This is my first water cooled build, and it is inspired by the Silverstone Raven and all of the fantastic work by Charles and his murderboxes.
When I first saw the Silverstone raven the whole 90 degree rotation made perfect sense to me, and as I am after a silent build the stack effect is just what I was looking for. At the same time I became fascinanted with Charles' superb builds I became obsessed with the clean build look. I was due for an upgrade anyway, and this is what I got:
I think this must have been one of the first bloodrages in the UK as it arrived from Overclockers UK the day before they officially came in stock! The i7 920 is batch 3839A and there is not much info on these, so fingers crossed! The Corsair RAM is the 6GB 1600mhz kit.
I am still deciding on my tubing and cpu block, and my thermochill PA120.3 has not arrived yet, but here are my water cooling bits:
In the bottom of the ek reservoir is a temp probe, and the pump top is the XSPC version, and the fittings are TFC. The mcubed bigNG will control all the fans and the pump - The idea is that the only fans in the system will be the three S-Flex F's on the radiator - more will become clear when you see the case layout.
I still need to decide on a graphics card... although I will probably be going with a single GTX 295 with the koolance block - I just want to see the results from tests. I am probably going to get the Fuzion v2 for the CPU, but ideally want to use the proper mounting kit, and well, there isn't one... (yet)
