So I finally received my MM case and I am now starting to figure out exactly what I want to do with it.
My first impression is that there will be no shortage of room! This case is a monster.
If you look at the pic with the MM and the Cosmos together you can see the difference.
The theme for the case will be Red and Black like my (UN)Designs logo.
I am planning on doing dual loops like I have now.
The pumps will be mounted on the lower fans in the front with a red Absolute bracket on a black Z-Bracket.
The second row up will be all fans and the third row will probably have some
reservoirs that stick through the fan holes so you can see the coolant. I know two
reservoirs is overkill but I like the look.
I have three MCR320 coming in soon that will go on top and I plan on using some
Bitspower fittings. I have not decided whether to use two of the rads in parallel or run
them in series. I would like to see some hard facts about the pros and cons of each.
There will be some custom channeling for the wires as I hate seeing wires.
Also I am soliciting advice on fans. I need quite a few and I want them to be somewhat
quiet. I do plan on using a fan controller for some of the fans. I will also try and use SS
screws wherever I can instead of the Black Oxide that come with it.
This build should take a month or two depending on what custom parts I decide to make. Thanks for checking it out.
Here are some of the parts I am considering:
http://www.sidewindercomputers.com/laf5mi3swba.html
http://www.performance-pcs.com/catal...ducts_id=24850
http://www.sidewindercomputers.com/bishsiywitrr.html
http://www.performance-pcs.com/catal...ducts_id=21255
