So currently this is my set up (ignore the dust)
Antec 1200 case with MCR320 push/pull in the bays with two HDDs in the top
(crappy pic with flash)
MCR320
HDDs
View from behind
Side view no flash with panel on
Side view no flash with panel off
Side view flash with panel off. Ok there's some stuff that I need to do as far as cable management as you can see but I need to extend the cables first before I can do that I need some stuff first before I can do that
So basically the plan is to cut out holes for a MCR320 on either side of the front of the case to make it into a paraflow system like so (complements of someone from this forum)
Along with that I'm going to be mounting two, perhaps three, reservoirs inside the case on the back of the bays (because air won't need to flow in from the front any more) and try and fit in a standard size DVD drive in the top. It'll be interesting, wish me luck.
Oh and I put in an internal bluetooth dongle and got a cell's bluetooth headset to work with my computer so I can use the headset for online games =)
