Results 1 to 25 of 42
Thread: my first Cascade is born :-)
Threaded View
    Jul 2005
    Austria
    Exclamation my first Cascade is born :-)
    On Fri Jan 27 2006 i decided to build my first cascade!
    i bought two nice comps from a friend and a plate hx from egay. the rest is from cold_ice who was and is a great help!
    here are the parts that i used:
    1st stage:
    Mitsubishi RH-421-VH (rotary)
    Verflüssiger: 0,88kW
    30g Filter/Dryer
    evap: PlateHX 4kW
    refrigerant: R507
    .7mm captube
    2nd stage:
    Rotary 7200BTU
    Condenser: PlateHX 4kW
    30g Filter/Dryer
    selfmade evap
    .7mm captube
    refrigerant: R1150
    the first idea of how i could arrange it...
    the two compressors on the mounting plate
    i like playing with CAD...
    thats gonna be the evap:
    some parts arrived
    i'm brazing with propane+oxy, green bottle is nitrogen for purging and pressure testing
    this is the finished cascade, partially insulated, wireing is not done but i only have to connect the cables with the relais...
    my cute assistant :P
    a psu for the fan controller and for the relais, the right one is an empty psu case, i will put the relais inside it
    these are two relais, one is missing (sry 4 quality, cell phone nokia 8800 is cool, but cam is really crappy)
    the danfoss kp17, 2nd stage high pressure cut off
    desuperheater, 1st stage compressor, some piping and the condensor with 230V fan
    left upper corner of pic: here goes the cap into the suction line...
    right ... oil sep
    insulating was hell!
    the front, forgot to rotate the pic CCW
    front view
    overview...
    here is a plan of the electric wireing of the cascade
    i had the idea (i know, some did already before i did) of building a box, which is filled with nitrogen, where the mobo is mounted inside, so that i wont have condensate...
    i hope you like it, and way more important, i hope i will crack the -100°C with that thing
    any questions, tips ... ?
