Results 1 to 25 of 227
Thread: Cases with all internal Water Cooling from the Gallery
Threaded View
    Mar 2008
    Oslo, Norway
    UPDATE!
    Only work logs seems to be working. Something has happened to the way the posts are numbered, so all direct links to posts are
    invalid.
    Currently in progress of sorting out bad links.
    It maybe is interesting for some to see what cases there are that can accommodate all internal water cooling.
    The requirements are pretty simple, all internal components. For work logs the case MUST be
    finished.
    * = worklog thread.
    Akasa
    Alienware
    Antec
    - 300
    http://www.xtremesystems.org/forums/...&postcount=100
    http://www.xtremesystems.org/forums/...&postcount=126
    - 900
    * http://www.xtremesystems.org/forums/...d.php?t=211950
    - 1200
    - P180
    http://www.xtremesystems.org/forums/...ostcount=10285
    - P182
    http://www.xtremesystems.org/forums/...&postcount=118
    - P183
    - P190
    - SLK3000B
    - Solo
    CoolerMaster
    - ATCS 840
    - CM690
    http://www.xtremesystems.org/forums/...d.php?t=223930
    - Cosmos 1000
    - Cosmos S
    http://www.xtremesystems.org/forums/...9&postcount=58
    - HAF932
    http://www.xtremesystems.org/forums/...&postcount=449
    - Stacker 830
    - Stacker 831
    - Stacker 832
    - Stacker STC-T01
    * http://www.xtremesystems.org/forums/....php?p=3755035
    http://www.xtremesystems.org/forums/...postcount=6440
    - Wavemaster
    http://www.xtremesystems.org/forums/...&postcount=111
    Danger Den
    - Double-Wide
    http://www.xtremesystems.org/forums/...2&postcount=26
    - Tower 16
    Gigabyte
    Koolance
    Lian Li
    - A05
    - 343B
    * http://67.90.82.13/forums/showthread.php?t=151109
    - G70
    * http://www.xtremesystems.org/forums/...d.php?t=214816
    * http://www.xtremesystems.org/forums/...=196647&page=2
    - PC-V1100
    http://www.xtremesystems.org/forums/...6&postcount=38
    ********************** Fixed to here *************************
    MountainMods
    - U2-UFO
    http://www.xtremesystems.org/forums/...49&postcount=4
    http://www.xtremesystems.org/forums/...66&postcount=7
    - Horizon
    http://www.xtremesystems.org/forums/...4&postcount=35
    - UFO Duality
    http://www.xtremesystems.org/forums/...&postcount=155
    * http://www.xtremesystems.org/forums/...d.php?t=220377
    - Pidestal
    * http://www.xtremesystems.org/forums/...&postcount=145
    - Pinnacle 24
    http://www.xtremesystems.org/forums/...&postcount=223
    * http://www.xtremesystems.org/forums/...d.php?t=221416
    NOX
    - HX
    http://www.xtremesystems.org/forums/...&postcount=850
    NZXT
    - Tempest
    http://www.xtremesystems.org/forums/...&postcount=177
    PC Design Labs
    - QV2E
    http://www.xtremesystems.org/forums/...23#post3953823
    Rocketfish
    http://www.xtremesystems.org/forums/...54&postcount=5
    http://www.xtremesystems.org/forums/...0&postcount=27
    http://www.xtremesystems.org/forums/...8&postcount=72
    http://www.xtremesystems.org/forums/...&postcount=502
    Silverstone
    - TJ07
    http://www.xtremesystems.org/forums/...9&postcount=24
    http://www.xtremesystems.org/forums/...3&postcount=39
    http://www.xtremesystems.org/forums/...0&postcount=71
    http://www.xtremesystems.org/forums/...3&postcount=74
    http://www.xtremesystems.org/forums/...0&postcount=95
    http://www.xtremesystems.org/forums/...9&postcount=99
    http://www.xtremesystems.org/forums/...&postcount=104
    http://www.xtremesystems.org/forums/...&postcount=205
    http://www.xtremesystems.org/forums/...&postcount=211
    http://www.xtremesystems.org/forums/...&postcount=258
    http://www.xtremesystems.org/forums/...&postcount=295
    http://www.xtremesystems.org/forums/...&postcount=366
    http://www.xtremesystems.org/forums/...&postcount=497
    http://www.xtremesystems.org/forums/...&postcount=499
    http://www.xtremesystems.org/forums/...&postcount=580
    http://www.xtremesystems.org/forums/...&postcount=641
    http://www.xtremesystems.org/forums/...&postcount=158
    http://www.xtremesystems.org/forums/...24&postcount=1
    http://www.xtremesystems.org/forums/...&postcount=923
    - TJ09
    http://www.xtremesystems.org/forums/...9&postcount=73
    http://www.xtremesystems.org/forums/...&postcount=286
    http://www.xtremesystems.org/forums/...&postcount=594
    http://www.xtremesystems.org/forums/...&postcount=623
    http://www.xtremesystems.org/forums/...&postcount=652
    - TJ10
    http://www.xtremesystems.org/forums/...&postcount=460
    Thermaltake
    - Armor
    http://www.xtremesystems.org/forums/...6&postcount=45
    http://www.xtremesystems.org/forums/...0&postcount=49
    http://www.xtremesystems.org/forums/...5&postcount=62
    http://www.xtremesystems.org/forums/...&postcount=516
    - Spedo Advance
    http://www.xtremesystems.org/forums/...&postcount=619
    - Xaser VI
    http://www.xtremesystems.org/forums/...&postcount=605
    http://www.xtremesystems.org/forums/...&postcount=906
    I Are DuneCat
    I Controls The Spice
    I Controls The Universe
    Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
    D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
