, and silence.
    I'm not a gamer, and this is not a gaming rig. It will primarily be used for playing with crypto, doing a lot of photo processing, and general office stuff.
    Being 'green' is kindof important to me, so where possible I want to use recycleable, ROHS compliant parts, avoid toxic coolants and paints (and have a toddler so it's safer that way). I will not cut a bunch of holes in the case b/c I will use it again; I learned from my previous Project Headrush...I mutilated that case and it's pretty much worthless for other configurations now.
    Components:
    Core i7 920
    3GB Corsair DDR3
    undecided Mobo
    undecided GPU(s)
    undecided SSD
    Cooling:
    Loop1:
    Thermochill PA120.2
    D5
    undecided CPU block
    Swissflow meter
    Loop2:
    undecided pump
    full mobo cooling
    gpu block(s)
    koolance flow meter
    BI Stealth 120.1
    BI 80.2
    possibly another Stealth 120.1
    Planning on putting the PA 120.2 on the floor, a 120.1 in the front, the 80.2 in the back, and the optional other 120.1 up on the mobo tray:
    Previous mods:
    Project Headrush - still ongoing. Honestly, I never really finished it and plan to 'refurbish' and finish it after City of Light. Here's an older pic (still in progress):
    And a shot of my top shroud:
    Macbook Carbon - I finished this last winter. It's a homemade carbon fiber shell I made for my Apple Macbook.
    Alrighty, I hope you all enjoy the ride!
    Oct 2007
    Stripping (not that kind)
    I mainly used a run of the mill cordless drill for drilling out the rivets to free the case from most if its internal 'stuff'. I got some spiffy drill bits for Father's day 2007 (thanks Cam!):
    For the times when the drill can't cut it, I got a great attachment combo for my dremel: the Dremel chuck and right-angle adapter. That made drilling out the rest of the rivets a breeze!
    Here's the fruits of my labor:
    I also took out the center divider, but not the drive supports. Sorry, I forgot to snap an 'after picture of that'
    I'll have another update for you soon.
    Oct 2007
    ETA on next update is Tuesday 1/27.
    Current Project: City of Light, (sortof) Updated 3/25 - A New Arrival
    Oct 2007
    Front light
    How many times have you had to turn on the light in your room/office, just to figure out which DVD to put in a drive or which way a memory card goes in? I wanted to fix that. So here we go.
    IMHO this case is perfect for what I want to do, which is add a little light that lights the front of the case from above, so I can see what I'm doing but it doesn't shine in my eyes and stuff. The V2100 has the 'bars' at the top and bottom of the front that hold and support the big, heavy front door.
    So, I removed the top bar and inspected it. It was ideal for my plan since it was hollow and the bottom was not too thick.
    I then got a piece of clear scrap acrylic, cut three strips, and glued them together. I wanted to 'frost' the part where the light would be coming out, and tried a bunch of grits of sandpaper, finally deciding on 800.
    After measuring and marking the center and where I wanted the 'window' for the light to pass through the top bar, I drilled two holes (can't remember what size), and two mounting holes, one on either side, and countersunk for M3 tapered head screws. Then I just dremeled out the middle.
    Then I took two LED's and flattened off the rounded bottoms with my dremel.
    With this bit - I don't know what it is called:
    I then soldered one cathode to one anode, and then wires to each side. Drilled holes in the top of the 'lens', and wired it up with a resistor.
    Wired up and ready to be screwed back on:
    And then for the test:
    I REALLY like the effect; this is something I've been wanting to have for a while! What do you guys think? to leave comments!
    barfastic
    Guest
    AWESOME idea with the lighting! Really! Goota love ingenuity... if i had that sort of problem i would probably end up using tape and a book light in some absurd manner
    Now get back to work and show us more
    Mar 2006
    Los Angeles CA
    My first real computer case I bought like 5 years ago had a similar lighting thingy.
    It was the Aspire X-Infinity case and it had two upwards and 2 downwards firing blue led's on the front.
    And before anyone asks, yes that's where the user name came from. Kinda lucky it worked out that way, LianLi.comptech just doesn't roll off the tongue the same way.
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Quote Originally Posted by headala View Post
    I think I know which MB you will be using......
    Nov 2008
    CA,USA
    THIS?!
    Could you take more pictures of your light in daylight? I don't quite see how it only lights the panel but not the front.
    Armor.exe worklog
    Mobo: Asus Rampage 2 Extreme X58
    CPU: i7 920
    GPU: ATi HD 4870x2
    Sound: Auzentech X-Fi Forte 7.1
    PSU : Corsair HX1000
    RAM: OCZ 3 x 2GB tri channel DDR3-1600
    HDD: WD 640 Black RAID 0 + 1
    Watercooled
    Oct 2007
    Quote Originally Posted by barfastic View Post
    Thanks! Hope to have some more to show soon!
    Quote Originally Posted by aspire.comptech View Post
    Cool...but I don't know why they don't do it more? It seems like it would be really useful to me
    Quote Originally Posted by theseeker View Post
    Yeah, baby, yeah! The mothership has landed...
    Quote Originally Posted by exe163 View Post
    I'm sorry, I don't have any more pics of it and I already packed it away until 'final assembly'. Could elaborate more on your question? I'd like to give you an answer.
    Thanks for your interest, guys!
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Nice idea on the light. Love the detail your putting into this.
    Oct 2007
    Thanks, Shazza, I appreciate it!
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Send me one of those light kits and I will give you a big discount on your next purchase.
    Sep 2008
    Perth, Aus
    Wow, that light is verrrry cool. I use one of these
    Also, I'm trying to work out how to mount my W/C in my V1000, which is similar design internally just craploads smaller. I'll be watching to get some ideas!
    _
    Apr 2008
    Wisconsin, United States
    Wow that light looks awesome!!
    Nov 2008
    thats some sweet lighting effect!
    Oct 2007
    Hehe, thanks. Though I've seen your skillz, and they're probably better than mine!
    Quote Originally Posted by downforce View Post
    Great, I hope you get some good ideas from little ole me.
    Quote Originally Posted by hotwaxisbad View Post
    Thank you!
    Quote Originally Posted by upsidedown View Post
    Thank you!
    Oct 2007
    Hi, what a beautiful Sunday afternoon here in NC! I hope you all are having a great day.
    I have had several request for a worklog on my Macbook Carbon alluded to in the introduction. Unfortunately I don't have enough progress pictures to do a full log so this Mini-log will have to do.
    I first came upon this idea when I was sitting in May 2007 in a Systematic Theology class (divine illumination!) and noticing how my little white Macbook looked...um...what's the politically correct word for it? Froo-froo? Effeminate? Anyway, it's not a sleek sexy black notebook (only if you give Apple an extra $200).
    It's also prone to scratches, which I hate anything I have being scratched up (The Seeker called me anal...I guess I am).
    Other things I was thinking about that are relevant: it's more or less geometrically the same top and bottom, it has very limited ports, I never use the DVD drive, and all the cooling vents are in one place on the back.
    All of these things, taken together, convinced me that it was an ideal candidate for a hard shell. And it can only be Carbon Fiber.
    In researching, I learned how much of a pain (and danger) CF can be to work with. The shards/splinters/dust can easily get in your skin/eyes/lungs/nose/ears, and sometimes have to be surgically removed. Someone even told me that they cause cancer! I thought...wow, sounds like something fun to work with!
    So, I have NO experience (except helping a friend re-fiberglass the inside of his boat in college) in composites. I did a bit of research. And I decided to try.
    My original ideas and my final procedure turned out to be quite different, so bear with me.
    My plan was to basically cover the computer in wrinkle-free plastic wrap (like for your leftovers Christmas dinner), and fiberglass it (with the CF), twice. Then trim the two halves and voila! Wasn't that easy though.
    I did get several layers of wrinkle free plastic wrap around it, and then fiberglassed it with some medium fiberglass batting, in two layers, as a test. All that stuff came from home depot. After it cured, I discovered that my MB had a weird smell and some of the plastic had deteriorated. Doh! can't do that again.
    So, I thought about how I could do it without using the computer as a mold. I thought about using MDF and building a replica, and then fiberglassing that with the CF, but it would take too much work. I didn't have a ton of time to work on it, and had limited tools.
    Then I noticed my 'test' fiberglass shell that I made. An idea was born.
    I orderd some big bottles of urethane rubber used for making molds, some carbon fiber cloth, some wax spray, and some sheeting used like plastic wrap to make the finish smooth.
    I took that urethane rubber, and dumped it into my fiberglass mold (after spraying it with copious amounts of wax). Then I put a cardboard box into the rubber to take up some space. After it cured, I had a pretty good mold made from rubber.
    Once the mold was finished, I could resume my original plan: I sprayed the mold with the wax, then stretched carbon cloth over the mold and taped it down to the sides of the box. Mixing my two part epoxy resin well, I tried to avoid bubbles as much as possible and the poured it on to the cloth. I found some spatulas at the dollar store and used them to work the epoxy into the carbon. Then I covered it with the release film. And now for the secret weapon: I used a block and tackle to carefully lower a garbage bag full of water onto the release film. This squeezed out most of the bubbles.
    I made two layers, and after it cured it seemed plenty strong. So, I did it again (another one of two layers) so I had two halves. I then had to dremel down the edges a little to test fit them onto the notebook, and then once on the notebook (and some spacers inserted inside to allow for the attachment material) I needed to mark off from the inside exactly how far down I needed to trim. I mainly used a dremel on a drill press for this.
    I realized after the trimming that in a couple of places the two layers of carbon (especially in the taller bottom half) weren't joined well. So, superglue and clothespins to the rescue!
    Overall I was pretty pleased with how they turned out. CF looks unbelievable, even when done by a n00b like me :
    I ended up attaching the top with double-sided tape, and the bottom with velcro.
    I then needed to make holes for the ports I use the most. I cut out notches on the back for the cooling vents, and holes for the power plug, front LED, and IR receiver. I mainly transfer files over my home network, and backup over that too, so I don't often need the USB/FW ports. I never use the DVD drive. So, just a couple of holes.
    Marking off:
    Drilling and filing:
    One thing that I hate is advertising for companies. Therefore, I'm not a big fan of the lit-up apple in the middle of the lid. So, I decided to make a window and show something else through it:
    Measuring:
    Finding a coin for a stencil:
    Transferring to paper:
    Drilled and cut (didn't want to dremel because of the dangerous dust/shards around my toddler):
    Sanded (a little wet):
    Finished:
    I put metal foil tape along the front edge to keep from sticking CF into my wrists:
    And we're done. Again, i apologize that the pictures are kind of hit and miss. I was on a tight schedule and have probably lost some of them. I hope you enjoyed it! I'll resume City of Light in the next update. Thanks for reading!
  18. #18
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Very creative thinking!
  19. #19
    PI in the face
    Nov 2008
    more pics to do the lappy justice!
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  20. #20
    Jan 2009
    London
    Quote Originally Posted by Bobbylite View Post
    Yes we need soem more pics
    Lian Li V1000 Plus - Core i7 920 2.66 Overclocked to 4.1ghz 1.448v 20x 1.3v QPI Multi 205MHZ BCLK (Still Tweaking) & Watercooled With 2x Feser TFC Xchanger 120mm Rads, EK Supreme Acrylic CPU Block - XSPC Drive Res - Laing DDC-1T Ultra Alphacool Top - Rampage II X58 - XFX GTX 295 680/1380/1100MHZ- 3x2GB (6GB Total) Corsair Dominator Triple Channel DDR3 1600mhz - Tagan Piperock 1100W PSU - 2x WD Velociraptors Raid 0 - Windows 7 64Bit Ultimate Beta
  21. #21
    Oct 2007
    Thanks, Seeker! Did you see that you're mentioned in the 4th paragraph, right below the 'sofa' smiley?
    Bobbylite and Swale, I'll take more pics tomorrow and post 'em.
  22. #22
    Oct 2005
    How much did the CF run you for that project? very cool idea.
    http://www.xtremesystems.org/forums/picture.php?albumid=144&pictureid=327
  23. #23
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    I noticed and trust me, you get more picky the older you get. Keep it up!
  24. #24
    Oct 2007
    Quote Originally Posted by AlucardCasull View Post
    The dry fabric cost me about $45 per yard, and I got two yards (I have almost a yard left over). Shipping will kill you though, because it comes wrapped around a heavy tube with another heavy tube around it. This keeps the CF from getting 'dented' or creased, which it is very susceptible to.
    Also, if you order more than just a little bit of epoxy and urethane rubber, you get hit with a hazmat charge.
    I'd estimate that this whole project cost me about $130, including screwups. That said, I've had countless people offer me as much as $150 to make them a set or buy mine. But it's too labor intensive and the quality isn't good enough for me to feel right about selling it to someone. I thought about trying to refine the process and sell them, but decided there are other things I would rather do with my time.
  25. #25
    Oct 2007
    Haha, maybe I can finish this project before I get super-anal.
