[BiP]Project: Duality (LianLi V1000b)
Hi there dear watercoolers and crazyheads !
Like I've been showing in the wc-ed case gallery, there is my V1000b II Plus, I've been able to buy this case about 8 months ago, it stood in a corner just like that, but in my brains, the ideas were showing up, one by one ...
The good thing about is that I've got the windowpanel and the non windowpannel.
This is gonna be my spare/lan/allround/everything rig, but actually my 2nd pc, al the hardware from the stacker build moved to here, plans are dual loops, with 2 colors of funky or well passing tubing colors.
hardwarelis !
- Asus P5K Deluxe (SB@Thermalright HR05-IFX) MCW30
- E6750@3.6Ghz
- 6GB corsair PC6400 with dominator fan.
- 2,64TB WD disks (4x500, 2x320)
- HD4870
- Antec Neo He 550 with sleeving !
- DVD BURNER !
- Zalman MFC1 Plus
Koelingslijstje
* Loop 1
- MCP355 w/ EK X-top V2
- D-tek Fuzion V2 or somethin' else, maybe changing from time to time
- multires 150
- Good ol' Thermochill PA120.2
- Yate Loon fans
- Red Tubing
* Loop2
- MCP355 met X-top V2
- ek multires 150
- EK mosfet blocks that I've bought from Coolfris
- MIPS asus universal freezer for the NB, also from Coolfris
- MCW60-R for the GPU !
- black tubing
- Swiftech MCR220
- XSPCRX120
- Yate Loon fans
I want to make it a tight pc, nice looking, bit of bling (BP love !).
Reason why I bought this was by coolfris' rebuild of his V1000, I want to make it all internal except the XSPC RX120 witch will be on the back.
Also, I don't want to screw this case, 'cause I'm havin' a sympathy for it.
Ow jeah, 'ffcourse I've got picca's from the fresh case!
FRESH LIKE A FISH.
Opened.
There's more, I've been really thinkin' and searchin' for ideas for about a week, and to work on it, most of the drilling work and jigsawin' and filin' is done.
Than offcourse you always has to start with some mockups of the watercooling gear
trials
bit of sanding
prepared the sketches for the radgrill
after the primary mods
more sanding
test fit of tubing in the tubingholes
This is where my good ol' PA120.2 will stay for many years, hole needs some more filing
got some slippers
HALOWA mates !
some fumbeling in the cellar
cabledrainpipe (in dutch we say "goot", "goot" is in english a drain .. :crack
That's the start, updates will follow very smoothly, 'caus it's almost finished, I just wasn't in the mood to translate the whole log in to english.
BTW, I also started allready with my V2000 build, so day 'n nite disappeared into a box (never gonna throw it away though, it carry's a lot of evolution, thinkering, first watercooling experience etc ...).
Soon to be more !
