Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: EVGA X58 Classified waterblocks roundup (finally!)
    Jul 2008
    Winterthur, Switzerland
    Arrow EVGA X58 Classified waterblocks roundup (finally!)
    This has been a long time coming, I have to admit. The whole review was delayed because two samples were delayed. Anyway, without further ado, here's my review of three EVGA X58 Classified mainboard waterblocks.
    Classified
    I guess by now everyone knows about the EVGA Classified. Thanks to positive reviews and, no doubt, it's visual design, it seems to have become a very popular piece of hardware.
    It is equipped with a notably huge heatsink-combo, but as we will see later on, this heatsink doesn't do it's job very well.
    This is where the waterblocks come in.
    Bitspower Black Freezer
    Bitspower's cooling solution consists of one main waterblock (copper base, brass top, both black nickel plated) called the EIX58NSC and a mosfet waterblock (black nickel plated base, POM top) called the EI58DP II.
    At this point it's worth noting that the Classified's heatsink is modular, so it is possible to watercool the NB/SB and NF chips and leave the air-cooler on the mosfets.
    The design and finish of the Black Freezer blocks is very well done. The nickle plating is almost flawless. Unfortunately, the block i had here still had one blot of slight discoloration. Nothing tragic, but perhaps annoying to perfectionists.
    Here are the blocks' internals:
    EK Waterblocks EK-FB X58 Classified - CF
    EK's block is a full-cover or full-board block. The two nickel plated copper bases are combined with a bridge, acrylic in my case or made of POM if you get the POM-version of the block.
    This bridge can be replaced with a red acrylic one that comes supplied with the waterblock, which is a very nice addition. Also note that both the bridges have two holes for 3mm-LED.
    I found the manufacturing quality on this block to be flawless. The nickel-plating is perfect, all surfaces are smooth and highly reflective and the whole thing just oozes quality. Here are some more pics including internals:
    MIPS EVGA X58 Classified Triple-Chip and Mosfet POM
    MIPS also offer a cooling solution consisting of two parts, much like Bitspower. Both have copper bases and POM tops. I've had a few MIPS parts before and in my experience, they were always pure perfection. Unfortunately, the same can't be said for the block I got here. The POM had some slight blemishes and the copper base was scratched in one place. I assume that this is an exception, though.
    Here are more pics, including the internals:
    Installing the blocks
    I can report that I had no problems whatsoever installing any of these blocks. The one thing I criticized in my installation video for the Bitspower blocks has already been fixed.
    I kind of expected that installing the EK full-cover block might be difficult. After all, it has a lot more screw-holes that need to be aligned and it is one big, rigid thing that needs to be maneuvered past the mainboard's components. But it was actually very easy to install, so no worries there, either. One great advantage of the EK block is that it needs only two fittings and thus makes tube-routing easier. On the other hand, many people like the looks of many tubes in their system, so I guess it also depends on personal taste.
    It's worth noting that the blocks from EK and BP come with thermal pads for the mosfets while the MIPS block uses thermal grease (not supplied) for the mosfets. This is reflected in the cooling performance, as we will see shortly.
    First, here are a few pics of the blocks installed:
    Testing and results
    My setup for these tests consisted of:
    - Laing DDC plus EK X-Res Top
    - 13/10 (3/8" ID) Masterkleer-tubes
    - HWLabs Black Ice GTS 140 Radiator
    - 1x Sharkoon System Fan Power @ 12 Volt on the Radiator
    - 4x analogue Waterprobes
    - 3x digital Temperature probes measuring ambient
    - GMR Flowmeter
    - T-Balancer bigNG and Sensorhub
    Software:
    - Prime95 (small FFT)
    - CPUID HWMonitor 1.4
    No other blocks except the MB-blocks were in this loop. I tested by running Prime95 small FFT for 45 minutes and then noting water, ambient and VREG (mosfet) temperatures. I also logged and noted the flowrates achieved.
    Let's get to the results.
    Now, the thing is, that the Classified won't let software running from the OS (like Everest, HWMonitor and many more) know the NB-temperatures. This is probably because the NB temperatures suck with the original heatsink. So what I did was reboot the system after the 45 minute load run and boot directly to the BIOS, where the NB temperature can be seen. It's important to note that the NB temps aren't full-load temps. They are on the way down by the time I see them in the BIOS.
    Flow
    The image really speaks for itself, here. I only want to add that, in my opinion, the three blocks are as close as makes no difference in flowrates. I wouldn't choose one over the other just for this factor.
    Temps 1
    Here are the temperatures measured shown as the difference between the components temperature and the water-temperature:
    Again, the image speaks for itself and again, you can see that it's a pretty close call.
    Temps 2
    To put this into perspective, I want to compare the temperatures to those measured with the original heatsink on. To do this, I compare the components temperatures minus ambient temps. Note that there's room for variance in here, since the waterblocks depend on water temperature which in turn depends on radiator size and performance. In other words: results may vary.
    The reason I want to show this comparison is because it shows that the temperatures with the original heatsinks are pretty bad and with watercooling, they are way better, regardless of which block is used. Again, in my opinion, the results are as close as makes no difference.
    Ultimately, I have to admit that this is one of my less useful reviews, since it simply shows three candidates practically on par with each other. Still, that's good news for you if you're looking for Classified waterblocks since it means you can pick the ones you like the looks of most.
    Cheers,
    Shane
    P.S.: Here's my installation video guide for this mainboard: Link
    Jun 2009
    East Bay, California
    Sweet thanks for the review!
    I have the EK block and am happy to see it holds up well!
    i7-920
    EVGA X58 SLI Classified E760
    6GB G.SKILL Perfect Storm PC3 16000 8-8-8-21
    EVGA GTX-285 x2 SLI
    X25-M G2 80GB
    CORSAIR 850HX PSU
    SilverStone TJ07
    HK Rev3 LT / EK-FC285 x2 / EK-FB Classified / MCP355 + EK X-Top x2 / Magicool Elegant 360 / XSPC RX240 / EK 250 Res / Swiftech MCRES / PrimoFlex 3/8 tubing
    Notebook:
    EON18
    i7-840QM
    Dual HD 5870m 1GB
    4GB Kingston 1333 MHz RAM
    3 x 250GB 7200rpm SATA 300 HD RAID 0
    Jan 2009
    Torrance, CA
    Great review - thanks for posting!
    the Borg Cube:
    Case - Lian Li PC-343B
    Mobo - EVGA X58 Classified (759)
    CPU - i7 920 (D0 stepping), watercooled w/Enzotech Luna Rev.A block
    RAM - Corsair Dominator GT 2000 (8-8-8-24) w/fan
    GPU - EVGA GTX295 quad-SLI, water cooled w/Koolance NX295 blocks
    PSU - Corsair HX1000
    O/S - Windows 7 RC build 7127
    Feb 2008
    Russia
    Wow! Thanks for this! Bitspower is worth of buying
    Intel Q9650 @500x9MHz/1,3V
    Asus Maximus II Formula @Performance Level=7
    OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
    OCZ SSD Vertex 3 120Gb
    Seagate RAID0 2x ST1000DM003
    XFX HD7970 3GB @1111MHz
    Thermaltake Xaser VI BWS
    Seasonic Platinum SS-1000XP
    M-Audio Audiophile 192
    LG W2486L
    Liquid Cooling System :
    ThermoChill PA120.3 + Coolgate 4x120
    Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
    Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
    Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
    3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
    Apple MacBook Pro 17` Early 2011:
    CPU: Sandy Bridge Intel Core i7 2720QM
    RAM: Crucial 2x4GB DDR3 1333
    SSD: Samsung 840 Pro 256 GB SSD
    HDD: ADATA Nobility NH13 1GB White
    OS: Mac OS X Mavericks
    Apr 2008
    The POM surface from the Mips block you can clean with a kitchen paper.
    Jul 2008
    Quote Originally Posted by Six View Post
    Unfortunately, that doesn't make a difference. I tried cleaning it off before taking the pictures, of course.
    It seems to be a discoloration in the material itself, not just a smuge on top of it.
    Jul 2009
    Great review HES.
    I'm picking up the EK block very soon
    [Project] Lateralus
    Intel i7 920 DO @4.2gz /H20
    EVGA Classified 760 /H20
    EVGA GTX275 715/1600 /H20
    6gb Corsair Dominator CL7
    Auzentech X-fi Forte
    Intel X25-M G2 80gb
    WD Black 1TB
    Corsair 1000HX
    Custom Silverstone TJ07
    Xtreme Cruncher
    Jul 2007
    @ the computer
    wow those are pretty big differences. are there any reason why the gigantic stock heatsink does such a bad job?
    [SIGPIC][/SIGPIC]
    Apr 2008
    Ottawa, Canada
    Damn this review makes me want to spend a tonne of money! Thanks for the review and it's nice to see this kind of review in here to show that sometimes cooling the board can be beneficial.
    You know I am not taking all the heat for spending money. I will direct her anger towards this thread when she asks where the money is going. Oh your in trouble now!
    Xtreme Guru
    May 2009
    Southfield, MI
    Was there any airflow around the board when you tested the stock heatsink? Was it benched, or in a case. I'm just wondering as those temps seem really high.
    Great review though. It's nice to see that the EK holds its own seeing its all one piece.
    Project Millertime: The Core I5 build
    Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
    Jul 2009
    I meant to ask HES,
    In the flow rates etc. Does that include the mosfets? You said it's only the MB block. I would assume you used the mosfet blocks also to make it fair for the EK block though, but it doesn't hurt to ask
    [Project] Lateralus
    Intel X25-M G2 80gb
    WD Black 1TB
    Corsair 1000HX
    Oct 2006
    Indonesia
    nice test, to bad i can't see the picture, dunno why
    Xtreme Guru
    May 2009
    Southfield, MI
    hmm, they are working for me.
    Mar 2007
    Looks like my money was well spent!
    Thanks for the work.
    Jul 2008
    Quote Originally Posted by millertime359 View Post
    I tested it on an open bench and with the stock aircooler on the CPU, so there was some airflow. In a case, you'd probably get more airflow, but on the downside, you'd also get warmer air, so I guess results would be similar.
    Quote Originally Posted by Armitage View Post
    I meant to ask HES,
    Yes, by "MB blocks" I meant the entire thing with the main block as well as the mosfet block.
    Quote Originally Posted by Boyu View Post
    You can't see any of them? That's strange.
    Jul 2008
    Update:
    One of the manufacturers of the MIPS-blocks has been pursuing the issue with the blemishes on the blocks that I got for testing. First of all, this shows that these guys are dedicated to delivering a flawless product and I think that's a very good sign.
    Anyway, I tried cleaning it again and this time, I used a cleaning-foam. I was afraid to use this before since I wasn't sure if it would affect the POM. It didn't though, and the blemishes could be (mostly) cleaned off. Here's what the block looks like now:
    I also want to add that I'd still vouch for MIPS products. Of all the ones I've seen so far, this block was the only one with any kind of flaw.
    Jun 2004
    This roundup can help the Classified users quite well. Nice idea @HESmelaugh, I really like it.
    Keep up the good work mate.
    Extreme ways I know will part the colors of my sea, perfect color me | Arthur's WC Worklog with Lian Li PC-9
  18. #18
    Visitor
    May 2008
    Gut
  19. #19
    Xtreme Guru
    May 2009
    Southfield, MI
    Quote Originally Posted by HESmelaugh View Post
    Ok, that's what i thought. I would think you could still get the temps to a reasonable spot with a fan blowing on it, but I would think you couldn't get them as low as water is.
    Once again, great review. Thanks for taking the time.
  20. #20
    Jul 2008
    Yep, with some direct airflow, I'm sure it would do better. On the other hand, in your usual air-cooled setup, you probably wouldn't have any fans blowing at it directly...
    One way or the other, usually, the stock cooling solutions do better, even on the bench and without airflow.
    Six, the guy who makes the MIPS blocks, or is involved in making them, says that the block I got was probably an RMA'd one. If they see a block with scratches or blots on the surface, they don't ship it.
  21. #21
    Jan 2009
    Torrance, CA
    Does the EK version have LED(s) for that piece that connects the NB and VReg?
    the Borg Cube:
  22. #22
    I am Xtreme
    Feb 2003
    Netherlands
    Pretty surpised to see the BP having the least restiction. The BP NB/SB block i had for my Rampage Extreme was very restrictive to say the least.
    Very nice review!
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
  23. #23
    Jul 2008
    I guess it depends on what you're compaing it to. In my comparison between the BP and Koolance RIIE blocks, the BP blocks were also the less restrictive ones. On the other hand, if you compare the restriction of the blocks vs. no blocks, you'll get a different picture.
  24. #24
    Jun 2004
    Quote Originally Posted by Zeus View Post
    Very nice review!
    I'll be bought my Bitspower Black Freezer AIX48NSE NB+SB Combo Block for my RE X48 soon. Because of that I could not find any combo block for RE X48 around thats why I'll buy it.
    Can I ask what is your experiences about Bitspower Black Freezer AIX48NSE NB+SB Combo Block generally? I suppose we talking about same block here.
    Any help would be great to me.
    Thanks,
    Arthur
  25. #25
    Jul 2008
    Well, I don't have any personal experience with the AIX48NSE, but the two Bitspower MB blocks I've tested so far were both very good. If nothing else, it's an indication that the manufacturers generally know what they're doing.
