Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 247
Thread: All 7900 owners please check something..!
    Dec 2005
    Netherlands
    I was doing some testing today with my XFX 7900GTX and noticed something during a temp test with ATiTool..
    On 2D mode all is well but as soon as I hit the artifact scanner and even more clear when you just hit the Show 3D view there's this high pitched noise coming out of the back of the card where the volt regulator is located.
    I had my case open and have a very silent system and it spotted my attention immediately... Although for some you might need to listen up close..
    I know nothing about electronics but it sounds like some sort of interference of some sort... maybe a capacitator or something..
    Can you verify if the same noise comes from your card...?
    Lian Li V2000+ Modded
    Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
    Asus Rampage Extreme 2
    OCZ 3x2GB DDR3 1600 Platinum
    EVGA GTX460 768MB 850/1700/2100Mhz SLi
    EVGA 8800GT SSC 730/1800/2000Mhz
    Corsair HX850W
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Some stuff with my 7800. I can hear it when running 3D Marks. It is my video card, and I don't know where it is exactly.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Jun 2005
    Denmark
    My 7900GT did the same in the beginning but after a while it stopped, or maybe I just don't hear it anymore.
    /Grau
    67744 - 30150 - 13273 - 7504
    Life is like a beer, the longer its open, the worse it gets
    Dec 2005
    Netherlands
    Another thing I noticed... when you run ATiTool... toggle between 3D view and artifact scanning several times then all of a sudden my FPS drops from 700+ to a mere 150-200 and won't go up unless I restart the tool.
    It would appear as it downclocks itself or reverts to 2D speeds..?
    Corsair HX850W
    Dec 2005
    Netherlands
    OMFG! http://www.xtremesystems.org/forums/...1&page=1&pp=25
    Do the 7900 cards have the same capacitor issue....?
    2.3 Listening noisy audio
    This method sounds quite wierd, but the more I have been playing with this problem the more sure I am that mysterius sound/audio generated by 6800le-card is related to BS-problem. In order to test whether you have encounter this issue see chapter 5.4 for details. I considered that noisy audio is generated by oscillating switching regulator, and having such case makes the card more vulnerable to rapid deterioration of filtering capacitors (=could finally lead to BS). Therefore, I suggest detecting 'noisy audio' is warning signal: the card is going to give BS some day !
    That's the noise I was talking about..!
    Corsair HX850W
    Muslim Overclocker
    May 2005
    Canada
    Guess they are trying to produce these cards as cheap as possible. This maybe related to all those problems people are having with 7900GTs.
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
    I am Xtreme
    Feb 2003
    Netherlands
    I get this very high pitched noise when my screen corrupts.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Jul 2005
    Illinois
    It's a sudden increase in voltage when the card is put under load.... s7 explained it to me.
    Quote Originally Posted by nn_step
    Well CPUs are like women they all like things specific ways for them.. Some love 8x and others Love 9x or 7x.. they all just have their G-Spot and you have to learn to use it..
    Quote Originally Posted by nn_step View Post
    He should have given up his nuts too. Since clearly anyone that wants any Apple product that bad, Should NOT ever breed.
    q6600 @ 2.6
    EVGA 680i
    OCZ fatal1ty ddr2 800
    8800gt SLI
    watercooled
    Dec 2005
    Netherlands
    More info is coming... this time from a Dutch forum where I'm also a member of tweakers.net and Mr-Beamer did a very interesting thermal test on XFX 7900GT...
    Image of the GT.. top of the image is the Zalman 9500.. on the right observer the white spot..
    Enlarged image of the white spot... white represents heat which is over 80°C as you can see..
    Regular shot of the problem area and you'll see the ISL6549 chip which produces the problem..
    Googling for the chip gives us the info that the chip is rated up to 70°C and not the 80.8°C measured..
    So in short... the back end card is overheating and this proves it.
    Corsair HX850W
    Oct 2005
    Netherlands
    hmm nice find, i got the same noise from my card (7900gtx) when its switching 2d/3d in between 3dmark tests. ill try putting a heatsink on that chip tonight, see if that helps the card..
    24/7 setup:|e6600 27B @ 4.1ghz|Commando|8800GTS 640mb @ 600/1000|OZC pc8000 plat. @ 455 4-4-4 2.1v|Frostmachine by Jort|'05 '06 (old amd scores)
    FullSpecs
    Dec 2005
    Netherlands
    I'm going to give up on this crap.. today the lockups and artifacts started again..
    nVidia can shove their 7900 cards up their ass. I'm going back to ATI
    Corsair HX850W
    Xtreme Mentor
    Oct 2005
    Portugal
    Quote Originally Posted by NightCrawler™
    i already did it
    I change XFX 7900GT Extreme to x1800XT 512Mb for less $$$ and i think its better
    [Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
    [Review] ASUS HD4870X2 TOP » Here!! «
    .....[Review] EVGA 750i SLi FTW » Here!! «
    [Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
    [Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
    Dec 2005
    Netherlands
    I just got a Sapphire X1900XTX and apart from the "holy crap" noise it makes it totally owns so far..
    Corsair HX850W
    Mar 2006
    Hmmm I have been wondering wtf that noise was for awhile now. That concerns me a little bit.
    DFI NF4 SLI-DR Expert Venus #s 909, 917, 924 w/ FragTek Sysxtreme Mosfet/Ram Cooling Bracket
    Opteron170 CCBWE 0550 UPMW Testing
    2GB G.SKILL DDR500 @3-4-7-3 1T
    7900GTX SLI (650/1600)
    PC POWER AND COOLING 1KW
    2x74gb Raptor Raid 0
    2xSeagate 7200.9 300gb
    NEC 3550A x2
    Heat:twisted5
    Sep 2005
    My 7900GT hasn't made any noise but that of its fan. Got a 9600pro here that does make a very high pitch sound though.
    Now about that back area- I can not hold a finger on those chips for even a second because they are so hot. Is it safe to put a heatsink on them.. say a cut up AXP heatsink?
    Dec 2005
    Netherlands
    I don't see why not... but IMO once the chip got overheated it's going to get worse regardless any fans..
    I had 2 72CFM fan blowing over that area and it still froze up on me... not as bad as without the fans but still it froze up..
    Corsair HX850W
    Jan 2005
    No(r)way
    It seems like corners were cut to keep these cards as cheap as possible. I had problems with my Club3d 7900gt locking up before I directed a fan towards that area, for now it seems to be completely stable in FEAR (which I find very taxing for the card) clocked at 530/1600 @stock volts. But those voltage regulators (or whatever they are) still get insanely hot, even at stock clocks. I am thinking about putting heat sinks on them.
    Obsolescence be thy name
  18. #18
    Mar 2006
    United States of America
    Even my two 6600GT's make these weird high pitched sounds when i 3DMark changes from loading screen to 3D :/
    - Schmetterling
  19. #19
    Feb 2005
    Minnesota, USA
    Just an FYI, the SOIC package can handle junction temps up to 150C. So, 80C would be well within tolerance. The regulator also has a built in thermal shutdown. I believe the 0 to 70C temp you found was the operating environment for the chip, not the tolerance of the actual chip.
    QX6700 @ 4.0 Ghz - EVGA 680i - 4 GB DDR2-1066 (4-4-4-10) - 8800 GTX SLI - 2 x 150 GB RaptorX RAID 0 - Seagate 500 GB - DVD-RW-DL - Realpower Pro 1000W - Vapochill LS - Dell 3007
    Q6600 G0 @ 3.6 GHz - EVGA 680i - 2 GB DDR2-1000 - 8800 GTX - Seagate 500 GB - DVD-RW-DL - Enermax 1000W - Swiftech Loop - Dell 3007
    E6850 G0 @ 3.6 GHz - EVGA 680i - 2 GB DDR2-800 - 8600 GTS - Seagate 250 GB - DVD-RW-DL - 700 W - ThermalRight SI 128 - Dell 2007
  20. #20
    Dec 2005
    Netherlands
    Interesting if you look at the datasheet where they warn for volt spikes which can easely damage the chip... (page 14 of the PDF)
    There is no maximum spec for PHASE spike below GND,
    however, there is an absolute maximum rating for (BOOT
    PHASE) of 7V; exceeding this limit can cause damage to t
    IC, and possibly to the system. Since the BOOT signal is
    typically 5V above the PHASE node most of the time, it on
    takes a few volts of a spike on either signal to exceed the
    limit. A good design should be characterized by using the
    math function or differential probe, and monitoring these
    signals for compliance, especially during full loads, where
    the signals are usually the noisiest.
    If the power efficiency of the system is important, then other
    FET parameters are also considered. Efficiency is a
    measure of power losses from input to output, and it
    contains two major components: losses in the IC (mostly in
    the gate drivers) and losses in the FETs. Optimizing the sum
    involves many trade-offs (for example, raising the voltage of
    the gate drivers typically adds power to the IC side, but may
    reduce some power on the FET side). For low duty cycle
    applications (such as 12V in to 1.5V out), the upper FET is
    usually chosen for low gate charge, since switching losses
    are key, while the lower FET is chosen for low R
    DS(ON)
    since it is on most of the time. For high duty cycles (such as
    3.3V in to 2.5V out), the opposite is true.
    Corsair HX850W
  21. #21
    May 2004
    Quote Originally Posted by Frodin
    You are just thinking about putting a HS on? I did it at an instant when I first read about it and felt the IC with my finger and it was like "Ouch!" That was it, HS on! I dunno, I guess this is why my card never has a single hiccup since I have it (from a Step Up). A lot of people are complaining about this problem, yet no one seems to take the time to put a heatsink on this particularly "HOT" IC. Having read so many users having this problem, if I were to get a new card, the first thing after I have taken out the card is to put a heatsink on this special IC.
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
  22. #22
    Apr 2006
    Belguim
    Got the same noise with my 7600GT if I run a 3Dmark, but I think its louder wen I overclock the card...I will test this again later.
    / DFI Lanparty UT nF4 ULTRA-D / AMD Athlon 64 3000+ Venice / Zalman CNPS7700-Cu / OCZ 2x512Mb EL Gold VX DDR PC-4000 DC / Nvidia XFX 7600GT Extreme 256Mb / Zalman VF700-Cu / Enermax Silver Wizard 3 case / Levicom X-alien voeding 500W /
  23. #23
    XS_THE_MACHINE
    Jan 2006
    USA/California/Sacramento
    i have the same noise.... but i cant comment if it is normal as 1: i have a VMod 2: i accidentally broke of a capacitor and stck it back on 3: i have a VMem mod
    but i think im gunna rma as it is pretty loud
    Asus P5B-Deluxe 0614
    Conroe E6400 @ 2.56ghz
    Team Xtreem DDR2 2x1GB @ 900
    ATI X1900XTX // MC14 Ramsinks -DEAD- Using spare 7900gt now
    Hitachi 80gb | Hitachi 80gb | Seagate 320gb
    Mountainmods U2-UFO Original Black \\ BenQ DVD-RAM
    Corsair Hx620
    Swiftech Storm r2 \\ Swiftech MCW60 \\ Swiftech MCW30 \\ Thermochill PA120.3 \\ Swiftech MCRES Micro \\ DDC+ Plexi Top
    Heatware | Guide To Current WaterCooling Components | Guide To WaterCooling and Leak Testing
  24. #24
    Apr 2006
    Belgium
    heatsinks did the trick here
    no artifacts or reboots anymore
    http://img58.imageshack.us/img58/7069/dscn14449ax.jpg
    http://img299.imageshack.us/img299/8320/dscn14464op.jpg
    the capacitators don't seem to make any noise
    but maybe that's because 11 fans make a lot of noise...
  25. #25
    Dec 2005
    Netherlands
    LOL
    Good stuff it works with those heatsinks...!
    Corsair HX850W
