Results 1 to 25 of 97
Thread: [Testing] Core I7 920 (watercooled) & Gigabyte UD5 X58
Threaded View
    Xtreme Mentor
    Oct 2005
    Portugal
    Intel Core i7 920 & EX58-UD5
    System
    CPU : Intel Core i7 920
    VGA : Powercolor HD4870X2 2Gb GDDR5
    Motherboard : Gigabyte UD5 X58 (F3 Bios)
    Ram : 3GB Corsair DDR3-1600Mhz
    PSU : Corsair TX750W
    HDD : Samsung F1 750GB
    O.S: Windows Vista 64bit +Sp1
    Driver : Catalyst 8.11
    Case : Antec Nine Hundred (3x Fans 120mm & 1x Fan 200mm)
    Cooling: Watercooling (BIX 240mm - Enzotech waterblock - Pump Eheim S600 Station)
    CPU : Core I7 920 OEM
    Batch: 3836A531
    Note: You should use the White Ram Slots !!!
    Task Manager @ 8 Threads
    Vcore Voltage
    With Loadline calibration enabled :
    1.31v Bios
    1.28v Windows Idle
    1.264v Windows Full
    Vdrop (Windows Idle >> Windows Load ) = 0.015v
    Total (Bios >> Windows Full Load ) = 0.04v / 0.05v
    Temps - Watercooling
    CPU Default
    Ambient Temp= ~16º
    Idle Temp =25º
    Full Load Temp = 37º/41º
    Overclock
    Bios Settings @ 3.8Ghz & DDR3-1600Mhz :
    Multi: x19
    BCLK:200
    Performance : Turbo
    RAM: DDR3-1600Mhz @ 9-9-9-24
    Loadline : Enable
    Uncore : x16
    Memory : x8
    QPI/VTT : 1.26v
    Vdim : 1.60v
    Vcore : 1.31v Bios (1.264 Full)
    CPU Settings :BIT & Multi Core ON , rest of settings OFF
    Note: Vcore voltage may not be the same for every system , you need to test !
    EX58-UD5 Temps @ Stock Cooling
    Core i7 920 @ 3.8Ghz (200x19)
    Board Temp Idle = ~36º
    North bridge Tem Idle = 48ºc
    Core i7 920 @ 3.8Ghz Temps (water)
    Ambient Temp = ~16º
    3800Mhz @ 1.264v Load (1.28v Idle)
    Idle Temp = 26º/31º(Watercooling)
    Full temp = 58º/64º
    Benchmarks
    CPU = 3.8ghz
    Ram Default (1600Mhz @ 9-9-9)
    Superpi 1M (Vista 64bit)
    10.87s
    Everest
    16500Mb/s & 28.6ns
    With Intel X38 + E8400 @ 4Ghz + 4GB DDR2-1069Mhz = around 9000MB/s & 54ns !!
    3DMark Vantage
    Core I7 920 @ 3.8Ghz & Ram Default ( DDR3-1600Mhz @ 9-9-9-24) !
    Also C2D E8400 @ 4000Mhz & 4GB DDR2-1066Mhz @ 4-4-4-12 !
    E8400 @ 4Ghz
    Core i7 920 @ 3.8ghz
    Results:
    E8400 @ 4Ghz
    CPU Score : 7189
    CPU Test 1 : 1095.33
    CPU Test 2 : 11.96
    CPU Score : 23077
    CPU Test 1 : 3264.79
    CPU Test 2 : 28.79
    3DMark 2006
    E8400 @ 4Ghz
    Results:
    E8400 @ 4Ghz
    3Dmark Score = 19877 Marks
    CPU Score = 3695
    3Dmark Score = 22939 Marks
    CPU Score = 6687
    Cinebench Benchmark (64bit)
    3GB DDR3-1600Mhz
    Windows Vista 64bit
    21813
    Winrar Benchmark
    3GB DDR3-1600Mhz
    Windows Vista 64bit
    Crysis Benchmark DX10 - 64bit
    3GB Corsair DDR3-1600Mhz 9-9-9-24
    Gigabyte X58-UD5
    Powercolor HD4870X2 2GB GDDR5
    1680x1050
    Very High
    DX10
    Windows Vista Ultimate 64Bit
    CPU Bench
    Average = 41.3 Fps
    Far Cry 2 Benchmark DX10
    Powercolor 4870X2 2GB GDDR5
    1920x1200
    AA 2x
    Ultra High Settings
    DX10
    Vista 64bit
    Average = 73.5 Fps
    Overclock - Core i7 920 @ 4000Mhz
    Bios Settings @ 4Ghz & DDR3-1600Mhz :
    Multi: x20
    BCLK:200
    Performance : Standard/Turbo
    Loadline : Enable
    Uncore : x16
    Memory : x8
    QPI/VTT : 1.26v
    Vdim : 1.60v
    Vcore : 1.38xv Bios (1.344 Full)
    CPU Settings : BIT , Multi Core & Turbo ON , rest of settings OFF
    Core i7 920 @ 4Ghz Idle
    Core i7 920 @ 4Ghz @ 1.34v Load
    Everest @ 4Ghz (Turbo mode ON = +200Mhz single App )
    Superpi 1M @ 4Ghz (Turbo mode ON = +200Mhz single app )
    Far Cry 2 Benchmark DX10 @ 4Ghz
    Core i7 @ 4Ghz (1.36v Idle/1.344v Load)
    Turbo Mode ON ( x21 multi in Single App)
    Corsair 3GB DDR3-1600Mhz 9-9-9-24
    Gigabyte X58-UD5
    Powercolor HD4870X2
    1920x1200
    AA 2x
    DX10 Mode
    Ultra High Settings
    Vista 64bit
    Average = 74.5 Fps
    Also notice the Min Framerate = 60 Fps
    With E8400@4Ghz the Min Framerate = 48 Fps
    CPU Máx Temp Running Far Cry 2 = 49ºc
    Core i7 920 @ 4.1Ghz (4.3Ghz Turbo On)
    205 BCLK
    DDR3-1640Mhz 9-9-9-24
    Uncore x16
    memory 8x
    superpi 1M
    Update @ F4K bios
    3800Mhz @ 1.20v
    BCLK 200
    Multi x19
    Uncore x16
    memory multi x8
    QPI/VTT : 1.235v
    Vcore : 1.20v LOAD
    ~1 Hour prime95 @ 4Ghz
    191x21
    QPi : x36
    Uncore : x16
    Ram : x8
    Vcore : 1.264v/1.28v Load
    QPi/VTT : 1.235v
    PLL : 1.80v
    Vdim : 1.60v
    220BCLK
    validation
    http://valid.canardpc.com/show_oc.php?id=457815
    Update @ F4R bios
    Idle @ 2280Mhz @ 1.04v (Speedstep & C1E)
    Load @ 3600Mhz @ 1.12v
    Windows Vista 64bit
    Core i7 920 @ 3800Mhz @ 1.20v
    Corsair XMS3 3GB DDR3-1600Mhz @ 7-7-7-21 @ 1.62v
    Everest
    Cinebench
    22246
    Best regards
    Mascaras
    [Review] Core i7 920 & UD5 » Here!! « .....[Review] XFX GTX260 216SP Black Edition » Here!! «
    [Review] ASUS HD4870X2 TOP » Here!! «
    .....[Review] EVGA 750i SLi FTW » Here!! «
    [Review] BFG 9800GTX 512MB » Here!! « .....[Review] Geforce 9800GX2 1GB » Here!! «
    [Review] EVGA GTX280 1GB GDDR3 » Here!! « .....[Review] Powercolor HD4870 512MB GDDR5 » Here!! «
