Hi guys!
Just a short report here.
I tested the EK Supreme on an i7 920 with two different orientations to see if it made a difference.
This is what the test-systems consists of:
- i7 920 Vcore: 1.28
- Asus P6T
- MCP355 with EK X-Res Top
- XSPC RS360 radiator with three Nanoxia FX-1250 fans @ 1200rpm
- Four analogue temperature probes in the water
- Three digital temperature probes measuring ambient
Software:
- RealTemp 3.00 logging core temps
- T-Balancer software logging water and ambient temps
- CoreDamage burning CPU for 40 minutes per test run, values averaged out for the last 20 minutes of each run.
Flow: constantly at 250 l/h during the test-runs.
Orientations
There are two orientations that matter IMO: Directing flow along the "length" of the die and directing flow accross the "length" of the die.
I named A "Vertical" and B "Horizontal", because that's the direction the water flows in when the CPU is installed on a mainboard in a normal case.
Here are the results of the three runs for each orientation, shown in temperature difference between Water and all core temps averaged out:
As you can see, it makes absolutely no difference. The differences we see here are all well within the margin of error, so it seems that with the Supreme, the i7 doesn't care what direction the flow is going in.
Hope you enjoyed this small report.
Cheers,
Shane
