Adding the MB cooler is causing me tube routing issues. I could do a second loop but that is going to clutter things up. Any ideas?
Victory May Be Fleeting, But Obscurity Lasts Forever!
Last Project http://www.xtremesystems.org/forums/...d.php?t=213829
Canceled Project http://www.xtremesystems.org/forums/...d.php?t=265292
New Project http://www.xtremesystems.org/forums/...d.php?t=269440
Go cpu > gpu's > down to bottom inlet of mobo block > res.
You could also consider going parallel for your gpu's. Which would make things a bit cleaner.
Intel I7 920 D0 @ 4.2g------------EK Supreme HF
EVGA X58 SLI LE------------------EK-FB EVGA X58 LE
nVidia GTX 580----------------------EK-FC580 GTX
6g Corsair DDR3----------------DDC 3.2 w/ Petra's top
OCZ 120g Vertex SSD------------------PA120.4
WD 150g Raptor
WD 500g
ASUS Xonar DS
HX1000 psu
Silverstone TJ07 case
How's the board block setup? I'm going to assume it's a single block for VRM's and bridges. You may want to consider going with two loops (loop 1: CPU & VRM's, loop 2: GPU 1 & GPU 2). Another option would be a Y-splitter. A third would be to setup the GPU's in parallel and then run as follows...
Pump -> CPU -> Mobo -> GPU 1 & 2 -> Res
Were do you plan to put the radiator?
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
The parallel option looks to be best option.
Like this...
My toys:
My rad is in the bottom of the case. If you check my build log you can see it in the pics.
F paralell the gpu's seeker!
double bridges = more stability in mounting.. meaning when you need to pull your gpu's out, having 2 bridges to hold is better then 1.
And it looks better also!
Nadeshiko: i7 990 12GB DDR3 eVGA Classified *In Testing... Jealous?*
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Here's what I'm thinking. Makes for a very tidy loop...
WD 150g Raptor
WD 500g
ASUS Xonar DS
HX1000 psu
If it's possible to use the bottom left thread of the reservoir, I'd move the upper barb on the reservoir to that position, and then route it like this:
Similar story if you want to run them parallel:
As for the connectors, you could go the expensive way with EK's dual Parallel bridge and 2 GeForce Links, or you could get two of these.
“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
well if u use a eK bridge, then it wont matter.
But basically attach both ports to both cards.
The top card only has a port open on 1 side, while the two are open on the bottom.
The bottom card has 2 ports which are open on top, and 1 open on the bottom.
The F parallel means as it says.
Say u have 2 F's, but the second one is flipped.
That way u got 2 L's feeding in even paths, so its a true parallel.
But as i said if ur using an EK bridge, its moot, if not, then i would use some dplugs as bridges.
GRRRR Edit..
Seeker, is that the proper orientation ur going to have this unit?
So It looks like a TJ-07 with an inveresed mobo plate?
So can i assume u will have a plate below that cpu?
Use that bottom plate to hide your routing.
And try to uniform the ups and downs like so.
So from pump -> Cpu -> back under the plate -> to another pump for redundancy -> board block -> gpu -> gpu->back again under the plate -> Res -> Pump -> cpu.
GRRRR Edit..
NaeKuh,
The MB will be inverted just like the last (TJ07) build. I try to hide everything under the midplate, but you can only hide so much! Two pumps, two rads, the tubing, the wires and not to mention the PSU.
Currebrly, Alexandros is winning for the $1,000.00 gift certificate for H20 cooling parts, less shipping
As always, thanks for your input!
NaeKuh.
You did not identify my spelling error, shame on you!
Trust me, I have so many H20 parts, I can make it fit. However, I would like to make it look nice too!
I love it when you chime in.
BTW, where is Shazza?
And yes, there is a "Gift Certificate" for the winner or winners.......![]()
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
lol... nvm... jsut saw i did the same exact thing as alexandros!! hahaha
I have basically narrowed it down to these two options;
They are both good potions, but I still cannot decide. Any thoughts or opinions?
The second one looks a lot better. And no need for another elbow that way.
I'm partial to my suggested loop as I think it makes for a slightly tidier loop.
They're both good though.![]()
WD 150g Raptor
WD 500g
ASUS Xonar DS
HX1000 psu
