XtremeSystems Forums
View Poll Results: Do you like my case design?
Like 520 94.89%
Dislike 28 5.11%
Voters: 548. You may not vote on this poll
Reply
Old 03-04-2009, 02:28 PM   #1
Mick64
Mick64's Avatar
Send a message via MSN to Mick64
Case Design for Liquid Cooling
I'll probably get shot for starting another thread featuring my case design, but I thought, as it has been specifically designed for liquid cooling, why not see what you guys thought of it. Specifically, those who don't frequent the computer case forum, or those who may not be interested in looking at the Render Gallery.
The dimensions of the case are: depth - 680mm, width - 230mm, height - 620mm and because of its size, will probably be constructed from aluminum. It can accommodate a 480 (120.4) rad in the top and a 360 (120.3) rad in the bottom. The case width would allow a push-pull configuration of 38mm fans, 38mm shrouds, rad of choice, 38mm shrouds, and 38mm fans. There is enough room for a long PSU if required, and the motherboard tray will except an extended ATX motherboard. There are 3 5.25" drive bays and room for 4 HDD's. Case cooling is provided by a single 200mm intake fan at the front, a single 120mm exhaust fan at the rear, plus the flow provided by the PSU fan. The is plenty of room in the centre section for a couple of pumps and reservoirs and I've provided routes for cables and tubing. I think that's most of the information you would want to know. Please let me know what you think. I am hoping to get it put into production, and have contacted a couple of well known case manufactures. I haven't heard anything back yet, but if I can show them that it would be a popular case, I'm sure one of them would be interested...
Updates.....
__________________
System :- Gunmetal Antec P182 : Antec Quattro 850 : Asus P5K Premium/WiFi-AP : Lapped Intel Q6600 (G0) @ 3800MHz (8 x 475 FSB) 1.54 volts (VID: 1.2750v) : 2Gb 1100 OCZ Gold XTC @ 950MHz 2.2 volts (5-6-6-15) : BFG 8800 GT (GPU: 700MHz, Shader: 1750MHz, Memory: 1000MHz - 2000MHz Effective) : 2x 80Gb Western Digital Raptors in raid 0 (OS) : 2x 500Gb Samsung Spinpoints in raid 0 (Storage) : Microsoft Windows XP Pro (32bit)
Cooling : 3x Sharkoon Eagle 2000's (Case) : 3x Xilence Pro Fan 120L 1400RPM Blue LED (R120-T rad) : 4x Yate Loon D12SM-12's (RS 240 rad in push-pull) : Akasa Fan Control Pro : Stepped Aquacomputer Cuplex XT di : XSPC Full Cover Razor (8800 GT) : Swiftech MCP355 : 1x XSPC R120-T : 1x XSPC RS 240 : XSPC Bay Reservoir : XSPC 1/2" Tubing : Blue Feser One Coolant
Check out my water-cooling case design:- Here & Here
Find SketchUp Computer Components Here
Originally Posted by No1451 View Post
Someone really needs to take the plunge and get this thing built. It's great as is but until it gets put into hard format it's a lot like masturbation, fun but ultimately it isn't going to get you anywhere.
Originally Posted by kinghong1970 View Post
So, um... Mick... stop jerking us off and make the damn case already!!!!
Mick64 is offline   Reply With Quote
Old 03-04-2009, 02:35 PM   #2
faster3200
faster3200's Avatar
That is a very nice design for a case. I am assuming you will put holes in the compartments to route tubing. If you could make that for around or less than $300 I would buy one. Maybe change the back 120mm to a 140mm (kinda nitpicky though). Otherwise, it is a VERY nice design.
Good luck on getting a manufacturer to make it. Other than MM or DD no one makes a case that would only be useful to WCers.
faster3200 is offline   Reply With Quote
Old 03-04-2009, 02:36 PM   #3
exemay
exemay's Avatar
i saw you post this on the render gallery.....and i gotta say, its an amazing looking case, id certainly buy one...personally i much prefer the look of this case to any MM or silverstone case
although the only criticism i have is that i would rather have another 3 or 4 bays instead of the side mounted HD rack and fan...thats just my opinion other than that its perfect! very nice work indeed!!!
__________________
yea.. i need help... seriously......last time i went to the bathroom, it seems that the male has the pecker that pokes the female, right?
i'm confused...
Originally Posted by lennox View Post
holy cow do you really run 1/2" tubing without clamps? that's like banging a prostitute without a condom!
Lian Li V2000B Special Water cut: DFI LanParty X48 LT T2R : Q6600 @3.21 ghtz : 2x Samsung Spinpoint F1 32mb cache 1tb HDD's : HD 4870x2 : 4GB domminator : Swiftech GTZ block : PA120.3 : DCC 18w res top : DCC 18w res top : EK FC 4870x2 :
Current Project:
http://www.xtremesystems.org/forums/...d.php?t=214295
exemay is offline   Reply With Quote
Old 03-04-2009, 02:36 PM   #4
Sadasius
Tygon Warrior
Sadasius's Avatar
I love the design of this case. So much can be done with it and I do hope you get this into production. I would buy one. I would make a door for it though but that's just me and because I have kids so I tend to pick cases with front doors to keep little fingers away from buttons and shiny things.
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 03-04-2009, 02:38 PM   #5
exemay
exemay's Avatar
just noticed your profile....your from essex, id deffo buy 1!!!! id even come pick it up! make these cases for the good of the people now! hehehe
__________________
i'm confused...
Current Project:
Old 03-04-2009, 02:38 PM   #6
viccan
I am Xtreme
viccan's Avatar
Send a message via AIM to viccan
I'd buy it I really like the interior layout well.
Wonder if the price would be sub $300 if so then definitely.
Good luck!
__________________
Q9650-OC@4.2gHz (full time)
Asus RAMPAGE EXTREME
Swiftek Apex Ultra Cooling Kit
4 Gig Patriot DDR3 2000L
ATI 4870x2 2Gig DDR5
BFG 285 GTX OC 1gig (just for physX)
WD Raptr150 + SG 750 x2
Thermaltake Speedo Advanced Ed
BFG 1000watt EX series PSU
viccan is offline   Reply With Quote
Old 03-04-2009, 02:42 PM   #7
SoulsCollective
Xtreme Cruncher
SoulsCollective's Avatar
Looks like a LiLi, a good one too. I'd hit that.
wut? Are you saying eATX will fit or it won't? I'd ordinarily presume you meant "accept", except that the rest of your post is fine
Edit: It's a little hard to tell, but going by the scale of the above pics it looks like you could whack another HDD cage right after the first one and still have room for extra-long VGAs - yes? This would definitely be appreciated by those of us with six or more HDDs.
__________________
Rig specs
CPU:
i7 920 @ 3.8GHz Mobo: eVGA Classified 760 RAM: 3x2GB OCZ DDR3-1866 Reapers @ 1,800, CAS-8 VGA: Sapphire HD5870 @ Core 900 Mem 1,250
HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520 SFX: Auzentech X-Fi Prelude
PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 RTM x64
Liquid-cooled
Sub-loop One
: EK-Supreme -=- MCR320, 3x Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Sub-loop Two: EK Classified FC -=- 2x MCR120, Scythe S-FLEX "F" fans -=- 7/16" Pro-LRT -=- 7/16" BP compressions-=- MCP655 w. Typhoon III
Peripherals
Dell 2408WFP rev.A01 -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
SoulsCollective is offline   Reply With Quote
Old 03-04-2009, 03:06 PM   #8
Mick64
Mick64's Avatar
Sorry! never been that good at spelling. LOL
__________________
Old 03-04-2009, 03:14 PM   #9
NaeKuh
Broken Gainestown
NaeKuh's Avatar
get it on solid works and see if ben at MM can make it. :P
__________________
Nadeshiko: i7 980 12GB DDR3 eVGA Classified
Lind: Dual Gainestown 3.07
NaeKuh is offline   Reply With Quote
Old 03-04-2009, 04:02 PM   #10
twwen2
twwen2's Avatar
I'd hit it
Seriously though, that's gotta be the best case design i've seen in a long time. In the right finish it would also look spectacular.
__________________
Originally Posted by b@llz0r View Post
i didnt have a girlfriend before i got into watercooling....
... now I have a cat.... her name is mittens
HW: E8600@4GHz||DFI JR-P45 T2RS||ATi HD4870||4GB Corsair 8500C5DF||640GB WD6400AAKS||Vista Home Premium x64
WC: EK Supreme||EK-NB S-Max||EK-FC 4870||PA120.3||DDC3.2+Petra's top||EK 150 res
Sense and Sensibility [My build log]: http://www.xtremesystems.org/forums/...d.php?t=201235
twwen2 is offline   Reply With Quote
Old 03-04-2009, 04:12 PM   #11
Talwin
great work
I'd buy one
__________________
Specs:
Intel Pentium Q6600 @ 3.6ghz - 1.34v / 1.33v loaded - 9x400
Tuniq 120 Tower with MX-2 thermal paste, CPU lapped but not HS (was dead flat from factory)
Gigabyte "GA-P35-DS4 (rev. 2.0)" Mobo
Corsair TWIN2X2048-6400C4 @ 4-4-4-13-29, 1:1, 1.91v
XFX Fatal1ty Edition 8800GTS Core @ 650, Memory @ 2000
2 x Seagate 80gb HDD [Raid 0] (O/S and Games)
Seagate 500gb HDD
Seagate 1000gb HDD
Silverstone 1000w PSU
Talwin is offline   Reply With Quote
Old 03-04-2009, 04:13 PM   #12
Pedalmonkey
Send a message via AIM to Pedalmonkey Send a message via MSN to Pedalmonkey Send a message via Yahoo to Pedalmonkey
id take one. IDK the dimensions but i bet u could fit 2 480's in the bottom and 2 360's in the top. might make it a bit more for the extremeists here lol
__________________
Pedalmonkey is offline   Reply With Quote
Old 03-04-2009, 04:26 PM   #13
ILikeCosmosS
Banned
its taking the idea of tj-07 but x2 notice the top can hold two rads as well?
i would definatly but this if i needed that much cooling
ILikeCosmosS is offline   Reply With Quote
Old 03-04-2009, 04:32 PM   #14
[XC] junglemaster
Dave's Woodzilla Holder
[XC] junglemaster's Avatar
Send a message via MSN to [XC] junglemaster
Nice work mate. Really nice design with some real thinking of what people want / desire / need.
__________________
[XC] junglemaster is offline   Reply With Quote
Old 03-04-2009, 04:38 PM   #15
Erdrick1980
i must say, that is one beautiful looking case man.. I buy one in a heart beat.
Erdrick1980 is offline   Reply With Quote
Old 03-04-2009, 04:47 PM   #16
tuanster1119
tuanster1119's Avatar
I would definitely be interested in one of these. That design is amazing.
__________________
System
:: CM ATCS 840 :: Intel C2D e8600 @ 4.0ghz :: Asus P5Q Pro :: GeIL Black Dragon 8GB (4 x 2GB) :: Asus Radeon HD4890 ::
Cooling
:CPU:
:: MCP350 w/ EK DDC X-Top v2 :: EK Supreme LT :: DD 5 1/4 Bay Res :: MCR320 :: 120mm Yate Loon D12SL-12 ::
:GPU:
:: MCP350 w/ EK DDC X-Top v2 :: EK-FC4890 CF Nickel :: MCR240 :: DD 5 1/4 Bay Res :: 120mm Yate Loon D12SL-12 ::
tuanster1119 is online now   Reply With Quote
Old 03-04-2009, 04:54 PM   #17
Jokester_wild
Jokester_wild's Avatar
Yep Id buy one, best case design I have seen.
__________________
Lian Dream: Intel Q6600 @ 3.6ghz 455mhz, Asus Formula Maximus Evga GTX 280, Mushkin 8500 2x2GB @ 540mhz, Seagate 500g, Plextor PX-755SA, PC P&C Silencer 750 Quad, Lian-li
HTPC: E5300, Asus P5Q Pro Turbo, Gigabyte 7600GT, Crucial Ballistix 1GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, PC P&C 510, Silverstone LC16m
Nikon D90 ~ Nikkor 18-200mm VR ~ Nikkor 50mm F1.8 ~ Sigma 10-20mm
Lian Dream Work Log
Heatware
Jokester_wild is offline   Reply With Quote
Old 03-04-2009, 05:25 PM   #18
dreamaxx
dreamaxx's Avatar
That case looks sweet, but its a shame the big front fan blows hot air through the HDDs, means hot air into the case. Not such a big deal if everything including ram is watercooled, but if you're not looking to watercool everything then some components may get a little warm. I like the TJ07's layout in that the hot air from the HDDs is blown straight out the side. I'm sure you could put one HDD cage up the top and leave a little more space for the pump/reservoir within the main compartment.
But it is a lovely looking case!
dreamaxx is offline   Reply With Quote
Old 03-04-2009, 06:27 PM   #19
faster3200
faster3200's Avatar
I don't think the HDs dump too much heat, and it is always good to cool them. Assuming you only have the vid card and cpu WCed I can't see the extra heat effecting anything. Notice how even the major ram OCers only have a fan on them.
Old 03-05-2009, 12:51 PM   #20
Mick64
Mick64's Avatar
Thanks for your support guys! I'm going to add a poll, a simple 'Like' or 'Dislike' just to get a feel of just how popular the design is. Positive, I hope.....
__________________
Old 03-05-2009, 01:53 PM   #21
tuanster1119
I honestly don't think you're going to find too many people who don't like this design.
__________________
System
Cooling
:CPU:
:GPU:
Old 03-05-2009, 02:28 PM   #22
Mick64
Mick64's Avatar
Just had some good news. Got a reply from one of the case manufacturers I contacted, and they really like how it looks. Sounds promising!
__________________
Old 03-05-2009, 02:37 PM   #23
ILikeCosmosS
Banned
i would love to buy it
but if i got couple more grand to build a wc with 2 quad and 2 triple rads i would
otherwise i would buy it
this is case would be called the tj-07 + edition (because of the top compartement for quad rad)
Edit: can you show a picture of the clearance from the motherboard to the hdd/5.25 bays?
if possible ek res's can be there
are 38mm fans loud? with shrouds?
Old 03-05-2009, 02:42 PM   #24
Sadasius
Tygon Warrior
Sadasius's Avatar
Awesome! Which one so we can hound them to use your design?
__________________
Old 03-05-2009, 02:52 PM   #25
MrToad
I am Xtreme
MrToad's Avatar
Hopefully not TT :P
I'd hate to see what they would do with it
__________________
Originally Posted by fart_plume View Post
First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
MrToad is offline   Reply With Quote
Reply
Tags
case, cooling, design, liquid, render
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
