Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
Thread: [Project] Water-Cooled HAF 932, Painted Satin Black
    Sep 2008
    Las Vegas
    Arrow [Project] Water-Cooled HAF 932, Painted Satin Black
    OK, I've finally got all the parts. Everything has worked out perfect. I just started tonight, I'll be taking my Sig Rig, and making it into a Water-Cooled HAF.. Yet to be named, but I have some idea's for it. (Gotta HAF Water, Darker HAF, My Better HAF, things like that. lol) *Open to suggestions*
    Anyways, I'll start with a picture of the goods, and then the case. Feel free to comment, leave constructive criticism, give me idea's. and ask questions.
    FINISHED PICTURE
    OK, Here's the Case, Just got it in the mail.
    Parts from left to right, Top to bottom.
    1. Cable Clamps
    2. Sleeving Kit, Shrink Tube
    3. Zip Ties 100pk.
    4. Masterkleer 15ft. 7/16 ID
    5. Yate Loon D12SM, 120mm Medium 71CFM 33dbA x 4
    6. Dual 12" Cold Cathode UV Tubs
    7. Swiftech MCP-655 D5 Pump
    8. Pentosin G11 UV Blue Dye, PT-Nuke (Kill Coil in Mail)
    9. PTS 3x3" Gel Stuff, For pump mount
    10. Swiftech Micro Res v2 w/ DD Fatboy (High Flow 1/2 Barbs)
    11. More DD Fatboy 1/2 High Flow Barbs
    12. Swiftech Apogee GTZ Block w/ Same barbs
    13. Black DD Fillport (Mounting in top of HAF)
    14. Rust-oleum Black Satin Paint for inside case
    If your wondering where the RAD is, I had the PA120.2 and had to sell it. I will have the Feser TFC 360 Tomorrow.
    OK, Now to start. I've decided to paint the case Satin Black, and I just applied my second coat of primer.
    Painting Side Panels
    I'll cut out the rear 120/140mm fan Grill to help with airflor and cut down on noise.
    Check out my work area, and see my Kayaks. During the summer I take those out about once a week. It's amazingly fun.
    More pics of my parts I'll be using, so everyone doesn't need to ask. (I hate imageshack) What's better to use?
    All my parts that were removed from the HAF 932 for painting. Patiently awaiting going home.
    This is it for tonight, More to come tomorrow. Thanks for looking. Feel free to comment.
    Project HAF 932 Water-Cooled
    __________________
    New OC Validation
    - Q9650 4.0 Ghz For Now -
    - GTZ, Feser 360, D5 Vario, EK Multi-Option -
    - eVGA 750i FTW! -
    - eVGA GTX 480 H20 & GTX 295 -
    - 2x2GB Dominators PC2-8500C5D -
    - WDCaviar Black 640GB AALS x2 (Raid0) -
    - FreeAgent Pro 500GB Ext x2 -
    - Enermax Revolution 85+ 1050w PSU -
    - X-Fi XtremeGamer -
    - CM HAF 932 H20 -
    - Dell U2410 IPS LCD -
    - Logitech G11 & MX-518 /G9 -
    - Sony 24x Optical w/ LightScribe -
    - BOSE Companion 3 -
    - ATH-AD900 Cans & UE Triple.Fi 10 Custom IEM's -
    - Nikon D40 w/18-105mm & 55-200mm VR's -
    Sep 2008
    Las Vegas
    oh no, I couldn't find where to do a log.. and after posting this. I see it now.. ahaha.. Sorry
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
    Banned
    Jan 2009
    i would do a glossy coat after that to make the it seem shiny
    other than it keep working
    Sep 2008
    Las Vegas
    well, thats just the primer, and the Black Satin has some clear coat in the bottle already so it won't really help any. the guy at home depot said it would be a waste of time to do it that way. Just use the spraypaint and be good. He said do 5-7 light coats instead of 3 thick ones, and no need for a clear coat after..
    I'm going to sand a little today now I have 2 coats of my main black satin, Get that orange peel away. then go ahead and finish this job for today, and post pics tonight.
    Thanks!
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
    Sep 2008
    Las Vegas
    So, Like the above post, I got a lot done, but not many pics. I went ahead and got up this morning and did another coat of Satin Black at about 10 in the morning. around 1:30 I did some Wet Sanding with some 1000 grit paper, just lightly, nothing to severe. and then I let it dry, helped it with my Compressor of air.. haha. And then I did another coat, and so on.
    So today I did 3 more coats, for a total of 5 coats to my CM HAF inside. It looks really good, and I think the sanding really helped smooth it out, so I don't have too much of that orange peel look to it. but I didn't do it to the last 2 coats. plus I'll use grease where you take the panel off to help with scratching.
    Anyways, enough talking, Here are the pics.
    My new RAD.. I'm exited.
    Here are some pics of my Fans, like said above. I got the Yate Loon Medium speed fans, and I went ahead and sleeved all them today. I love the sleeve job, Looks so clean.
    Close up on the sleeving.
    And thats about it for now, I took a few more pics than that, but I'll have to do some editing in Lightroom tomorrow and remove some of the marks from the dust in the Sensor on my Nikon D40, to bad amazon's shipping is slow, or I'd have my sensor cleaner already. ;( I have to take all the shots at a low enough f/stop in order to not see the dust marks, but soon I'll have that fixed.
    More pics to come tomorrow as I put the case back together.
    Thanks for watching.
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
    Jun 2007
    mars
    good sleeving on fans
    may you show another end, near connectors?
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Nice sleeving, and glad to see you got your radiator. Looking forward to seeing how your paint job came out.
    Dec 2008
    Santa Clara, CA
    Oh hey, I just got some of that same sleeving from Fry's last night. It's great stuff. I don't know how you're cutting it, but I've been cleaning up the ends with a soldering iron. Absolutely no chance of fraying after that. Great job on the fans.
    Jan 2008
    Midwest
    looking good!!! cant wait to see the rest.
    i use photobucket to host the pictures.
    edit...how do you take these off?
    Windows 7 Ultimate x64
    Cooler Master HAF 932
    Intel i5 750 @ 3.8Ghz LC Fuzion V2
    ASUS P7P55D Pro
    2GBx2 GSKILL F3-16000CL9D-4GBRH
    eVGA GTX 470 SC Koolance Full Cover
    Corsair VX 550
    Dell 2209WA & 2709W
    Razer Lycosa & Cooperhead
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Watch the sleeving, it can become addicting!
    Oct 2008
    Leeds UK
    Quote Originally Posted by theseeker View Post
    yeah but..
    if you are addicted to coke, you get a bleeding nose,
    if you are addicted to sleeving, you get painful, sore, bleeding fingers
    nice project! I like those cases.
    Jun 2007
    mars
    but i would like fans come sleeved right out of box
    unfortunately this never happened, or quality is quite poor
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
    Jan 2009
    Subscribed!!!
    I have a same case. Gonna start WC project soon. Can't wait of your progress
    Sep 2008
    Las Vegas
    well, performancepc's you cang et fans sleeved already for you.. great buy, but I did them by myself, and I'll post pics of the other connectors tomorrow..
    Yes, sleeving is addictive, I want all my wires to be sleeved now.. all of them.
    Thanks everyone, and yea, I just used a lighter to seal the sleeve ends. I'd barely get it warm and use my finger to open the end a little, then seal it off better. then just use it after that. Then I used a lighter for the heatshrink tubing also. Might as well. It works.
    as for taking the drive bay locks out. you need to start with like the top left side. and push down as hard as you can without breaking it, and it will pop out, it has to clear the plastic edge, then do the otherside and your good. I did that on the first few, my fingers got tired, but then I started just doing that, with a screwdriver inside helping my push them over the metal lip's that are in the way. So it went very fast, I hear the trouble is adding them back on without scratching my new paint job. lol. I'm sure I'll figure it out though.
    More pics of sleeving, and the case with finished paint coming tomorrow, I drank to much jack tonight to actually do work. lol.
    Thanks, stay tuned!
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
    _
    Apr 2008
    Wisconsin, United States
    Looks awesome so far. Is there any way to remove the cooler master badge off the front?
    Feb 2009
    Bet this turns out nice, good job so far.
    Sep 2008
    Las Vegas
    Thanks guys, Yea I could remove that if I wanted to... why?
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
  18. #18
    Dec 2008
    Kansas City
    Same setup as what I've got planned....I've got this thread bookmarked!!
  19. #19
    Sep 2008
    Las Vegas
    wasn't able to take pics tonight. I'll for sure be posting some tomorrow.
    check back tomorrow night for paint pics.
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
  20. #20
    Jun 2007
    mars
    how do u plan to setup 360 rad?
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
  21. #21
    Sep 2008
    Las Vegas
    I have not decided yet on that, any idea's or suggestions would be nice.. I only have 4 matching fans at the moment. I dont wanna put 3 medium fans on one side, and 1 on the other along with 2 high speed. that would be all wacked out...
    I have the 120mm Yate Loon Medium speed fans from Petra's. and I was planning on just mounting the RAD up top. I was going to put the fans on the top of inside of case. and then mount the RAD to the fans. So it would go top, Fans, RAD.. and have the air being sucked into the case. but that would be a Push config.. but I've been told that pull is better, but then I also don't wanna be pulling warm air from inside my case and from my GPU's through my RAD and out the top of my case, as that wont yield the best temps.. So what does everyone suggest.. depending on how everything goes, I might get 3 more of the YL mediums for a Push Pull config.
    So is pull better than push
    __________________
    New OC Validation
    - eVGA 750i FTW! -
    - CM HAF 932 H20 -
  22. #22
    Jun 2007
    mars
    but mesh on the roof covers only 2 fans
    3d would be covered with plastic part
    on other hand, those mesh is very wide so how will rad looks when it'll be lot of space on the sides?
    Foxconn Bloodrage
    Samsung F1 1TB
    Corsair TX950W
    NEC 2690WUXi
  23. #23
    Feb 2007
    From Martin "Push Vs Pull - This depends on fan speed/power. The high speed fans at 2000RPM with a 38mm fan thickness provided the best performance in a push condition. The slow speed fans with 1350RPM with a 25mm fan thickness provided the best performance in a pull condition. I would estimate that performance line is likely to cross in the 1500-1700RPM range where they are equal. So.... slow speed = pull, high speed = push, medium speed = it doesn't really matter."
  24. #24
    _
    Apr 2008
    Quote Originally Posted by xguntherc View Post
    It just looked like it could be removed. Also, i don't like company badges on my case.
  25. #25
    Nov 2008
    Great case!
    I expect a good work here!
Tags for this Thread
