View Poll Results: Aluminium or Steel
Voters
562. You may not vote on this poll
  • Aluminium
    471 83.81%
  • Steel
    91 16.19%
Results 1 to 25 of 573
Thread: What do you think of my "water cooling" case design?
Threaded View
    Jul 2008
    Essex, UK
    Hi all in the Computer Cases section. I normally hang out in the Liquid Cooling section, but I've been working on a case specifically for water cooling and thought I'd see what you guys thought of it.....
    If I get a favourable reaction, I may post some more renders showing other views of this case. I may even look into getting it made....
    System :- Gunmetal Antec P182 : Antec Quattro 850 : Asus P5E Deluxe : Intel Q9550 (E0) @ 4004MHz (8.5 x 471 FSB) 1.4 volts (VID: 1.3v) : 8Gb 1100 OCZ Gold XTC @ 942MHz 2.0 volts (5-5-5-15) : Gainward GTX 570 GS GLH (GPU: 800MHz, Shader: 1600MHz, Memory: 2000MHz) : 1x 128Gb Crucial RealSSD + Asus U3S6 (OS) : 1x 1Tb & 2x 500Gb Samsung Spinpoints (Storage) : Microsoft Windows 7 Home Premium (64bit)
    Cooling : 4x Sharkoon Eagle 2000's (Case) : 3x Scythe Gentle Typhoons (R120-T rad) : 4x Scythe Gentle Typhoons (RS 240 rad in push-pull) : Akasa Fan Control Pro : Stepped Aquacomputer Cuplex XT di : EK FC5X0 GTX GW - Nickel (GTX 570) : Swiftech MCP355 : 1x XSPC R120-T : 1x XSPC RS 240 : XSPC Bay Reservoir : XSPC 1/2" Tubing : Blue Feser One Coolant
    Check out my water-cooling case design:- Here & Here
    Find SketchUp Computer Components Here
    Download my case design SketchUp files from Here
Tags for this Thread
