Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Alphacool HF 14 Yellowstone Review
    Jul 2008
    Essex, UK
    Intel 775 & 1366 Review
    Introduction
    Welcome to my review of the Alphacool HF14 Yellowstone - before we get on to the interesting stuff and all the nice pictures that I have in store for you, I would like to thank Kaner at Alphacool for providing the HF 14 Yellowstone CPU waterblock for this review, as well as thanking Rob and his team at WCUK (Watercooling UK) for the on going support and service to the community and myself.
    You’re likely to know Alphacool was founded in 2003 in Germany, with one purpose: to supply quality water cooling to the masses from Europe to Asia. Since it was founded, they have innovated many designs from NexXxoS to the Cape, XexXxoS XP and now Yellowstone and Livingstone.
    The Yellowstone is one of new range of CPU block released this year by Alphacool, continuing the design and innovation from it’s predecessors, the NexXxos series of blocks. with Lots of great improvements from the old and with the added benefit of being available in lots of fancy colour combinations. This makes this block great for any colour-schemed or themed build.
    So what do you get in this nice retail packet, I hear you ask. I was a bit surprised and shocked at the same time. With mounting bracket, screws, nuts and the extra few things needed to mount the block to your motherboard and thermal interface material (TIM as we know it) also being chucked in, the only thing really missing and letting it down is a back plate.
    An Overview of what is included:
    • Instructions
    • Thermal Interface Material (TIM for short)
    • Mounting Hardware
    So with the above all in mind and with past experience with other blocks in which I own, it has one of the best if not best packing around. With the block clearly visible on first sight through the plastic casing and cardboard internals housing the rest of the goodies supplied with the block.
    Block Characteristics
    The Yellowstone has a direct vertical water supply that goes straight though the integrated pre-chamber which is machined into the top of the block. The water is then forced onto the pins on the base of the bock. With it being optimized for Socket 1366 processors, aka Nehalem aka Core i7, it will be nice to see if it can cope on a 775 platform, as well as on the i7 platform it is designed for.
    A few key features of the block included:
    • ¼ BSP thread barb holes
    • Variety of colours (sliver, black, red and bronze)
    • Patented tightly focused water Jet Design
    • Dimensions 52x52x16mm (WxDxH) (Without mounting bracket)
    • Dimensions 95x95x16mm (WxDxH) (With mounting bracket)
    • Weight 410 Grams
    • Compatible with Intel socket 775, 1166 and 1366
    The block is fully CNC machined with a media blasted brass top and clear lacquer for protection, which is available in a range of colour including silver, black and bronze. Unlike some of the ranges of the Alphacool blocks this model has ¼” BSP threaded barb holes, which makes it easy to add a range of barbs or compression fittings of your choice.
    You can find out later which fittings will work with this block.
    It has an integrated anodized mounting plate, which has no contact to the hydrophilic area. As well as being 3mm thick, and 2mm thick around the mounting hole section of the mount, it has the capability of being able to mount on 775, 1166 and 1336 Intel Motherboards. The block has its own mounting hardware similar to most blocks on the market to date.
    The base, which is made out of electrolyte copper and is 3mm thick has a rectangle pin base area in the centre with a larger square section for the return flow water around it. The pin base area measures 17mm x 20mm with a square area of 340mm2 and 12 rows of 14 pins, which gives the base 168 pins of 1mm width. The pins are raised 2mm of the base of the block to make flow more, not less, restrictive. The base can easily be removed from the rest of the block by unscrewing the 4 screws on the top of the block, which makes it easy to maintain.
    Flow
    For the restrictive test to see how much the block limits flow, I ran the pump at 12v, and added a Digmesa Flow Meter to the loop, along with normal loop components for a actual loop result. With information recorded once every minute, a total of ten recordings are averaged out and made into simple graphs. Since I use the same setup for each block I test, with all the parts being the same, I am able to compare the restrictiveness of each block to other blocks later on.
    Flow Rate Loop – Laing DDC 1T + XSPC Res Top, 2 Meters XSPC 7/16” Tubing
    Alphacool NexXxoS 360mm Radititor, 2 Alphacool Ball Valves, Disstilled Water
    This is just a basic flow restriction test however - testing this way has it downside, compared to Pressure Drop Testing. This testing is more accurate, as well as faster and easier to do. I will update this review in a few months once I am able to get hold of the right gear for this.
    Thermal Test Specification
    A 5-mount test with 1hour with each mount, 50 minutes ‘warm up’ and 10 minutes of temperature logging.
    • The 775 Test Setup is as follows: Intel Core 2 Quad Q6600 G0 Stepping overclocked to 3.4 GHZ (no lapping) running on a Gigabyte EP45-UD3P motherboard. 4GB (4x1GB) of OCZ DDR2 Sliver memory with Corsair fan module, the motherboard cooling is stock with no extra airflow. Video card is an EVGA 8800GT, also on stock cooling. The power comes from a Zalman 850W Modular PSU, plus a Samsung 500GB Hard drive split into 2x250 GB partitions. Test case is a Le Chuck Test Bench, which has horizontal mounting.
    • The 1366 Test Setup is as follows: Intel Core i7 920 D0 overclocked to 3.6 GHZ (no lapping) running on a Gigabyte UD5 Extreme Motherboard. 6GB (3x2GB) of Patriot Viper DDR3 1600MHz Memory - the motherboard cooling is stock with no extra airflow. Video card is an EVGA 8800GT, also on stock cooling. The power comes from a Zalman 850W Modular PSU, Samsung 500GB Hard drive split into 2x250 GB partitions. Test case is a Le Chuck Test Bench, which has horizontal mounting.
    • The cooling setup I am using is based more around Euro Style, with a few exceptions.
    o Radiator: Alphacool NexXxoS Xtreme III 360mm Radiator 3x Scythe S-FLEX SFF21D Fans @ 1200rpm, I chose this rad, as it has great value for money and good performance to go with it.
    o Radiator: Alphacool NexXxoS Xtreme III 360mm Radiator and 3x Scythe S-FLEX SFF21D Fans @ 1200rpm, (I chose this radiator, as it has great value for money and good performance to go with it.)
    o Pump: I run a Laing DDC 1T with an XSPC res top, also known as the Swiftech MCP350, run at 12V. (I chose this pump, as DDCs seem to be the norm with most users using the basic model.)
    o Loop Order: Optimal to my needs my loop is setup in this order, XSPC Res Top > DDC > Digmesa Flow Meter > 360mm Rad > Temp Sensor (Water In) > Ball Valve > Block Being Tested > Ball Valve > Temp Sensor (Water Out) > Res Top. (For an optimized loop for any set up always have your res feeding the pump.)
    • TIM Material I use MX-2 like most other enthusiasts and testers alike, with it working as soon as you apply it (no break in time like AS5). Also being non conductive, conductive could become a problem with multiple applications per test and multiple blocks. The TIM application method I use is the dot in the center. (small pea sized dot applied to centre of CPU, then when block is Compressed TIM is spread evenly across the cores of the CPU), Recorded data is only used if the TIM application is good after inspection on remount (my way of validating my results)
    Thermal Test Results
    775
    775 Average Temp Over 5 Mounts 28.7°C
    To give a comparison, i have tested the EK Supreme, which was the best 775 Block for some time.
    As you can see, the Supreme is still better than this block by a margin. But as the yellowstone has been designed and developed for i7 CPU's i don't think it did bad at all.
    1366
    1366 Average Temp Over 5 Mounts 32.4°C
    To give a comparison, i have tested the EK Supreme, which was the best 775 Block for some time but has performed poorly against new blocks on i7.
    As you can see, Yellowstone is better then the Supreme, being designed for i7 CPU's it has an advantage to begin with but the Supreme still cools the CPU Well.
    Fitting Compatibility
    Over the past few years we have seen a great increase of fittings available on the market, thanks to emerging companies like Bitspower and TFC, with companies in the fittings market changing and adapting they ranges to suit the needs and the trends of modern water cooling. Thanks to this modern compression fittings and adapters come in many shapes, forms, colours and most sizes. So let’s take a look at what fittings this block can handle.
    As you can see the 3 most common sizes of compression fittings from TFC and Primochill do not fit, which is a shame. I will update with the other companies and smaller fittings once i have sourced them.
    With the thought of guaranteed protection, I would advise you to read Martinm210 advice, which is quoted below.
    “One thing that should be noted on the GTZ is that you need to install a second o-ring to fill in the recessed barb holes. You can use the o-rings from the provided swiftech barbs, they work fine.
    With all that I would highly recommend exercising extreme caution with compression fittings. I've had a few leaks myself with compression fittings and 1/2" ID tubing when you move the tubing around a bunch. Try it yourself, if you can eventually wiggle the tubing out of the fitting, it's not all that secure. I even managed to fry one of my water heaters in radiator testing because one barb leaked out enough to run my test loop dry while I was out of the room, luckily the pump shut itself down, but the heater kept going until it melted and self destructed. Even more luck is I had the entire loop on the test bench, and all the water simply ran off the bench onto the floor. That cost me a $30 heater, which isn't a big deal, but I'd be very careful that you cut the tubing perfectly straight and use channel locks to crank those compression rings as hard as you can. I would also keep a close eye on any tubing that gets moved around much, digging around in your system after all has been leak tested could potentially be enough to work a tube loose just enough and you can't see that since the tube end location is hidden under the retaining ring.”
    Where To Buy
    Considering this block comes in at the high end of the price range with the modest EK Supreme being £39.99, the Alphacool block is a whole £16.48 more expensive. However the build quality makes up for it with it being made fully in Germany to the highest standards. The style makes up for it also. With many colour options, and the all sliver not costing any more than the black and bronze version I tested here, there is an added bonus for you bling loving water coolers out there.
    It was hard finding respectable e-tailors for this block, as some of the most popular shops both in the US and UK simply don’t stock it - however AC-Shop are doing what they do best and came up with the goods. I have included Performances-PCs as it was the only place in the US I could find but I would always prefer to buy from WatercoolingUK, Sidewinders or AC-Shop thanks to all three giving great service, fast delivery and a friendly touch in my experience.
    United States
    Performance-PCS - $89.95
    United Kingdom
    Watercooling UK - £49.99
    Conclusion
    Pros
    • Brass top which makes it really strong – i.e. no cracking, which can occur with acrylic tops
    • ¼” BSP thread barb ports for ultimate compatibility with G1/4” threaded barbs and fittings
    • Variety of colours to suite individual preference and build colour coordinating
    • Multiple Intel platforms for increased compatibility
    Cons
    • No Back Plate Provided (have to buy separately)
    • AMD users have to by separate mounting plate or block as there is no truly universal mounting plate
    • 3/8” and ½” Compression Fittings Don’t fit
    Final Thoughts
    The new Alphacool Yellowstone isn’t just a lovely looking block - it actually performs just as well as it looks. It a great design and works well with both 775 and I7 CPU’s. With an all metal top and bottom, you can easily powder coat the block to your desired colour if Alphacool doesn’t do the colours you’re after. But the main downside and the only one that bothers me is the compression fitting issue, with 3/8” and ½” in both Primochill and TFC Compressions fittings.
    So with the normal German engineering you accept from Alphacool and with great performance on i7 and only slightly worse then the EK supreme on 775. I would recommend this to anyone, who has the budget for it or is looking for a replace block after upgrading from 775 to i7.
    (With Out the following people and companies for amazing help and support, this would not have been able to happen.
    www.watercoolinguk.co.uk www.alphacool.com www.xspc.biz www.skinneelabs.com
    Skinnee from XS, Bundymania from ForumDeluxx, 775matt from WCUK,
    HESmelaugh from ForumDeluxx, Rob* from WCUK, prosser13 from OCN)
    Xtreme Mentor
    Sep 2007
    Dallas
    Nice review. I wonder how it would stack up against the Heat Killer since that seems to be a very popular block right now.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Banned
    Feb 2009
    Bangkok,Thailand (DamHot)
    hmm another good 1366 block
    May 2008
    Vancouver, BC, Canada
    Quote Originally Posted by Utnorris View Post
    This block is not as good as the HeatKiller. It trails by a few degrees. Check HESmelaugh's block showdown from some time ago...
    Xtreme Mentor
    Jun 2007
    Chicago
    Thank you for this review.
    I am simply shocked the ek supreme is doing so poorly on 1366 chips.
    Any idea to why this could be?
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Jul 2008
    Essex, UK
    Thanks for the kind words, Eddie, it is due to the way the block was designed. The core i7 chip is built in a different way with chips being bigger and different shapes.
    Oct 2007
    Burnley
    Nicely laid out reveiw Aaron and awesome photos, getting the hang of the 450D it seems!
    Look forward to the next review.
    Jul 2008
    Winterthur, Switzerland
    Nice thorough review here!
    I'm rooting for you to get more blocks soon so you can add some more data to your comparison charts.
    Banned
    Apr 2008
    Brisbane, Australia
    Quote Originally Posted by Eddie3dfx View Post
    A lot of the once great blocks don't fair so well with 1366 cpus. The FuZion is the best example.
    Jul 2008
    Essex, UK
    Cheers, Marcus & Shane
    MomijiTMO hit right on the head, the deign is so different to 775 cpu's that, they just aren't cut out for it. I hope D-Tek will bring a Fusion V3 out soon for 1366 CPU's (Designed).
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    nice general review!
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    I am Xtreme
    Sep 2006
    Looking forward testing one myself. On my setup the Supreme did very well, following your results it should best the Koolance 350 block. Nice review mate !
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Jul 2008
    Essex, UK
    Nice review bentleya. That mounting bracket looks strangely familiar....
    System :- Gunmetal Antec P182 : Antec Quattro 850 : Asus P5E Deluxe : Intel Q9550 (E0) @ 4004MHz (8.5 x 471 FSB) 1.4 volts (VID: 1.3v) : 8Gb 1100 OCZ Gold XTC @ 942MHz 2.0 volts (5-5-5-15) : Gainward GTX 570 GS GLH (GPU: 800MHz, Shader: 1600MHz, Memory: 2000MHz) : 1x 128Gb Crucial RealSSD + Asus U3S6 (OS) : 1x 1Tb & 2x 500Gb Samsung Spinpoints (Storage) : Microsoft Windows 7 Home Premium (64bit)
    Cooling : 4x Sharkoon Eagle 2000's (Case) : 3x Scythe Gentle Typhoons (R120-T rad) : 4x Scythe Gentle Typhoons (RS 240 rad in push-pull) : Akasa Fan Control Pro : Stepped Aquacomputer Cuplex XT di : EK FC5X0 GTX GW - Nickel (GTX 570) : Swiftech MCP355 : 1x XSPC R120-T : 1x XSPC RS 240 : XSPC Bay Reservoir : XSPC 1/2" Tubing : Blue Feser One Coolant
    Check out my water-cooling case design:- Here & Here
    Find SketchUp Computer Components Here
    Download my case design SketchUp files from Here
    Never go full retard
    Feb 2008
    Vegas
    Well done for your first review Bentleya...we've talked offline, but still wanted to show my support!
    Jan 2008
    Vancouver, Canada
    Awesome job with the review Aaron!
    Great presentation and yummy pics. Looking forward to your next offering.
    Jul 2008
    Essex, UK
    @NaeKuh - Cheers dude .
    @Leeghoofd - The Koolance 350 is on my list but i need to source one, so could be a good while before any more Tests, also Skinnee has Alphacool blocks as well as the Koolance so we will see once he publishes his results.
    @Mick64 - Mick, it dose and i think thats why it looks and feels good
    @Skinnee - Cheers dude, i'll send you an email at the weekend about what we talked about .
    @charles_h - Thanks charles, i feel privileged you posted in one of my threads
    May 2009
    bentleya nice review. Have you gotten the chance to test what compression fittings fit this block? I have tried b.i.t.s.p.o.w.e.r 45-degree compression fittings, and it is not compatible. I wonder if a 45-degree adapter + compression fitting compatible?
  18. #18
    Jul 2008
    Essex, UK
    Quote Originally Posted by nzone View Post
    I have Emailed Vincent A few times and no reply again, as i'm no going to go spend my money on it as i can't afford them.
  19. #19
  20. #20
    May 2009
    I have installation question for Bundymania & Bentleya because you know Alphacool products well. I have Yellowstone and the CoolCover. What is the optimal tightness? Do I need to turn the knurled Knob all the way down until the tube is tight? Thanks.
  21. #21
  22. #22
    May 2009
    Thank you, sir! It's perfect installed illustration. I noticed you didn't use the plastic washer between the tube and the mounting plate. I had the knob almost all the way down too with the plastic washer, and the tube is not tight...I can turn it. However, my classified is kind warped. Thanks! I'm going to try remount the thing.
  23. #23
    Jul 2008
    Essex, UK
    Thanks for sharing more pics bundy , can't wait to add few more colour combos to my collection plus heat master is september.
  24. #24
    Jul 2009
    Question for you guys, in your review you state it does not come with the back plate. I do not see the back plate sold on Perfromance PCS for the states. So which back plate would we need to buy?
    Thanks Chad
    Components;
    »Obsidian 800D
    »CPU: Intel Core i7 940 OC'd to 3.69
    »Motherboard: Evga X58
    »EVGA GeForce GTX 295
    »CORSAIR DOMINATOR 6GB (3x2GB)
    Water cool parts;
    »RAD - EK XT360, EK XT260 & XSPC RS120
    »CPU Block - Alphacool H14 Yellowstone BRB
    »Koolance Northbridge/Southbridge Water Block
    »Black Feeser Mosfet Block
    »EK-FC295 GTX GPU Water block
    »EK-Multioption RES 250
    »2 x Swiftech MCP355™ Water Pump
    »XSPC Dual Acrylic Top
  25. #25
    May 2009
    Install without backplate is fine, but you need to be careful...over tighten the board will bend. I have tried Xigmatek backplate, even though it says M4 screw, it's not compatible with Alphacool's M4 screw. It must have been a mistaken labeling on Xigmatek part. I've just placed an order for Watercool Heatkiller 1366 backplate (stated M4 screw), and I hope it is compatible with Alphacool mounting screws. Crossing fingers.
    Alphacool CPU blocks are nice, but the instruction is mediocre at best. For example, I have the optional CoolCover and the instruction said to tighten knob until...hmmm...to look like Bundy's illustration photo a few posts back. However, for doing so as per instruction, the board will bend like a solar eclipse (crescent). The problem is the spring is too long and the cover tube is too short. Oh well...I hope the Heatkiller's backplate solve this issue.
